Question about HP PSC 1210 All-In-One InkJet Printer
Problem getting the printer to print with the correct alignment
HP 1210 Printer: I am trying to print on 5.5"x8.5" paper and it prints half off the paper to the right. Basically it seems to think that it is printing on regular letter size paper, although it is set to print on the correct size paper and the page set up is set correctly. What am I doing wrong?
  • karissa09308 Apr 22, 2008
    Somehow it just started working correctly. I am not even sure what I did....Thanks for replying!!!
  • Anonymous Apr 23, 2008
    Yes, I am trying to print 5.5 X 8.5 paper but it is not offered as a standard size by I type in the sizes as user defined, but it will not print in the center of the paper when fed at the extreme right of the tray. The print view shows it centered nicely
It was working well. All of sudden it shows problem with cartouche. But they are all right. What should I do? please suggest
Posted on Apr 22, 2008
  • 975 Answers
Is the printer connected to the your PC ?? ARE YOU PRINTING THIS SIZE directly from the PRINTER ?? AS soon as i get an answer from you , Ill tell you what to do next , thanks AJ
My hp 1200 printer tells me out of paper on windows 8
I think Paper try sensor not working properly. Check the sensor, is it on normal position?
Jul 30, 2014 | HP PSC 1210 All-In-One InkJet Printer
The printer won't print because it says it is out
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Nov 06, 2009 | HP PSC 1210 All-In-One InkJet Printer
Printer says out of paper. paper added still wont print
The solution to this is bizarre but worked for me.
In Vista press the windows key and R button. The Run window opens and in the run window type services.msc and then press Enter.
2. Locate Print spooler from the Services window which opened in the previous step.
3. Right click on it and select Restart.
Your printer will print a self-test page but then should be good to go.
Nov 22, 2008 | HP PSC 1210 All-In-One InkJet Printer
Poor print quality - top half page okay, bottom print faded and skips top half page okay, bottom print faded and skips problem Just installed a new cartridge
check the wright cartridge model you installed and well pluged to the printer
if it is ok
try to change printer properties and fix it correct options with there tabs ( ex: paper, print quality etc)
all are well try to reinstall the printer driver
Jul 16, 2008 | HP PSC 1210 All-In-One InkJet Printer
Hp psc 1210 all in one printer
go to printer and faxes and then right click on the printer icon and select use printer online.
check usb cable if it is properly plugged in.
download hp printing diagnostic utility at www.hp.com/support make sure you type it in the website search box
Jul 03, 2008 | HP PSC 1210 All-In-One InkJet Printer
Unresponsive printer
First off, I will try an uninstallation of the printer
Then reinstall all the drivers and software for the printer.
Jan 20, 2008 | HP PSC 1210 All-In-One InkJet Printer
Please follow the below given instructions to resolve the issue.
Please click on Start >> Programs >> HP >> HP Director.
Click on Settings >> Print Settings >> Printer Settings.
Click on Quality Tab at top of Printer Settings Window >> Set the Paper type as " Plain Paper " .
Click on Layout Tab at top of Printer Settings Window > Set the Paper size that you are using >> Click on Apply and then on OK.
Try Printing, that should resolve the issue that you are experiencing with.
If the issue still persists, try installing alternate drivers by following the below given instructions.
Installing the Alternate drivers:
1. Right click on My Computer, select Explore and then goto Control Panel, and then select Printer and Faxes.
2. Double-click the Add Printer icon. Click Next.
3. When prompted, choose Local, and then click Next.
4. In the Manufacturers list, choose HP.
5. In the Printer list, choose the HP Deskjet 870C printer, and then click Next.
6. Choose the port as parallel port, and then click Next.
7. The printer name should be listed as HP Deskjet 870C Printer.
8. Click No when the "Do you want your Windows based programs to use this printer as your default printer?" message appears. Then click Next.
9. Click No when the "Would you like to print a test page (recommended)" message appears. Then, click Finish.
Configure the alternate printer driver
1. Right-click the HP Deskjet 870C printer icon placed in the Printers window.
2. Select the Properties menu item.
3. Select the Details or Ports tab.
4. Select the DOT4_00x (where the "x" represents any digit) port from the Print to the Following Port list.
NOTE: The All-in-One model number should appear as part of the port destination.
5. Leave the printer identified as HP Deskjet 870C printer, and click the Apply button.
6. Close the Printer Properties window.
If Deskjet 870c is not listed, you may even try with Deskjet 990c or 550c
Hope that above information will work.
Regards,
Lawrence
Jan 05, 2008 | HP PSC 1210 All-In-One InkJet Printer
Printer wont print
Not sure but this printer may not be compatable with vista. OR.... you say it goes through the motions, does a page of paper come out? Did you try a different cartridge?
Aug 25, 2007 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 1210 All-In-One InkJet Printer Logo
96 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
