Question about Carrier 38BRC048 Air Conditioner
How do i chnage my themostat from a carrier to a hunter
  • Carrier Master
  • 43,501 Answers
Here is a tip that will help you with that...
Thermostat Problems - How to Change the Thermostat for Heating or Cooling
http://www.fixya.com/support/r3583603-thermostat_problems__how_to_change_the_t
heatman101
Posted on Jul 20, 2010
Hunter manual tc3700 tire machine
Sometimes the polished shaft the arm carriers ride on becomes dirty and/or dried out, which wont let the carriers lock into position. We usually spray them with brake clean as we work them up and down, then re-lubricate the shaft with WD-40.
Dec 06, 2013 | Sport & Outdoor - Others
I bought a Hunter 44155C programmable thermostat to replace my Carrier non-programmable one. The wiring on the carrier is: W- white wire O- no wire G- green wire R- red wire C- blue wire Y- yellow...
Hello,You need RH/RCjumper together=red wire...C=blue wire...G=green wire...Y=yellow wire...W=white wire...O/B unused for reversing valve for heat pump.Hope that helps. : )
Nov 10, 2010 | Hunter Heating & Cooling
Carrier 6 wire, installed programmable hunter ther...
Is this a heat pump? Look in the thermostat. You should have something like the following.
Red wire to R terminal
Green wire to G terminal
Yellow wire to Y terminal
White wire to W or W1
Blue or Orange wire to the O or B terminal
Brown wire to C terminal.
Let me know what you have in the thermostat. The wire colors are not always the same.
May 21, 2010 | Carrier 38BRC048 Air Conditioner
HAD Carrier Digital unit, did not like, purchased Hunter, which I could not get to work Now I have extra colored wires hanging from the wall that came off the carrier that I did not tag.
Put the carrier unit back on the wall and connect the colored wires to the designated terminals.
R-Red, G-green(fan), Y- yellow and so on until they are all reconnected.
Manufacturers controls are designed to operate their units and sometime have more control options that require the extra wire you experienced with the off brand unit you purchased. Take it back and get the instruction manual out for the Carrier unit and learn to like it. If you have aZone System it is the only cotrol that will work with your system.
Oct 23, 2009 | Heating & Cooling
OUR 1957 STUDEBAKER OVERHEATS. IT OVER HEATS
Are u sure it is overheating--the headlites should have nothing to do with the temp. Check ur temp sending unit--Did u change the themostat??--If it is overheating that is probably ur problem.
Aug 17, 2009 | Avanti Studebaker Cars & Trucks
New thermostat not starting compressor
With the jumper inplace does the compressor start? What about without? Unless you have more than one transformer you should leavethe jumper.
Dec 06, 2008 | Heating & Cooling
Location of reset button on model 44110
There is a little reset button right under DAY/TIME. You will need a pencil/pen tip to press this little switch in to reset your unit.
Hope this helps.
Good luck.
Mac =)
Feb 09, 2008 | Hunter Fan Company 5/1/1 Programmable...
Carrier 38BRC048 Air Conditioner Logo
74 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
