Question about Pioneer GM-5000T Car Audio Amplifier
Works for about 3 mins then no sound,the blue illumination light flashes with a slight thud coming from the sub
  • Pioneer Master
  • 17,130 Answers
Remove off all the speaker connections and connect back one at a time. Check if your speaker wires have grounded or short, test the Sub seperately for any fault. If not connect and power. If you notice any distortion then there is a confirmed fault with your mosfet drivers. Make sure the +B and the ground is good when you test. Also if the signal is not distorted from the head set. Check for signs of over heating, if so there could be deteriorisation of the output drives . You must check the juctions of the mosfets for good values or else replace them. It is most possible that the fault must be in the power output than in the pre amps. So please check this out , get a familiar help if your electronics need updation. Helpful I hope. Good day
Posted on Jul 23, 2010
42inch bush tv has just turned its self of no buttons were pressed and the lights still on
the sound is an indication of a short in the set--have a shop take a look as this likely is not a do it yourself repair.
Apr 16, 2012 | Televison & Video
My protect light is flashing from red to the green power light it makes a thud noise in the sub when it flashes i have checked my ground and power it all seems to be fine does any1 have a idea on what...
You either have a short in your wiring (between the amp and the sub) or have wired the sub(s) at too low of a resistance. If for example you have wired it to 2 ohms, when the amp can only support a 4ohm minimum, the protect light would come on once you tried to turn up the volume a bit. This may happen if you have lost the wiring off one of your subs or one of the voice coils, thereby affecting the total resistance.
Mar 06, 2011 | Jensen LXA300 Car Audio Amplifier
Same monitor, same problem!!!
While the unit is attempting to "come ready", disconnect and reconnect the 7 wire blue plug. Some how or another, this disrupts the start up pattern that is failing, and the monitor comes on as normal when reconnected???
Oct 01, 2009 | Hanns.G Corporation JW-199DPB 19" LCD...
800 watt pioneer mono block blue light comes on then goes off
sounds as if u have a short going on somewheres maybe a loose gound wiredo u have the gain set to hi.check all connetions..check sub connections a sub short will put your amp in protect mode
Sep 01, 2009 | Pioneer 800W Class-D Mono Amplifier With...
Fantom 120GB HARD DRIVE BLINKS RED& BLUE LIGHTS WITH SOUND
Sounds like your drive is trying to recalibrate itself which is what the clicking noise is. This is similar to the post routine for your motherboard when you boot up to ensure everything is operating properly. You indicated the drive may have suffered some physical damage and this is a result of that. Probably a head crash and one of the heads is damaged or the calibration track is damaged. Try switching the heads with another drive of the same model. If it comes up (calibrates) get your data off fast and consider yourself lucky. If it doesn't come up then it is dead. You can call one of the repair services listed on the net or try contacting the manufacturer for their opinion. Good luck, but I think you have a very serious problem.
Aug 10, 2009 | Fantom Titanium Hard Drive
Blue illumination doesnt work
unscrew the plexiglass and try to get to the light and mess with it to see if it shook something loose, if that doesnt work, you might have to buy a new light....hope this helps!!
Mar 21, 2009 | JC Whitney - Dual Illuminite 12" Bandpass...
Sub power comes on consistently for about a second and thuds
u might have bridged the amp below is ohm load, if that the case run the speakers in series instead of parraell !
Dec 25, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Shuts off after playing music
i had the same problem, apperantly creative made an error making the hardware for the subwoofer, and put in an mos-fet with to little resistance, i called creative and gave them the serial number behind the subwoofer and they sent me a new one that hasnt acted up yet.
Jan 13, 2008 | Creative Labs Gigaworks S750 Computer...
No reception or sound on rear speakers.
Here's the fix: power off the sub-woofer and wait for 60 secs before powering it on again. My rear receiver works every time now.  I guess the sub-woofer isn't just a dumb speaker; it has some kind of smarts in it too.
Prior to this, I had only tried cycling power to the DVD player itself.  I also re-seated the two, fat cables connected to the junction box. One of them had worked itself slightly loose and the result was completely absent speaker channels.
Dec 03, 2007 | Philips Cineos HTS9800W System
Pioneer GM-5000T Car Audio Amplifier Logo
77 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
