It will only come on and after a couple seconds it will pause and go blank.
Charge the Walkman fully. To charge the battery of the Walkman fully keep it plugged in to the Computer for 4 hours.
Reset the Walkman by pressing the RESET button that is located at the bottom.
You can use any sharp pointed object to press the reset button.
If the issue still persists, then you may format the Walkman only using the FORMAT option in it.
Then transfer the audio files to the Walkman and check whether it works.
Make sure that you transfer the audio files that are supported by the Walkman.
