Question about Amana ABB1927DE Bottom Freezer Refrigerator
Does not seem cold enough and it is turned all the way to seven
  • Amana Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Dec 28, 2010
I've got the device for three weeks. It was working fine at temperature 4. But it was too cold so i turned it down to 3, still tooo cold then turned it down to 2. I even switched it to zero for a while...
I would say your thermostat in the fridge has had it. Try the internet for a local appliance parts sales shop, give them the make and model number and / or get a fridgie in to fix it.
Jun 16, 2011 | Heating & Cooling
Refigarator and freezer no longer cold enough. freezer is not freezing and refigarator is not cold enough, food is going bad. Unit is not yet 5 years old.
pull out the plug for the fridge and let it stand for 7 days then plug in after seven days.the problem is that the fan that circulates the air is cloged up with ice so you have to give time for the ice to melt off.
Mar 04, 2011 | Microwave Ovens
It seems to be cutting unevenly from left to right?
Operator's manual for the 22-547 is here.
It sounds like you may need to adjust the knives. Page 10 and 11 of the operator's manual discuss the details. See below: (I have removede references to the figure and diagrams in the manual - look there for pictures).
ADJUSTING KNIVES
To check and adjust the knives, proceed as follows:
1. DISCONNECT THE TOOL FROM THE POWER SOURCE.
2. Lower the head assembly by turning handle
3. Remove chip deflector
4. Carefully place knife setting gage, on the cutterhead so the rounded sections are directly over the knife as shown. When adjusted correctly, the knife should just contact the bottom of the center portion at each end of gage. Check the other knife in the same manner.
5. If an adjustment to one or both knives is necessary, slightly loosen the seven locking screws, by turning the screws CLOCKWISE into the knife locking bar just enough to relieve stress in the cutterhead and not disturb the knife setting.
6. With setting gage, in place, apply pressure to the knife being reset. Turn the seven knife locking screws, CLOCKWISE until the knife locking bar becomes loose. Lift springs will automatically raise the knife until it comes in contact with gage. Snug the knife locking bar by lightly turning the seven locking screws, COUNTERCLOCKWISE.
IMPORTANT: AT THIS TIME, ONLY TIGHTEN THE KNIFE LOCKING BAR JUST ENOUGH TO HOLD THE KNIFE IN POSITON INSIDE THE CUTTERHEAD SLOT.
7. If the other knife needs adjustment, repeat STEP 6.
8. After both knives are positioned in the cutterhead, turn each of the seven screws, COUNTERCLOCKWISE until the knife is secure in the cutterhead. NOTE: When tightening knife locking screws, tighten the end screws first, then inward toward the center of the cutterhead.
9. Replace chip deflector.
Jan 12, 2010 | Delta 22 - 547 12" Steel Knife Set for 22...
Quadra drive does not seem to provide enough slip
Yes it is very probable that the diff oil is so cold its not allowing for proper lubracation when cold. Once ity warms it will go away.
Dec 15, 2009 | 1999 Jeep Grand Cherokee
Fan running, weak air, fridge not cold enough, freezer working fi
it sound that your fridge is cloged of ice if so defrost it by unpluging it for the day to defrost completlyb with freezer door open then replace defrost timer if to much ice is formed on coil air does not cuculate properly thanks from gille
Feb 15, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Frigidaire MDD40WW2
Your dehumidifier may be low on refrigerant. Seems cold may not be cold enough to reach the dew point to condense moisture from the air stream.
May 09, 2008 | Frigidaire FDL45P1 Dehumidifier
My refigerator and freezer are not cooling enough
Is the fan in the freezer running?? Is there frost on back panel of freezer??
Oct 03, 2007 | Kenmore 50522 / 50524 Side by Side...
Fresh Food Compartment not cold enough
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 08, 2007 | GE Profile PSS26NGS Side by Side...
Kenmore
problem has been almost certainly caused by freezer door not being completley closed allowing warm humid air into freezer, (do not say this could not happen because it often does), sollution, turn off defrost overnight, turn on following day, within 24hrs unit will work ok. Regards Adviso
Aug 22, 2007 | Kenmore 52632 / 52634 / 52639 Side by Side...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
64 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
