Question about Samsung PCL545R 54" Rear Projection Television
Convergence out and turns itself off
I just got one of these sets and it will turn on, but "no signal connected.." is not level across screen and when in the menu you can tell that the RGB guns are not lined up, there is also some vertical bowing of certain colors. I think red is the furthest out of alignment, seems like someone might have messed with adjustments.
Also the set will turn itself off sometimes just whenever, other times it seems to turn off when you run the perfect picture adjustment. I am an ET but have never dealt with a rear projection TV before.
Any ideas what I should check first?
Thanks JB
  • Anonymous May 13, 2008
    red light blinks four or five times and tv turns off
  • Samsung Master
  • 8,617 Answers
You will need to replace the two Convergence ICs STK392-040 they are located on large heatsinks on the large board on the right side of your TV. You can order replacement ICs at the following link, and They will also include free instalation instructions plus provide free tech support if needed. here is the link
http://servicemanuals.vstore.ca/
Posted on Apr 22, 2008
LG MZ-42PZ44
hi friend
u need a user manual see the in menual tell me whats ur tv model no
Apr 12, 2008 | LG MZ-42PZ44 42 in. EDTV-Ready Plasma...
Fluttering line across screen after replaceing Lamp
there is no convergence on this set. you have a problem on the FMT and the DM pcb's.the chassis needs to be rebuilt. email me or go to www.tv-techs.com
May 19, 2009 | Mitsubishi WD-62725 62" Rear Projection...
This is a convergence problem that should be relatively easy to resolve, I am assuming that the set is new to you rather than new. If new, it should be under warranty and if opened would void the warranty. If new to you and you can solder, you should be able to fix this. First, realize that there are potentially dangerous high voltages present inside the set even when unplugged. Locate the convergence ICs (large black ICs attached to a heatsink and marked STKxxx) and resolder the pins. That may resolve the problem. If not, then replace the ICs. Check the area for small valued resistors that may be defective as well.
Keep us posted.
Dan
Feb 04, 2009 | Samsung HCL5515W 55" Rear Projection...
PHILIPS 50PF9630A/37
Quick test of the plasma screen itself:
1) Turn on the TV
2) Try to bring up an on screen setup menu using the remote or buttons on the tv.
3) Does the menu appear? If so, the screen itself is ok.
If it doesn't come up you make have an issue with the screen itself. I am not sure it would be possible to set contrast and brightness settings such that the picture would completely disappear, but I suspect you should be seeing something on the screen just from having turned it on.
We also need to know more about what you have connected to the television. HD televisions typically have several inputs on them including HDMI, digital cable, VGA and component. Let's say for example you have PS3 connected via HDMI. You can tell the PS3 to send audio across the HDMI cable as well as video. You also have the option of running separate connections for your audio signal. It is the existence of these options that make it necessary to understand where and how you have things connected, very specifically.
Sep 17, 2008 | Philips 50PF9630A 50 in. Plasma Television
Red line convergence problem on KP-57WS510
Yes replacing the ic's should solve it. It worth a try if you want to spend the money
Jun 02, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Red and green lines across the screen
classy cuban,
Probable convergence issue....replace convergence IC's
Guest,
In front of set behind access panel,locate RGB focus and screen
adjust block.....turn red screen control ccw a bit........
m888, Your monitor has a bad CRT.........................T.
Nov 09, 2007 | Sony KP-51HW40 51" Rear Projection...
NO PICTURE
your tv most likely has a bad vertical chip or cold solder on this chip. Another thing is that the connections on the vertical yoke connectors are broken and need to be resoldered....John
Sep 18, 2007 | Mitsubishi VS-4543 45" TV
Samsung PCL545R 54" Rear Projection Television Logo
37 people viewed this question
Henry  Thomas
Henry Thomas
