Question about Maytag 7.0 Cu. Ft. Electric Dryer
Chemical like smell while clothes are drying
Dryer is making bad chemical smell
    Problem Solver:
  • 17 Answers
If you have recently painted or varnished something then just air out the house. The fumes can react w/ the heat of the dryer to create this smell. It smells different than the actual fumes, but still like some sort of solvent.
Posted on Aug 15, 2010
Clothes come out of my gas dryer with a slight chemical smell
In my years of experience, the only situation like this resulted when painting had been done within the last 12 months. The flame burns off the VOCs. Beyond that, it's a stumper.
Apr 20, 2014 | Maytag MDG2706A Gas Dryer
My Kenmore 80 series dryer seems to operate normally, except for a horrible "burnt chemical" smell in the dryed clothes. It almost smells like the gas is not exhausting correctly. Could it be the...
A lot of time a chemical smell is the result of blown capacity where the electrolitic is leaking out. Large caps are used in the moter start circuit and are usually located close to the motor. After awhile there will be an impact on the motor starting and the performance of your machine.
If it is the belt slipping you would get a burnt oil smell. If it was the blower motor or the drive motor it would be more of an electrical smell - burnt plastic type.
Jun 21, 2011 | Dryers
Burning chemical smell coming from the gas dryer
You first thought was probably the correct one...the fumes from the new paint may take a few days to disspate enough not to react with the heat of the dryer...I would give it a few dyas to clear before looking any further...
heatman101
May 28, 2010 | Kenmore Elite HE4 Electric Dryer
The dryer puts off a chemical smell on the clothes-gas dryer
If it smells like gas on your clothes, your exhaust vent is probably being restricted, causing the exhaust to back up into the dryer cavity. Remove exhaust hose, make sure it is clear all the way to where it exits your home.( sometimes birds build nests in the outlet vent) Look into vent where hose attatches to dryer, and make sure it is clear also. If you smell gas when moving the dryer, there should be a shutoff valve near the wall, close it. DO NOT THE DRYER ! ! Call someone qualified to make the repair.
Feb 08, 2010 | Maytag Dryers
Chemicals left behind in washer
i honestly would check with the manufacture of the chemical, with out knowing whats in it how do you know how to clean it?
Dec 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Glasses Smell after Washing
if you are using the heater to dry them .. have you ever washed anything plastic that may have melted onto the heater element? You might try flushing the dishwasher with white vinegar and then run a set of glasses in the energy efficient mode ( no heater to dry them)..just air dried.. See if any of these ideas rid the chemical smell you have observed... Hope this helps///
Aug 29, 2008 | Bosch 24 in. SHE43C05UC Stainless Steel...
Ice and Refrigerator and Freezer smell like alcohol chemical
I believe that you might have a coolant leak causing the chemical odor. You really should get it checked out by a fridge repair-person because it's not healthy to breathe in the fumes.
May 21, 2008 | Hotpoint HSS25GFP Side by Side...
FUEL LIKE ORDER COMING FROM ELECTRIC DRYER POWERE BY FUSES
Have you recently painted anywhere in your home. And I mean anywhere? Paint fumes or other chemical type cleaners or solvents will get in the elements and put off that whole gas or oil smell. If no, have you put any type of clothes in the dryer that may have had some paint or anything else petroleum based on them to dry. That also could have caused this smell as well. If your hot water heater runs on propane or natural gas, check it careful for leaks. This could be a serious situation as a major explosion could happen if it is leaking. Leave the house and call 911 immediatly from a safe distance. I doubt that this is the problem, but be safe than sorry. Let me know if none of these are the culprits. Thanks and let me know.
Feb 22, 2008 | Whirlpool LER5636P Electric Dryer
ELECTRIC DRYER SMELL LIKE GAS
I would imagine that you are saying you have an electric dryer, but it smells like it has a gas leak correct? Let me ask one question, have you used any kind of paints or chemicals in your house lately? If you have painted anything (in any room as well), the fumes of that paint (or other chemical) will get into the elements, and produce that smell for sure. I have actually had customers give me the clothes they dried to smell them, and sure enough, it will get in the clothes for sure. If this isnt the case, be sure that you dont have a gas line behind the dryer that may be leaking, or if your hot water heater or furnace is gas, you dont have a leak there. If you do have gas coming into your home, and you havent painted, etc, call your gas or propane service provider IMMEDIATLY from another home or location and let them come out to be sure you dont have a hidden leak. Good Luck!!!!!
Jan 31, 2008 | Dryers
Maytag 7.0 Cu. Ft. Electric Dryer Logo
451 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
