Question about Hotpoint HTS16HBR Top Freezer Refrigerator
Repairman removed the backing in freezer, exposing the coils, and also exposed what looked like paint that was peeling. He said that "painted" piece of refrigerator was flaking into the tube that was to drain defrosted water to pan in bottom of refrigerator and causing it to clog and leak into refrigerator. He said this part was not replaceable and that best solution was a new refrigerator. Refrigerator is only about 6 years old; is this the only solution?
  • Hotpoint Master
  • 43,501 Answers
Here is what is really happening and it is 100% repairable...
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
Water Running in Refrigerator from FreezerRepairman removed the backing in freezer, exposing - 2_bing.gif
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Jul 20, 2010
The bottom inside part of my Oster microwave is peeling up pretty bad where the plaste circle with wheels turn the glass. Don't use it much for this to happen....is it still safe and is there any recalls...
Using the microwave with exposed metal can cause additional problems. You can remove the loose paint, lightly sand the area and reprint with microwave cavity paint. The paint can be purchased from your local parts distributer, or find it online. Follow the instructions on the can.
Jul 21, 2014 | Microwave Ovens
A,S,D,Q,W,E keys not working.
You can repair any keyboard problems by taking it apart. Find the plastic mats with the exposed electrical contacts and look for food dirt, sugar syrups etc. Using a little water and a toothbrush clean and rinse the food covered areas and pat dry. Leave it to dry for an hour. Try putting it back together and see if it works. If not.... then take the offending letters and look for where the carbon paint touches those contacts and either repaint with carbon paint (available from a quality electronic supply) or just use crazy glue gel and glue little foil pieces to each carbon painted spot that is acting up. This works for remote controls too.
Oct 16, 2013 | Microsoft Arc Keyboard
Arcing issues again -- what's at fault?
It could be the mag tube, get warm soapy water and clean until spotless, now look for any exposed metal in the interior of the microwave oven, sometimes the enamel paint will peel off exposing unwanted metal, if everything checks okay you may end up having the same part replaced again.
Mar 26, 2012 | KitchenAid KCMS2055SSS Microwave Oven
The refrigerator in the house I am renting has paint pealing in the freezer. Can this dangerous or harmful?
If there is paint peeling off then it is advisable to have this cleaned and made sterile.
So try and use some good cleaning liquid and do not expose your food to the freezer but use containers or safe packing- freezer bags.
check this link for cleaning liquids:
http://www.espares.co.uk/parts/cleaning-products/fridge-cleaning/p/1424
Aug 04, 2011 | Kitchen Ranges
Where the coils inside are soldered together, we are seeing cracking or peeling. Should we be worried?
These are painted with a silver paint that falls off over time, this is normal and not harmful. It will work just fine and be okay. The next time you shut it off to defrost it, you can clean the peeling paint off.
Kelly
Mar 24, 2011 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Was cleaning inside of microwave and noticed the paint was bubbled and when I cleaned this area, all paint came off and metal was exposed 9about a 2 inch area). Should I use the microwave or will arching...
Hi Bonnie,
Do not use the microwave with the exposed metal surface.
What you can do is pick up some appliance touch up paint, it comes in a small plastic bottle with a brush. It looks similar to fingernail polish. It should be available at an appliance store such as Sears, Lowes, Home Depot etc.
Clean the area good and use sandpaper or steel wool if needed to make sure the area is smooth and clean. Then use the touch up paint to recoat the surface. Let dry before using the microwave oven, usually a couple hours or so.
May 01, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
Build in microwave started to sparkling during cook cycle
there is some exposed metal in the cooking chamber, look for scartched paint or exposed screws, paint them or place tape over them.
Aug 18, 2009 | Thermador Microwave Ovens
Paint off inside top of microwave exposing metal. Safe to use?
It would be dangerous to do so. Any exposed metal inside a microwave is source for sparks and is extremely hazardous. I would recommend getting the paint job done up, or even better, buy a newer model.
Nov 15, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Mircowave oven the paint is peeling off from the inside top of the microwave
all you can do is clean it out and spray paint it again. there should be no metal exposed inside the oven or arching will occur.
tnx 4 uisng fixya,
drcool
Oct 11, 2008 | Whirlpool Microwave Ovens
Hotpoint HTS16HBR Top Freezer Refrigerator Logo
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
