Question about Danby Compact Refrigerator DCR-101W
Compressor in the back is hot
We just bought this compact Danby frig at an outlet store. It's been rebuilt. The number is D9604W Shortly after I plugged it in, the compressor is hot and my husband and I don't know if that's normal. If that isn't normal we are going to take it back. That is the second frig we bought from these people. We took a Diplomat back today because it was getting hot in the same place. Is this normal for this type of frig? We would appreciate your help. Thank you. Shirl Horton
    President:
  • 1,218 Answers
Good day,
It is normal for a compressor to run hotter than normal when it is going thru it's pull down cycle.
One, it is working harder than normal since the interior is still warmer than normal.
As well, at the beginning, since the machine is trying to get to normal temps as well as cooling the walls, it will run excessively if not all the time.
Waiting 48 hours would be prudent to make a judgement call.
The compressor should be warm, but since by then it should be shutting off and on it will tend overall to be cooler.
If it reaches normal operating temperatures and cycles off and on, I wouldn't worry about it.
Posted on Jul 21, 2010
My kegerator out of the blue starts making noises?
Good chance the compressor is going bad. It will likely die shortly.
May 03, 2014 | Danby DKC645BLS Compact Beverage Cooler
Compressor is hot and I hear clicking in back every couple of minutes. I understand that this indicates that the compressor is in a locked up / no start condition. the overload cools enough to reset and...
Could be bad start/over load relay, or bad compressor. Try unplugging your frig for say 30 to 40 min then, with your hand on top of a cool compressor, plug the frig back in and see if compressor smoothly vibrates for at least 5 min without becoming very hot or shutting off even though fan continues to run. When the start/over load relay fails, it can apply power to both the compressors start coil AND it's run coil at the same time for to long and it very quickly causes and over load situation. I bet your "Starting Components" (start/over load relay) are bad. Any decent appliance parts store will have what you need. Just take in the make, model, and serial number of tour frig.
Oct 11, 2013 | Refrigerators
Compressor is hot, but will not start. Just keep hearing a relay / contact clicking ebery few minutes.
Oct 11, 2013 | Magic Chef MCBR360S Stainless Steel...
Danby DUF408WE Upright Freezer not working
Does the compressor feel warm to the touch. If it does, it will be proof that the thermostat is calling for cooling and is probably good. For the obvious questions: Is the freezer in an area below 80 degrees F, is the wall outlet in good shape and not hot to the touch, is the freezer plug not blistered around the prongs, is the door gasket against the face all the way around the mating surface on the chasis. If the compressor is hot, listen for a click every 2 to 5 minutes. If the click is present the starter is your last best hope. The click is the compressor trying to start. Without the proper tools you are pretty much up against a wall. One last suggestion is to check for loose wires under the compressor terminal cover. I would suggest you look up the compressor manufacturer for a visual on cover removal. Dont forget to unplug before attempting compressor cover work. I hope you havent tried to put screws through the outside walls of this freezer or damaged the shelves inside. Both are fatal for the freezer and no repair can be made. Good luck.
Jun 03, 2012 | Danby DUF408WE Upright Freezer
Cools but constantly runs
you hit the nail on the head there,,,its the thermostat its dead!
change it they often stick in the on poshion when they stop working to save any food inside of the fridge
Jul 12, 2010 | Haier HSB03 Compact Refrigerator
Danby dkc645bls cools once, then wont kick back on when it starts getting warm.
Your compressor is not starting and in your case you have a thermal induced problem.
I looked for about an hour for parts below on-line with little success. (Danby sourced)
You have 3 possibilites as far as what is causing your problem.
1. PTC start relay / Klixon (2 parts as an assy)
2. Run capacitor
These are not expensive parts even if you ordered all of them.
The sad thing about it is the parts are probably available at your "local" appliance parts store.
If you can look at your compressors' label and copy down the
Manufacturer (i.e Embraco, Mitsubishi Elec, Panasonic etc) and ALL numbers (including LRA)
you can take that info to the local appliance parts supply and walk out with the parts in hand.
Otherwise your looking at calling Danby (number below) and telling them you need a PTC Start relay / Overload and run capacitor.
1-800-263-2629 (US)
Thanks for using FixYa
Oct 16, 2009 | Danby DKC645BLS Compact Beverage Cooler
I just brought home a DCR038W Danby compact refrigerator.
Yes, wait a whole day to let the compressor oil dran back to the compressor.
Sep 04, 2009 | Danby (DAR604BLS) Refrigerator
Danby 4.4cuft compact refrigerator
The last time I saw a problem like this, the motor/compressor was bad. If the unit is still under warranty I would contact the manufacture or an authorized repair station in your area
Nov 10, 2008 | Danby DAR483 Compact Refrigerator
Broken shelf
Lenabs,
I was able to find the shelf I needed by typing the brandname and the fridge model number online and I got the number of the part I needed from a diagram but the bad news is that it was aver $40 per shelf and it was just a piece of plastic. The new one would be just as weak as the old one. I finally decided to add some strength to the existing shelf with some hardware store aluminum and glued it on with some JB Weld. I suggest you take the broken plastic piece in with to an ACE hardware and you will be surprised how many pieces of precut shiny aluminum are there for the having.
You can use that JB Weld to join the parts and make them stronger than new. Let me know if you need some more help.
HarryF
Oct 12, 2007 | Danby (DAR604BLS) Refrigerator
Danby Compact Refrigerator DCR-101W Logo
213 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
