Question about Kitchen Ranges
My clock and timer no longer lights up or works on my frigidare stove
    Scholar:
  • 150 Answers
Check for voltage to the board also check the neutral from the board if okay you have a bad board very common with the frigidaire I have replaced many they are sensitive to power surges
Posted on Apr 22, 2008
Oven and digital display clock and timer doesnt work but burners and oven light works
Clock & Main control display issues - YouTube
? 4:44
https://www.youtube.com/watch?v=OmOocInxHOo
Jun 28, 2013 - Uploaded by ApplianceVideo.com
... symptoms: Clock and display does not work At: http://www.appliancevideo.com For ... and show you how to ...
Range/Stove/Oven Repair - Replacing the Clock Timer ...
? 3:42
https://www.youtube.com/watch?v=0RSnf4wfSZM
Oct 20, 2011 - Uploaded by PartSelect
Range/Stove/Oven Repair - Replacing the Clock Timer (Frigidaire Part .... My timer still works fine, but ...
Y0315570 Amana Range/Stove/Oven - Appliance Timer
Dec 01, 2015 | Kitchen Ranges
The digital clock/timer on my stove has basically quit working. The timer keeps setting to 59 minutes and beeping all day and all night and I cannot set it back to clock after the buzzer goes off. How do...
Your membrane keypad is shorted.
Whether it's available as a separate part, assembly, or if you have to order a whole controller is determined by the model number, which you did not mention.
You can find handy exploded views and order parts by model number here.
May 25, 2011 | Microwave Ovens
My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Apr 30, 2009 | GE Profile JTP18 Electric Single Oven
FRigidare new stove installation
Loud pop means electrical fault occured. There may be and internal fuse in the oven that blew. Probably blown oven element but certainly open circuit to timer. Remove back, check for supply to oven timer. If supply is there, the timer can be bypassed to allow for oven element to work as clock replacements are very expensive.
Nov 09, 2008 | Frigidaire FEF355 Electric Kitchen Range
My clock and timer on my Frididare stove no longer lights up or works
Dear Realtor,
If 120V is reaching the clock than the problem is caused by the clock.We repair mechanical and electronic clocks,timers and controls for major appliances.
Regards,
Howard Simons
http://www.appliancetimers.com
Apr 22, 2008 | Kitchen Ranges
AMANA STOVE
you have an electric problem that it can be from lightening or replace the clock. so u must be sure that gas valve working mostly it must be 24 volt . if u haven't electricity on gas valve check the high limit switch if there is a combination u must change valve
Mar 10, 2008 | Amana RanARG7302 Gas Kitchen Range
Caloric gas stove prestige series
to jenna 12 Does your stove have a stop and start timer? When you set your clock you may have inadvertantly moved the stop or start time on that timer. Check them, if they have knobs for setting the stop and start time, make sure the pointer is pointing to the current time and that the knob is popped out and not stuck in. when you have it right both the stop and the start knob should be out, not pushed in. They will pop out when you turn them to the current time.
These timers allow you to start something cookin at a time delayed several hours. this means they will not allow the oven to come on until it hits that time that you may have set in error.
If your stove has a digital stop and start timer check each one so that both show the current time, then your oven should light.
Oct 13, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
87 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
