Question about Bushnell Waterproof Binoculars
My bushnell 10x42 waterproof binoculars have double vision. I've tried focusing, but no luck correcting this. I've never seen nor heard of this in binoculars before
Obertelli
  • 3006 Answers
SOURCE: double vision
The yoke which connects the eyepieces and keeps them aligned as the focus changes is damaged. If you can easily move one eyepiece back and forth with respect to the other then the yoke has broken, if not then it's bent, probably cracked and waiting to break.This is easily the most common fault on most binoculars, and it's always uneconomic to repair on budget brands such as Bushnell.
If bent, the yoke *might* be able to be straightened, but it will be weakened and the alignment afterwards will rarely be spot-on. If broken, then the yoke must be replaced professionally but the repair will cost more than replacing the binoculars with new. In any case, it's unlikely that Bushnell even list the spare part for it. The break cannot be simply glued: the contact area is too small to carry the loads it has to carry, and you also usually find that the yoke bent before breaking anyway so you then have all the same problems as you do with a bent yoke.
The fragile nature of the yoke is why binoculars must always be inserted into their case with the objective lenses facing down; this avoids shock loads on the delicate yoke assembly.
I hope that you've found my posting to be of use and in return ask only that you take a moment to rate my answer.
Posted on Feb 13, 2010
  • 32 Answers
I'm assuming you have set the dioptre correctly for your eyes.
Normally this is caused by a collimation error when one (or both) prisms move. This can be by a small amount.
Your going to have to take them in for service/repair to fix this as is not a DIY problem. (Unless of course you have a collimator lying around)
Posted on Mar 25, 2009
  • 112 Answers
SOURCE: bushnell binoculars /double image
they have to be aligned if you want mail them to me for an estimate..larry@reichinstruments.com
Posted on Apr 22, 2009
  • 73 Answers
SOURCE: unable to focus my Bushnell 7x35 insta-vision binoculars
If it just turns without making the bridge between the two eyepieces move up and down then they are broken. You will need to send them to Bushnell.
Posted on Jul 31, 2009
  • 43 Answers
SOURCE: I need rubber eye pieces for our 10x42 bushnell
This depends on where you are geographically located. If you are in Australia there are only one or two people who can help. If you are in the USA the same applies. Try typing in "binocular repairs" into Google and see what pops up. For example in Australia you will find "The Binocular & Telescope Shop" and "York Optical" pop up.
Posted on Mar 02, 2010
Does anyone have a diagram or instructions on how to disassemble a Chinon Splash 10x42 binocular (waterproof)
Bryan, If lens was moving before, try a little heat on thimble, from a hair dryer to free it up, caution do not overheat as you do not want to cause distortion.
Check the attached link,instruction and guide, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Clean binoculars and their Lenses by Best Binocular Reviews
Apr 21, 2016 | Optics
I have a pair of Bushnell 20x50 Powerview getting double vision. Can focus each side by themsleves but not together.
Sorry to say but it sounds as if the binoculars have suffered a jolt.
All bincoculars are collimated at the factory so they will focus together at a "central point".
Some Binocular dealers will check the collimnation prior to shipping.. and make adjustments as needed..
If the internal prisms were shifted out of place or the frame was bent.. chances are it will be cheaper to replace then to repair... if not impossible to repair.
Inspect the frame.. to check for any debris or loose fasteners.. but I am afraid that these will need to be replaced.
Best of luck
Feb 27, 2011 | Bushnell Powerview 13-2050 (20x50)...
I own the Bushnell binoculars 21-1242 waterproof. The focus knob is broken. Can it be fixed? Can not focus them.
easy they are under warranty for 30 years from date of purchase send therm back to bushnell...
Aug 23, 2010 | Bushnell H2O 13-2412 (12x42) Binocular
The diopter setting eyepiece has come out of the body of my Bushnell 10X42 ''Waterproof'' binoculars, model 13-2410. I see keyways inside, but cannot screw it back in more than about 1/4 turn, which is...
The entire diopter setting eyepiece was off.I separated the eye cup from the rest of the diopter setting eyepiece, and aligned the channel guides on the lens piece to slide it into place. Then holding it in place, taking care not to gum up the lens, I experimented with how to screw in the retainer ring so that its white dot registered correctly. Finally reattach the eye cup and focus. It's like new!
Apr 10, 2010 | Bushnell Waterproof Binoculars
I dropped them and they are seeing double now they are the xtra-wide bushnell ,how do i get them back in focus
Try grabbing the binoculars in both hands and twisting the body in the opposite direction of the double vision until the images coincide.
Sep 25, 2009 | Bushnell Xtra-Wide (4x30) Binocular
Unable to focus my Bushnell 7x35 insta-vision binoculars
insta-vision bino's are self focusing no adjustments.
Jun 05, 2009 | Bushnell "Insta-Focus" Binoculars
Double vision
Mar 24, 2009 | Bushnell H2O 13-2412 (12x42) Binocular
Bushnell night vision binoculars
They do stay on for a while after switch, that is OK. Dim and out of focus may indicate that the output voltage is low. If replacing the battery does not fix it, then the problem may be in the power supply circuit.
Nov 08, 2008 | Bushnell 26-0400 Binocular
Double vision
The distance between the centers of the eyepieces of your binocular must be the same as the distance between your pupils. This distance is adjusted as follows: 1. Focus on a distant object. 2. Pivot the two halves of your binocular farther or closer apart until you can see a single unobstructed, circular field of view. Make sure to focus on a distant object when you do this because when you focus on a close object you always see two slightly overlapping circular fields. Your binocular may have a scale on the top, between the eyepieces, to help you remember this setting.
Jul 03, 2007 | Bushnell Powerview - Compact 10 x 25...
Bushnell Waterproof Binoculars Logo
367 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
