Question about Makita 1,100 Watt 2.5 Hp Portable Power Generator #G1100
TYPE OF OIL USED FOR A MAKITA GENERATOR G1100
    Novelist:
  • 145 Answers
10W-30 is what the factory specs call for.
Posted on Jul 21, 2010
What does a diode stack assmelly do on my
makita g5501r parts Power Generators Questions & Answers
www.fixya.com > Forum > Tags > makita g5501r parts
Power Generators makita g5501r parts questions and answers. ... I own a makita 6100generator and it is only putting out about 105 volts ac and about 208 volts .
Nov 18, 2015 | Makita Electrical Supplies
Leaking gas overflow
The float is probably stuck, or there is debris in the needle valve seat. may be time to rebuild the carbureator.
Jul 18, 2014 | Makita 1,100 Watt 2.5 Hp Portable Power...
What type of oil
http://www.homedepot.com/p/Makita-Hammer-Bit-Grease-194683-7/205182387
For outside chisels
Inside its depend on the model but most time its a Makita 181490-7 or for the older types Hammer grease Makita P-08361
Feb 19, 2014 | Makita Hammering
What tipe of oil makita generator g1100 takes
Great generator, i use 15/40 Quaker State it seems to work well for my uses, i have same one, but is 2000. check your manual if your really concerned, the whole thing, is keep oil fuel, and changed often. Hope this helps mike
Jun 13, 2011 | Makita G1100 1100W Generator
What will a 2.5 hp engine run please?
It's a 1100 watt gen, so you have 1100 watts available to use. All electriccal equipment is rated it volts and watts. Just do the math...
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 18, 2009 | Makita 1,100 Watt 2.5 Hp Portable Power...
Makita G11oo portable generator. starts on choke. cuts off run
Just noticed your question... If you still need a little help:
1. If the gas is from last year, drain the tank and the carb bowl and replace gas with new. Visually inspect the inside of the tank ..be sure there's no sediment that needs to be cleaned out.
2. remove air cleaner and make sure it's not plugged or dirty
3. plug the spark plug and clean with spray carb cleaner.
4. At end of season, mix some gas stablizer in with the fuel to keep it from going bad while in storage.
Let me know how it goes..
k
May 21, 2009 | Makita 1,100 Watt 2.5 Hp Portable Power...
Makita Generator suddenly stops has gas
Hi
Hi See if the gas tank cap vent is clogged,remove the cap and check the gasket in it.Check the flyweel key(not to be sheared) and the condenser( not to be defective).The ignition points(not to be burned).Check the oil in the crankcase(pay attention to the low-oil-level shutoff sistem (if there is one).Check the fuel lines and filter.Check the muffler(not to be clogged).Check the plug wires and make sure is securely attached at the sparkplug.Check the cable and linkage.
best regards savumihai71
Dec 15, 2008 | Makita 9 Hp 4,300 Watt Portable Generator...
Makita 8406C Gearbox oil
It uses grease to lube the gearbox. makita supply their own grease so you should be able to get a small tube from your local dealer. You don't have to use Makita grease though, just general grease should be fine. Not too thick and heavy, or too oily and light. I know that sounds a bit vague. Do you have other machines that you have grease for? SDS hammer drills, saws, any small power tool like that will use a similar type of grease.
Nov 01, 2008 | Drills
Makita 1,100 Watt 2.5 Hp Portable Power Generator #G1100 Logo
224 people viewed this question
Top Makita Electrical Supplies Experts
Craig Butler
Craig Butler
obsteiner
Tom Chichester
Are you a Makita Electrical Supply Expert? Answer questions, earn points and help others
