Question about Pioneer DEH-14 CD Player
Help!! how do i hook my amp and subwoofer??please!
  • 975 Answers
Need more information , this is an amp for the subwoofer only? and want to connected to the rest of the car audio ??
Posted on Apr 22, 2008
Jvc KW-AV50 subwoofer amp hook up
very good ! there is nothig wrong with your system, buy a stereo to mono RCA jack (Rs10/-) and connect the subwoofer (if single coiled) L+ & R-- of your existing amplifier. NB: Please go through the manual of amplifier
Apr 08, 2012 | Car Audio & Video
I have 2 12s kicker comps 2ohm. One of them are working fine, the other one, when I hook up to amp, it throws them both off and just does this repetitive bass....or when I just hook the one thats...
Measure the resistance across the voice terminal of the known good sub, and then compare that to that of the problem sub. You may see a greatly changed value, which likely means the voice coil is damaged. Don't connect the subwoofer again because you risk damaging your amp as well.
Nov 16, 2017 | Kicker CVR152 CompVR 15 2/4 ohm 1000W...
Can i wire one speaker to the other speaker inside the box so that i only have one positive and one negative cable wire coming out out of the box and to the amp
Hello... I can help you with this question. Yes it is possible to do this, but you will have to use a 2 ohm stable mono block amplifier in order to do this. By connecting both positives together and both negatives together, you will be running a 2 ohm load. So if your amp is a monoblock amp, connections will be simple as tieing all the positives together and the negatives together and just hook to the amp. If you are using a 2 channel amplifier that is bridgeable, then you will need to series the subwoofers to an 8 ohm load and then bridge the amplifier to 1 channel. The way you series the subwoofers is take the positive wire in the box and hook to the positive on subwoofer #1. Take the negative wire in the box and hook to the negative on subwoofer #2. Then take a piece of wire and hook the negative from subwoofer #1 to the positive connector on subwoofer #2. Then hook the wires to the amplifier. To bridge the amplifier (if it is a 2 channel bridgeable) would be to use the left positive and the right negative, but check the amplifier for markings to confirm this. If you have any other questions, feel free to let me know and I will help you out! Hope this helps!!
20 year car audio/video installer
Bay manager
Mar 22, 2011 | Kicker 05C104 Car Subwoofer
Can u connect another subwoofer to this sub? if so how?
Yes, you can connect another subwoofer too along with this unit, hook RCA pin in this subwoofer coming from amplifier sub out and there is RA jack line-out, anothersubwoofer can be plugged there. It is mentioned in user manual page-7 and previous expert gave you user manual link to download a copy.
Thanks.
Aug 26, 2010 | Sony SA-W305 Subwoofer
Subwoofer/speakers are hooked up to my amp but making bad noise
it sounds like you have some wires crossed or a bad ground
Hope this helps
Jan 25, 2009 | Kicker CVR12 Car Subwoofer
New (old) house with stuff installed when we got it
IF YOU HAVE THE SAME AMOUNT OF CABLES AS SPEAKERS HOOK THESE UP TO YOUR AMP THEN SUB TO SUB OUT PUT ON YOUR AMP WITH A SUB CABLE OR PHONO THAT REACHES FROM AMP TO SUB.SET AMP TO ALL CHANNEL STEREO OR MODE THAT SENDS STEREO TO ALL SPEAKERS,ALSO SET SPEAKER SIZE IN SETUP OF AMP TO SMALL AND SUB OUT PUT TO SUB ONLY.YOU SHOULD GET MUSIC AROUND THE HOUSE.IF SOUND IN SAY BEDROOM IS NOT AS LOUD AS BATHROOM USE THE TEST TONE TO LEVEL OUT EACH SPEAKER.
HOPE THIS HELPS.
CABLE GUY.
Jun 26, 2008 | Audio Players & Recorders
Subwoofers not bumpin, amp is still on
Check to make sure there is a good input to the amp. Next check each sub to another source to make sure they are good. Look for any reset on the amp.
Apr 26, 2008 | Kicker CVR12 Car Subwoofer
My subwoofer doesnt work
you mean that the SUBWOOFERS connected to the amp cuts off and come back on randomly?? did you bring the SUBS level to a high volume ? i suggest to check first the value of the speaker (ex. 4 , 8 , 16 ohms ) matches the same value with the amp . second , hows the subs connected , in series ? or parallel . you will need a multimeter for this task .
Apr 22, 2008 | MTX Thunder 8000 T8154A Car Subwoofer
Subwoofer Optimus
I added the subwoofer wires to the right and left front speakers.
Apr 01, 2008 | Onkyo TX-SR601 Receiver
Pioneer DEH-14 CD Player Logo
82 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
