Question about Kodak Easyshare C813 Digital Camera
When camera is turned on it says memory card is
I have a kodak easy share C813. When camera is turned on it says memory card is protected. i have pushed the reset swithch on the memory card. What can i do next to try to fix this problem.
    Brigadier General:
  • 11,967 Answers
If you're using an SD card, it doesn't have a reset switch. It does have a switch to lock (protect) and unlock the card. It should be in the unlocked position.
Posted on Jul 21, 2010
Kodak easy share c183 memory card protected how to reset
Camera LCD: "Memory card is protected (Reset ... - Kodak
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
[PDF]KODAK EASYSHARE C183 Digital Camera
resources.kodak.com/support/pdf/en/manuals/.../C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
Jan 26, 2016 | Kodak Easyshare C183
How can I switch on memory card?
Make sure the memory card in not write protected. There is a small sliding switch on it.
On the camera, go to Settings and look for Save to Camera, Save to SD Card.
Jan 26, 2016 | Kodak EasyShare Cameras
Need to install driver for mac for the kodak easy share digital camera
http://support.en.kodak.com/app/answers/detail/a_id/16433/kw/c813
You might want to consider NOT connecting the camera to the computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use iPhoto or any other photo cataloging program.
Nov 30, 2010 | Kodak Easyshare C813 Digital Camera
When I take pics w/ my kodak easy share c813. The pics don't go to the memory card, it goes directly onto the camera's hard drive. how do I fix this problem?
Sounds like it doesn't recognise the card.
Probably the first thing to try is formatting the card. There is a function in the camera menus to do this. If it won't format or gives an error when you try, then there may be an issue with the connectors in the card slot or the card may be incompatible.
Maybe it is having trouble with the size of the memory. Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards.
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Nov 05, 2010 | Kodak Easyshare C813 Digital Camera
When I turn on my kodak easyshare c813 camera, I can't get past the ''Memory card is protected'' error message. Any ideas?
Yup.  Quite often on media cards there's a tiny switch to write-protect the card so important files can't be overwritten/deleted.  Simply put the switch to the other position and you'll be able to take photos again.
Please rate me if you found this helpful.  Thanks.
Mar 09, 2010 | Kodak Easyshare C813 Digital Camera
How to transfer pictures from internal memory to memory card (Kodak easy share C813)
E-mail your question to this address: http://www.kodak.com/global/en/service/contactKodak/email/consumerDigital_contact.jhtml?pq-path=13452
Jan 09, 2010 | Kodak Easyshare C813 Digital Camera
How to download pics. from my camera to my computer
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  1. On the camera, press Review and then Menu.
  2. Select Image Storage.
  3. Change to Internal Memory.
  4. In the menu listing, scroll down to Copy, and select OK.
  5. Select a single picture, or select All.
When you have finished copying pictures, reset the Image Storage location to your original setting.
Once your pictures are transferred to the SD card it will be easy to transferre onto the computer.
Dec 12, 2009 | Kodak Easyshare C813 Digital Camera
When i turn my kodak easy share C813 on it says
take out the battery and set your mode dial to auto and put the battery back again and turn on your camera.
Aug 19, 2009 | Kodak EasyShare CD33 Digital Camera
Help Turning my camera On
Hi , I had the same problem ,Kodak advised getting re-chargable batteries Mah 2500 ,normal batteries just are not powerful enough. Mine works fine now
Aug 31, 2008 | Kodak Easyshare C813 Digital Camera
Kodak Easyshare C813 Digital Camera Logo
185 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
