Question about Frigidaire PLHS67EESB Side by Side Refrigerator
I have a Frigidaire PLHS67EEsb7 side by side. Every couple of months, something happens that causes the coils in the freezer to freeze over and the fridge and freezer stop cooling altogether. I have to take everything out and use a hair dryer to defrost the coils. Once they're defrosted, it works again just fine...for a few months. I'm tired of this problem and would like to fix it once and for all! What's up?
  • morgan319 Jul 22, 2010
    Will that fix it for good? Do you know what is causing the problem? Is it a faulty part, or just accumulated moisture over time? I'm a breast feeding mom and can't afford to lose my frozen milk supply by having the freezer break again.
  • 4,793 Answers
Clean out all the vents,syringe the drain holes with clorine bleach,check the door seals for air tightness all round...after a full defrost(do not help it with a hairdryer as this only defrost the ice you can see....try to defrost it when you can leave it for 24/36 hours....with the doors open and switched off....then dry thoroughly.
Posted on Jul 21, 2010
  • geoff hunter Jul 22, 2010
    if you live in a high humidity area,frost will build up quiet quickly,even though it is frost free(the food is kept frost free).it is not a problem to keep the vents/drains clean(free of dust etc).
    try to ensure that all food is wrapped so that minimises the frost a bit,and check door seals are flat to the cabinet,nothing will stop ice buildup,but minimises the problem.
Temp on screen rises & flash high temp.
Hallo
The compressor winding's could also be faulty.
regards
May 19, 2016 | Frigidaire Refrigerators
I have a Frigidaire professional model Phs68ejsb since 2009. It will randomly start to cool down both in the freezer and refrigerator side, stay like that for a couple of days and start working again. This...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 22, 2011 | Frigidaire Professional Series PHS68EJSB...
We have a Frigidaire FRS202RG side by side fridge/freezer that is about 9 years old. In the last 3 months, it has begun frosting up in the bottom of the freezer with ice forming over the vents at the back....
Sounds like the fan behind the rear freezer panel has stopped working,therefore no air flow over evaporator coils causing ice built up and no cooling on refrigerator side. easy fix
Nov 30, 2010 | Frigidaire FRS26ZSG
I have a Frigidaire side by side frig, model FRS20ZKG. My supply inlet to the ice maker keeps freezing which after 2-3 cycles will not make any more ice because no water can make it to the tray. This...
The supply inlet to the ice maker is connected (via metal coupling) to the radiator-like-coils in the freezer which are actually hot and they keep the line from freezing. If this coupling is not connected close to a heat source, then the supply line can freeze as you are experiencing.
If possible reroute the supply line out of the freezer area
Sep 23, 2010 | Frigidaire Refrigerators
Model FRS26ZRF---Water forming ice block on bottom of freezer
I ll tell you whats going to happen . the clean coils will helt it to freeze up sooner . that part is good / but the ice problem is a defrost problem caused by the heater or defrost control failure . so keep on working your not done yet .. .you will find the heater and defrost terminater inside the fack of freezer .. mm
Jul 06, 2010 | Frigidaire FRS26KF5C Side by Side...
Freezer won't freeze, but refrigerator section fine, have cleaned main coils and removed ice buildup on defrost coils, still won't freeze, only gets to about 32 degrees
one problem i had was the condensor fan had stopped working because it was clogged up with ice buildup, check and make sure the fan is not iced up, once a year i have to unclog ice from the condensor fan which located behing the white panel, which you unscrew and you can get a visual on this fan. my freezer would stop working but the fridge part was fine. something as small as that was causing this problem for me.
Apr 21, 2010 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire side by side freezer - LOUD noise...
It sounds like the evaporator fan is hitting ice that is built up on the evaporator coil. When it's making the noise, open the freezer door and see if it stops.
(Most models are wired so that the evaporator fan cuts off when the freezer door is open.)
Check the inside back, lower panel of the freezer for ice built up or frost on it. If there is, you have a defrost problem that is most likley a bad heater. It's located around the coil inside the freezer behind the panel you will be looking at. The defrost problem would explain the freezer not freezing ice cream.
Nov 12, 2009 | Frigidaire FRS26R4A Side by Side...
Frigidare side by side FRS202RG freezer cold, fridge side warm (coils frozen)
your having a defrost promblem either the adc-auto defrost control board is bad or the defrost termination thermostat is bad or the heater is bad thats rare but does happen if you will open the refridgerator door and get me the model number off the serial plate on the toop of the compartment just look up when you open the door then let me see if it has an adc or timer i can reply and be more spefic about fixing your promblem hold my rating till we are done ok
Mar 30, 2008 | Frigidaire FRS26ZSG
Fridge problems - frigidaire
Sort of sounds like the adaptive defrost board is bad and you are not going into a defrost cycle. Do you have ice build up on the lower interior freezer section? Are the vent slots full of frost/ice? Ideally, pull the freezer shelfs out and take the little aluminum panel off the interior back to look at the coils. Are they basically a block of ice and frost? The problem happens when the unit doesn't go into defrost cycle and the coils freeze up. That blocks the air flow in the freezer so you get frozen food at the bottom but soft stuff at the top. And the frige just can't get enough cool/cold air from the freezer section to cool anymore. Power surges or blackouts, etc. can just destroy the defrost circuit board. Without good air flow the unit is not going to cool properly.
Dec 17, 2006 | Frigidaire PHSC39EESS Stainless Steel Side...
Frigidaire PLHS67EESB Side by Side Refrigerator Logo
137 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
