Question about Kenmore 24 in. 16034 Built-in Dishwasher
Clean button flashing, will not let me do anything else
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 13, 2010
Remote pauses and flashes before i can press any other button quick enough
open the remote control and clean very well the keypads from dust, corrosion, etc. Resolder any colder joint from the board. Clean the contacts batteries very well.
May 30, 2013 | Televison & Video
The CLEAN light is flashing on my Kenmore QuietGuard3 , but it won't clean anything. It starts a cycle for a few minutes, stops and starts flashing clean again. Any suggestions?
You will have to reset the dishwasher. First try and turn off the mains power and back on after a short time. If the clean light flashing starts again then you go through the hard reset procedure.
press NORMAL WASH then HEATED DRY buttons one after the other until all the lights on the board lit up (3X's). The dishwasher will enter into a cycle; Press Cancel. This should stop the flashing.
If you are supplying dishwasher from hot water inlet then make sure the inlet water temperature stays within the recommended range of 145 deg F.
Apr 21, 2013 | Dishwashers
I have a new ES-LA93 razor which I love but I have one question. After shaving I press the [SELECT] button to choose Clean/Dry/Charge. The process finishes and all seems fine but the CLEAN and DRY course...
If you clean the razor every day, the CLEAN and DRY lights flash repeatedly to show you that the cleaning has completed. You should be able to confirm that this is correct by NOT cleaning it one day. You should see that those lights don't flash then. I know this because I clean the razor twice a week rather than every day. On the days that I clean it, the lights flash. On the days that I don't clean it, the lights don't flash.
Nov 08, 2010 | Panasonic Health & Beauty
When I try to take a picture the camera tries 2 or 3 times then I get a err05. (built in flash auto pop-up was iobtructed.) But I can't find anything obstructing it
Alot of times there is residue that has got stuck in between the flash cover and top cover. Turn the camera on and with your nail pry open the flash as you push the flash pop up button with your other hand! Then with alcohol and a couple of q-tips clean every part under the flash pop up. When the camera is facing you there is a arm that rests slightly forward on the left side clean there and on the right side in the back there is a piece of plastic sticking out of the cover. Its black in color clean that with alcohol depress it a few times with the q-tip soaked in alcohol and the arms that push up the flash are silver, clean those real good. Alot of times when a camera is sent in for this it is usually a result of residue of some sort getting in between the flash pop up and the top cover! Even if it looks clean, clean it anyways. Also sometimes the flash pop up is slightly bent you can bend it in place with your hand. Just a little a a time and then try to depress the flash pop up button and see if it works.
Jun 18, 2010 | Canon Rebel XT / EOS 350D Digital Camera
The "clean" button is flashing & none of the other cycles work.
heated dry and high temp wash
toggle till all the lights light up
then hit cancel
you should be able to turn dishwasher back on
you probably have a bad heater
is it flashing 7 times
take kick panel off and look to the rear of the dishwasher
is anything burned
if the clean light keeps blinking replace your heater
Feb 09, 2010 | Dishwashers
All 3 Error lights are flashing (4 if you count the GO button)!!
When all lights flash it's a service problem. You press and hold the go button and see what lights are on then.error light means main PCB failure, Toner light means fuser failure, drum light means laser failure. Toner and error light means main motor error, drum plus error light means its a fan failure.
Jun 26, 2009 | Brother HL-2170W Laser Printer
''clean'' light flashing (whirlpool Dishwasher GU2300XTLS1 model)
I had the same problem recently and a repair person came to my home to fix the dishwasher. He said he had to reset the control panel. He did this simply by making sure the soap dispenser door inside the washer was closed, then making sure the main dishwasher door was closed and locked. Then he quickly pushed the Heated Dry button and the Hight Temp wash button alternately. He said each button needed to be pushed twice within five seconds. After he did this all the lights on the control panel came on, then turned themselves off before the washer went in to a test cycle. This simple reset fixed the whole problem. Works great so far.
Mar 26, 2009 | Dishwashers
Red & Green Lights keep flashing on Epson Stylus Photo1280
I had the same problem. You need to reset the waste ink counter:
1. Turn printer off, unplug power cord. Disconnect computor interface cable (back of the printer).
2. After one minute, reattach power cord, but not the computor interface cable.
3 Hold down the LOAD/EJECT and CLEANING buttons simultaneously (cleaning button has ink drop on it) .
4 Turn printer on. Release all buttons as soon as the paper out light flashes.
5 Quickly press the cleaning button, and hold for 10 sec while paper out light flashes.
6 Release the button and the printer will initialize.
7. Once the initialization is complete, turn the printer off.
8. Reconnect the interface cable.
9. Turn the printer on and try to print your document.
This process worked for me. Good luck!
Feb 01, 2009 | Epson Stylus Photo 1280 InkJet Printer
Filter light keeps flashing
The light flashes after a certain amount of run time. It is a reminder to check the filter to see if it needs cleaning. Once you have checked/cleaned the filter and reinstalled it, press the filter button for 5 seconds and the light should go out.
Jun 18, 2007 | Whirlpool ACQ158XP Wall/Window Air...
Kenmore 24 in. 16034 Built-in Dishwasher Logo
77 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
