Question about Acer Aspire 5100 Notebook
Dim lighting everytime i turn on my laptop i have a very dim lighting thats going on. i can barely see the screen.i just bought a new battery/charger to try and see if thats the problem.I also tried brightening my screen but im guessing its at its brightest because it light up and go back dim.Please let me know if charging the laptop with my new charger will help or if there is another problem going on thank you
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 98 Answers
You need to configure the power options.
Go to control panel and then click on power options.
Select advanced power options and there select the power mode as balanced or high performance.
Posted on Jul 21, 2010
My Acer Aspire A150 turns on but the screen is so dim you can barely see anything. the battery is full! please help!
sorry but if you have dim screen is because the lcd panel need to be replace , make sure the new panel comes with the ballast , the lcd has a lamp between the screen the life of the screen is over that way look like that
Feb 08, 2012 | Acer Aspire One A150-1006 Notebook
My laptop is a hp 6365 and it was working last night but then when I got home it would not turn on. When I plug it in the blue light on the charger lights up but no other lights(The lights the show that...
1. Unplug your computer and remove the battery.
2. Press the power button several times.
3. Reattach the battery, plug in the computer, and press the power button.
4. If the problem persists, look closely at the screen. If you can make out faint, dim images, the backlighting components must be replaced or repaired. If not, it is likely another issue with the physical hardware of the machine such as the screen or the motherboard.
Mar 05, 2011 | HP Hewlett Packard Pavilion dv6365us PC...
When i plug the charger in my Nokia N95, the white (screen is dim) startup screen with the word "Nokia" will appear, then after about 5 seconds the screen will go black and will not charge. This has...
you bought a fake battery or the battery terminal are bad and are having poor contact with the battery.remove the battery and try to clean the three golden panels that come in contact with the battery
Sep 23, 2010 | Nokia N95 Cellular Phone
Dim display on laptop LCD screen
The part you need is called a CCFL Backlight. Basically, there are lights in the screen that back-light/illuminate the display. Over time it burns out and you are left with a dim and completely dull display. These are a pain to replace and expensive when bought from the manufacturer. But this site has a break down with dis-assembly instructions...if you want to try it.
Mar 10, 2010 | HP OmniBook XE3 Notebook
My toshiba satallite p200-1ee laptop is not charging. Battry life left: 40% When on: The Charging light blinks 3 times every few seconds and the screen dims with it. When off (But pugged into mains): the...
If you plug the charger into the computer without the battery and the laptop runs fine, then I would suggest to you that your battery is failing and will no longer accept the charge. On the other hand if the laptop will not stay running or acts strage and the screen dims and gets bright, then I would suggest to you that the charger's built in voltage regulator is failing and will damage the laptop if it continued to be used. A bad charger will also permenently destroy the battery condition.
Dec 01, 2009 | Computers & Internet
Monitor is dim
Sounds like your inverter is failing. The inverter takes the dc power from the battery and charger and converts to high voltage AC current for the backlight lamp inside the screen. When the inverter starts to fail, the display will sometimes blink, dim out over time, flash just get dark and stay that way.
Sep 28, 2009 | Toshiba Satellite A215-S7422 Notebook
My laptop won't turn on
a copoment inside the laptop might be broken. go to where you bought it from and ask them for a new one or to repair it. this is only if it comes with a guarantee though. or just ditch it and buy a new one. never try to open or repair it yourself though the electral shock could kill you even when it is off.
May 08, 2009 | Acer Aspire 5500 5570-2609 Laptop
Won't start without charger on battery.
when you charge the battery make sure that its cable is is loosen from the motor coz it can damage your charging system. on your case you have damage it already that's your light dims whenever you rev the rpm up. so change your voltage regulator of your charging system, charge the battery and it is done easy.
Apr 25, 2009 | 2003 Harley Davidson XL 1200 C Sportster...
Lack of brightness on battery. OK on power supply.
there should be an Fn + one of the F keys function to make the screen brighter or dimmer.
Mar 18, 2009 | ASUS Eee 4G Notebook
Lgvx9400 screen turns black
I had the same problem. Went and bought a new battery.
Replaced it and let it charged without turning it off.
4 days now and I have not see the black screen yet.
Before it was happening almost everytime I wanted to use my phone.
At least once a hour I would have to shutdown and pull the battery.
Aug 30, 2008 | HTC S710 Smartphone
Acer Aspire 5100 Notebook Logo
211 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
