Question about Xante ScreenWriter (Refurbished) Laser Printer
What do I need to install the xante on my windows XP computer
Drivers and all of that? The new PC will not read the installation disk. I down loaded drivers but what next?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 98 Answers
Install the drivers.
Posted on Jul 21, 2010
How do i load windows xp on hp nx8220 it goes to microsoft then back to start windows normally then repeats is there a solution thankx
the reason why is because ,hp computers use a different set of video drivers than does win/microsoft, when upgrading to xp you must install xp 1st release no svc pacs, then must have the hp video drivers oem for the model you are installing xp to , they can be downloaded on hp driver download, or the intel driver download site, unless you have a different chip set, the oem drivers must also be puton either a floppy disk or cd , that is made bootable from restart, make shure either the A drive or the C drive is set to boot before the hard drive so it will pick up the bootable disk you made with the downloaded drivers , then reboot the computer with the xp disk , at the disk partion screen select leave old files intact with the new install !
Jan 22, 2013 | HP Compaq nx8220 Notebook
I get a disk read erroroccurred after I have installed a new hard disk. How can I get my computer going again?
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Aug 15, 2012 | HP Compaq nx6325 Notebook
New hard drive operating system not found
The reason why you cannot install Windows on your hard drive is this model Sony has a SATA disk controller.
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Feb 17, 2012 | Sony VAIO VPCEA36FX PC Notebook
Will windows xp supported in amd sempron 145?
No it should not.
However your post does have one confusing detail - XP when installed does not reside on the motherboard but on a Hard Disk Drive. Parts of it will be loaded into memory when you boot up the PC.
If you mean that you are also installing a new Gigabyte MB under an existing installation of XP, you will probably still need the XP system disk for a reinstall of XP as it may not recognise the new MB.
If you are newly installing XP in an existing PC with the specs you mention, it should be ideal. It is best to have enough memory on board, at least 1 Gb.
Nov 20, 2011 | AMD Sempron 145, 2.8 GHz
Install windows XP
You sure your HD isn't bad? You could try a low-level format and then try to install, I am assuming you don't mind loosing any data already on the disk.
Sep 09, 2009 | Computers & Internet
Set up did not find any hard disk drivers installed on computer
Your notebook has SATA hdd. Got into the bios (keep pressing F2 key on startup) then in the bios screen find HDD and press enter. Select IDE mode. Press f10 to save changes and exit. When this is done install XP.
Alternatively connect external usb floppy drive and unzip sata drivers into that. When booting from xp cd press f6 to load drivers.Follow onscreen instructions to load drivers and continue xp installation.
Please let me know if issue not solved for futher ts steps.
thanx
May 28, 2009 | Fujitsu LIFEBOOK P1510D Tablet PC
When installing a new hard drive the system bios recognize the drive. However, when I start to install Windows XP, the program does not see the drive as being present. How can I get the computer started...
What type of hard drive is it. Sound like you put in a SATA hard drive. You need to load the drivers for that hard drive. During the Windows XP setup it gives you an option to load 3rd party drivers that what is sounds like you need to to.
Mar 05, 2009 | Dell Dimension 8400 PC Desktop
I put a used e210882 socket 478 motherboard into my computer. which is a emachine. when i start booting the computer ask me what file to download windows xp into. what file should i send it to.
It is probably asking you to insert an XP disk, as Windows XP will need to install the new drivers for your new motherboard.  It will also give you the option to select a folder (this is what you are seeing) already on your hard drive that would contain the proper drivers for that motherboard.  Chances are this folder does not contain the proper drivers.  You will need an XP disk to install these drivers.  Boot with the XP disk in, and chances are Windows will take care of everything else.  If you do not have the XP disk you used to originally install Windows on that machine, then you can use a seperate PC to get the drivers required.  You will need to visit the website of the manufacturer (I believe emachines is your new mobo?) and download the drivers.  Then save them to disk.  When booting into your new system, make sure this new disk (you made from other pc) is in the drive, and then select that drive when it asks you for the folder you are talking about.  This will then install the proper drivers and you will be up and running shortly.  Hope this helps :)
Dec 31, 2008 | Dell (E210882) Motherboard
Problem with new install xp
First of all, was there a reason that you wanted to reinstall windows? If you were having problems with the operating system and now upon reload the hard disk is not appearing it could mean that the disk or the system board itself is bad.
If you pull the XP disk out and just try to boot your computer up are you able to login and use your computer from the previous/original install of XP?
If so, then perhaps you're using a special hard drive controller that supports RAID. If you have a RAID controller you'll need to load the drivers of that controller on a Floppy disk. During the initial startup of the XP install it will give you the opportunity to click the F6 button on the keyboard to load additional device drivers. You want to click F6 when it prompts you at the bottom of the screen and wait for it to prompt you to put your floppy disk (with the RAID controller drivers) in the floppy drive.
Hope this helps. If you need more help just let me know.
MO
Jul 13, 2008 | HP Compaq Presario v3000z Notebook
Win 98 does not permit flash disk
sir u have to install drivers of flash drive  in win98 (the cd which u got with flash drive )coz xp is plug&play so their is no need to install drivers in xp try it good luck
Oct 22, 2007 | Microsoft Windows 98 for PC
Xante ScreenWriter (Refurbished) Laser Printer Logo
111 people viewed this question
Top Xante Office Equipment & Supplies Experts
Marvin
Marvin
Jose Pino
Dudeman321
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
