Question about Frigidaire 22.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White
My kitchenaid side by side refrigerator model ksra251 has a ice maker...it is not making ice at all, there is a "ice maker control" panel on the inside that has a red lite that is blinking. What does this mean? There is absolutely nothing in the manual on it at all.
SOURCE: Frigidaire frs24zrh refrigerator not cool enough
Check out partselect.com. need to replace defrost timer and defrost thermostat. good luck.
Posted on Sep 26, 2008
  • 85 Answers
SOURCE: Ice maker makes ice, but won't dispense.
if you hear a click when the actuator is depressed the swt is ok remove ice bin and try rotating auger mtr by hand if you can't the auger motor is frozen, you can remove the whole auger asm and let it thaw out and dry out for a few days
Posted on Dec 14, 2008
SOURCE: ice maker not making ice
my ice maker is not making ice what could be the problem, and there is not any water in the ice machine what do i need to look for
Posted on Jan 11, 2009
SOURCE: My Frigidaire refrigerator (FRS20WNF)does not make ice anymore.
did you check your copper line in the back
Posted on Jan 14, 2009
SOURCE: Frigidaire side-by-side model # FRS26H5ASB4 making humming or buzzing noise
I had the same problem. I found the buzzing noise was caused by ice build up around the fan motor inside the freezer. I believe water must have leaked down around the fan during a defrost cycle. I removed the ice maker, the ice cube bin and ice dispenser auger motor. It sounds complicated, but it isn't too bad. The ice maker and auger are connected with quick connect plugs. So just unplug, remove the screws and remove them from the freezer. You will need to remove several other screws as well, I believe 11 in total as well as the top freezer rack. This will give you access to the white aluminum panel that runs from the top of the freezer to about halfway down the back of the freezer. After you remove the aluminum panel you will see the fan about half way down the freezer. I found a lot of ice around my fan. The fan blades were hitting the ice causing the buzz. Remove the ice and the buzzing is gone. It took me an hour to complete this repair. I hope this helps.
Posted on Feb 05, 2009
Kitchenaid superba ice maker not making ice
Put some water in the tray. Let it freeze and once frozen will the ice then empty into the ice bin? If yes then the problem is possibly one side of the water control valve is defective. This is not the correct water control valve for your model number. HERE You need to provide the correct model number first.
What is the model number? I am here should you need me, Thanks John Tripp Appliance 911
Apr 21, 2014 | KitchenAid Refrigerators
There is ice in the ice tray but will not dump
da7a4823-cd31-448f-bac2-11ff8c3d6b4e.jpgCan you confirm your refrigerators model number? If youre model is the KSCS25INSS there can be two possibilites. The Electronic Ice Level Control Board or the ice maker itself=> 2198597 Ice Maker Assembly Instructions on how to diagnose the ice maker and the Ice Maker Level Control can be found HERE I am here if you have questions, Thanks Sea Breeze
Oct 04, 2013 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid 25in KSRJ25CNST00 icemaker trouble. The LED light on side of freezer is blinking twice with a delay and repeats same sequence. No ice is making. Any suggestions on what to look for?
Try the reset button on the control panel. If that doesn't work, then try unpluging the refrigerator.
Also, make sure that ice tray shut off arm isn't in the up position. It should be in the unlock position one notch below the off position. This arm is used by the refrigerator from over filling the ice cube holding tray. Once the ice fills the tray. The ice in the bend will push up on the arm which
initiate the ice maker to stop making ice. As soon as you start using the ice in the bend and the arm falls below the off position. The ice maker will start making ice. GB....stewbison
Sep 04, 2011 | KitchenAid Superba Architect KSCS25INSS...
I have a KitchenAid SxS model # KSRG25FTST01 with an icemaker problem. It stopped making ice, but the water still dispenses. It makes no noise and no water in the ice tray. I never hear it try to fill with...
If the thermostat behind the left side of the fill tray goes bad, the cycle will stop completely. Cost of thermostat is $20.00. Cost of new icemaker with new motor and everything including thermostat is $45.00, brand new, on EBay plus shipping. Cost for new icemaker from repair shop, $153.00 plus tax. Control board circuit panels each side of freezer compartment will go bad also stopping the ice maker cycle. these control boards come in pairs, one for each side of freezer compartment. Cost for new circuit panel control board from repair shop, $215.00. Cost from EBay brand new circuit control board $45.00 plus $8.00 shipping. Easy to install both, icemaker and control board circuit panels. Phillips screw driver and small socket set is all you need for removing and installing these items.
Jan 22, 2011 | KitchenAid KSRS25IL Side by Side...
My kitchen aid refrigerator model KSB251NBL..NO ICE
Problem could be a couple of things.One There is a little control in the very back,its should be on the lower right side looking at the freg. from the back.It has a water line running up to the ice maker.If that is ok,you will need to replace the ice maker.It is not a big problem on either.Cost is for the little controll about $30.For the ice maker about &90.
Aug 29, 2009 | KitchenAid Refrigerators
KitchenAid Superba refrigerator, no ice.
this fridge uses a infrared controlled ice maker on the freezer top right side you will find a white lid whit three screws the ice maker control board replace it and if don?t solve your problem emplace the ice maker to.
Jun 07, 2009 | KitchenAid KSRK25IL Side by Side...
Ice maker not makeing ice
The most possible 2 reasons for this is the water control valve part number 4389177 or the thermostat inside the ice maker is not working. If ice maker is empty pour tap water until full and lower arm to see if the ice freezes and drops. If this works I would replace the water control valve. Below is a link enter your model number or the part number in the model search feature. There you will see your refrigerator. Thanks Sea Breeze
http://servicepartstec.blogspot.com/
model number KSRS27ILSS02
May 29, 2009 | KitchenAid KSRS27ILSS Side by Side...
Kitchen Aid Ice maker Stopped working
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
Aug 02, 2007 | KitchenAid KSCS25FKSS Side by Side...
Frigidaire 22.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White Logo
164 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
