Question about Weber Genesis Silver B Grill
The starter button does not seem to be igniting the propane
The propane tank is full and open, and we can smell it when we turn the burner on, but when we hit the starter button it has absolutely no effec,t like it is not providing a spark.
    Problem Solver:
  • 12 Answers
Its not, and this is common after about a handful of uses. The igniter is covered with sooot or grease or broken. They sell universal igniters at Sears for like 3 or 4 dollars. Your only other option is to strike long length matches and use those to light it. Be careful , always stand back when lighting grills or any kind off fire. hope this helps.
Posted on Jul 21, 2010
  • rubygirl11 Jul 21, 2010
    thanks for this. I went to the troubleshooting section for weber and they told me to turn everything off, close the valve on the propane tank, disconnect the propane tank, then turn all burners on for at least a minute. Then I re-connected the tank, and slowly (per their instructions) opened the valve. It worked!
Weber grill will not light
you have to narrow down the problem.when you turn the propane on first at the tank (make sure lid is OPEN) and then turn on the burner control are you smelling gas ? If yes then its simply ignition (BBQ lighter to light manually) if no smell are you sure there is propane in the tank ? Can still feel like fuel inside when empty.if you smell gas but won t light check your venturi valves for spider nests,etc if it sat outside for the winter.it will stop the propane from coming thru the burner.Good luck (my money would be no fuel ) please let me know !
May 05, 2018 | Weber Grilling
The grill is too slow when grilling. It doesn't seem to get hot enough
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Aug 01, 2014 | The Holland Grill HGG421408LP Epic Gas...
We replaced the regulator and the grill still does not have big flame always seem to be on low despite knob adjustment
Jul 30, 2014 | KitchenAid Superba KFRS271TSS Stainless...
Cannot get and flame.see spark from starter new tank
Jul 27, 2014 | Char-Broil CharBroil 4638310 Grill
Poor flame after changing tank on gas grille
Jul 05, 2014 | Weber Genesis E-310 Gas Grill
No sound of gas
Tyrn off tank open conrtol knobs to burners , turn off burners turn tank on slowly see if gas comes out now , if not check burners are not blocked or injectors are not blocked
Jul 04, 2012 | Grilling
Grill isn't flowing propane when tank is on. No smell of propane and starter is clicking. Tested 3 tanks on grill and no luck. Tested same tanks on another grill and they work fine so it's the
it could be the reg or a blockage in the line or open the taps on the grill then close them reconnect gas tank open slowly then tis if there is gas to grill
Mar 16, 2012 | Barbeques Galore Turbo STS 3-Burner...
My grill has full propane bottle but doesn't seem to be getting propane! Any help would be appreciated.
Check there is gas at the burners and that the orfices are not block or the burners are bot blocked .
Turn on burners let pressure out of line turn off tank remove gas line then reconnect to tank and turn on tank slowly see if this works
Mar 12, 2012 | Weber Baby Q Grill
I cannot get the gas grill to light. The tank was not completely empty but I replaced it anyway to make sure that was not the problem. I have the same problem with the refill. It does not seem to be...
the regulator could have gone into lock up.
try this to unlock it...
  1. Open the BBQ Lid
  2. Turn ALL main control knobs to the "OFF"/CLOSED position
  3. Turn the Propane tank valve to the "OFF"/CLOSED position
  4. Disconnect the Regulator hose from the Propane tank
  5. Turn ALL main control knobs to the "ON"/OPEN position
  6. Let stand for 1-2 minutes, allowing all excess gas in valves and manifold to dissipate
  7. Turn ALL control knob back to the "OFF"/CLOSED position
  8. Reconnect the regulator hose to the Propane tank- hand tighten only.
  9. Check all hose connections to ensure that a positive seal has been made
  10. SLOWLY turn "ON"/OPEN the propane gas supply
  11. Wait approximately 5 seconds for the regulator pressure to stabilize
  12. Turn "ON"/OPEN the selected burner control knob to "HI"
  13. Press the Multi Spark ignition button or match light selected burner.
  14. Hope this helps you has me in the past!
Jan 08, 2018 | Char-Broil 463220004 Grill
Grill will not light
If there is no gas check the tank, If the tank is fine look at the regulator. It has to be flat, because of a valve inside. This is a safety device incase of tipover.
Apr 14, 2010 | Jenn-Air JLG7130A
Weber Genesis Silver B Grill Logo
582 people viewed this question
Top Weber Grilling Experts
Paul Carew
Marvin
Marvin
Joseph Hoffmann
Are you a Weber Grilling Expert? Answer questions, earn points and help others
