Question about Electronics - Others
I have a medion 1tb external hard drive with 2.0 usb,i cant connect it to the tv,as the tv has only hdmi ports on the back of it,how can i resolve that problem
  • 75 Answers
You can buy usb to hdmi cable
check the following link
http://sewelldirect.com/articles/USB-to-HDMI.aspx
Posted on Jul 21, 2010
I have a western digital My Passport 1TB USB portable drive and my Panasonic TX-P42G20B does not recognise it
Hello
The only way to connect an external hard drive to your TV is first connect your laptop to TV then use an external hard drive from usb port on your laptop. If you have no laptop then you will have to get a media player box to put your drive into if you do this your drive must be formatted with fat 32.
Thank You
Sep 05, 2011 | Panasonic Televison & Video
I have a WD MyBook Essential 1TB external hard drive installed with my Mac OSX 10.5.8. The drive is only being used for Time Machine and my iTunes backup. The drive will randomly unmount itself and I get...
I would suspect that either the USB cable or port is the problem. Change the USB port (On the Mac or on the WD MyBook (I don't know if it has more than one USB port) that the cable is connected to and see if that improves the situation, if it still happens change the USB cable. Hope this helps.
Mar 22, 2011 | Western Digital My Book Essential 1TB...
How to make WD MyBook essential 1Tb work on sony bravia EX300 LCD TV ? I tried to connect the external hard drive on my sony dvd player and it appears on the tv screen that the USB device is not...
this will not work by it self you will either need to buy a computer with media software that will support your hard drive or a DVR that will support you hard drive.
the hard drive connected to the device you have tried to connect to are not smart devices they will not support a stand alone external drive even though there is a usb port.
Mar 17, 2011 | Western Digital My Book Essential 1TB...
My western digital 1tb hard drive is freezing my computer and its not showing up as being connected to my computer
IT is a clear indication that the data transfer from the External hard drive is not compatible with the processor and can be resolved by changing the usb cable.
Jan 21, 2011 | Western Digital My Book Essential 1TB...
Can external hard drives be "piggy backed"? I have
Each external device connects to one USB port on your computer.
So, you'll have no problems running two devices at the same time, in different USB ports.
Dec 13, 2010 | Seagate FreeAgent Pro 1TB External USB...
It wont show up
Have you tried alternate usb cables and usb ports on your system? have you tried a different system? If that doesn't resolve the issue- you have a dead external drive- if swapping the cables works, you have a dead cable. If swapping the port that you are connecting to- it could be the port is bad, or the port is a low power port. If swapping to a second system works- and none of the ports on the other system works- then the system will need service- either for reinstalling windows, or a replacement motherboard since the USB has failed.
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Oct 03, 2010 | Western Digital My Book Essential 1TB...
When i connect my wd 1tb hard drive i get usb device not recognised plz help
Hi sexybarneygu, Assuming you have tried other USB ports getting the same problem, I recommend you return it (if it's under warranty) if not, remove the Hard Drvie from the casing and connect it to another computer internally (I dont want you to get another external case for you Hard drive because you hard drive MIGHT be the one with the problem and you cant fix it (you can't fix hard drives, just work around it in order to get your data back and then trow it away). If the other computer sees your hard drive ok, then go buy an external case and install your hard drive there. make sure it's the same interface - most likely SATA interface. I'm 80% sure it's just the casing not the hard drive. Don't forget to rate if my answer helped you. Thank you :D
Apr 28, 2010 | Western Digital My Book Essential 1TB...
Hello, I plugged in my iomega 1tb desktop hard drive storage device and the drive does not appear in my drive or computer. I do have the new hardware 'sound' that comes up but I dont have the drive show up...
Iomega 1TB Desktop Hard Drive is a dedicated usb 2.0 plug and play external storage device that has an ability to transfer at 480Mbits/second. having these large capacity storage drive needs a fast connection and additional power source to make sure to run the external unit system properly.
just make sure both power and data cables are properly plugged and connected respectively. if you are using it with a desktop, please always plug your usb connection from the Iomega 1TB external drive to the rear USB port in line where you built-in LAN is.do not plug it in the frontload ports. some motherboard manufacturers uses usb 1 and/or 1.1 only for frontload desktop casing provision.
thank you.
Dec 30, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Electronics - Others Logo
465 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
