Question about Canon FAX-JX200
Screen display auto print off
Screen displays auto print off how do I fix this
  • manorhouse May 06, 2008
    screen displays auto print off, tried tapping the on/off button and no change.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
Course:
Most often, Auto Print Off is activated by pressing the On/Off button, and documents are then stored in memory. Disable this function by pressing the On/Off button again.
The fax will also turn off Auto Print when the machine runs out of ink or paper, in which case, you should replace the ink cartridge or supply more paper. This situation usually results in display of the message Rec'd in Memory as well, and the unit will receive up to 30 transmissions or 60 pages maximum.
Please post back if you need further help, otherwise thank you for using and rating FixYa!
[Manorhouse:
Try holding the button down just a moment as opposed to tapping. If it still doesn't work, please post a new issue, by selecting "Ask Me", and I will continue to help you through other troubleshooting steps. You need to make sure to check that all your other supplies are in place and OK! Thank you.]
Posted on Jul 02, 2008
How to fix screen display
This is normally a problem with the LCD display and cannot be fixed. Im sorry but you will have to try and locate a used unit from an auto breaker or buy a new one.
Apr 26, 2014 | 2000 BMW 7 Series
Fault/error a fault has occured switch off the machine . ensure that the screen desappears before swithing it on. it the problem persists,call for service. 124-315
Solution : Perform an Automatic Gradation Adjustment (Color Calibration) Automatic Gradation Adjustment compensates for tones when the color tones shift in color copies / prints. Compensating for color tones maintains the quality of color copies / prints made by the machine at a fixed level.
NOTE: Output of the Automatic Gradation Adjustment chart is added to the metered copy count.
NOTE: When Gradation Adjustment is selected, the following changes will be made to default copy settings set in System Settings mode:
  • Copy Density = Normal or Auto
  • Color Shift =Normal
  • Saturation = Normal
  • Color Balance = 0
  • Sharpness = 0
  1. Press the [Access] button (key symbol) on the Control Panel. The Access button is located above the number "3" on the numeric keypad.
  2. Using the numeric keypad, enter your administrator password and select [Confirm] on the Touch Screen. The System Administration Menu screen will be displayed.
    NOTE: If you do not know the password, contact your administrator. The initial password at machine install is 11111. If the administrator encounters a problem with changing the password, or forgets the password, a service call must be placed.
  3. Select [System Settings]. The System Settings screen will be displayed.
  4. Select [System Settings] again.
  5. Select [Common Settings].
  6. Select [Image Quality]. The Image Quality Adjustment screen displays.
  7. Select [Automatic Gradation Adjustment].
  8. Load 8.5 x 11 inch (216 mm x 279 mm) or A4 (210 mm x 297 mm / 8.3 x 11.7 inch) paper in Tray 5 (Bypass Tray). Adjust the paper tray edge guide so that the guide gently touches the edge of the paper stack.
  9. Select the desired gradation adjustment screen.
  10. Press [Start]. The Adjustment Chart is output.
    NOTE: When printing the color chart for Auto Gradation and you get the message,'Auto Graduation Procedure has completed with an error' make sure that 8.5 x 11 inch (216 mm x 279 mm) paper is loaded into Tray 5 Long Edge Feed (LEF).
  11. Place the Adjustment Chart face-down on the Document Glass with both the Magenta color patches against the left side of the glass.
  12. Place 5 sheets of white paper on top of the Adjustment Chart and close the Document Glass Cover.
  13. Press [Start].
  14. To continue Automatic Gradation Adjustment with other screens, repeat steps 6 to 10. When you are finished, select [Close] until the System Settings screen is displayed.
  15. Select [Exit] to exit the System Settings mode.
Hope it helps!
May 02, 2011 | Xerox CopyCentre C128 Copier
Cyan and majenta tone is not good
  • Color Balance = 0
  • Sharpness = 0
  13. Press [Start].
Hope it helps!
May 01, 2011 | Xerox WorkCentre M-24 Color Copier
I have classic model KM-2030; need code to change paper size from 8-1/2 X 11 to A4. Thank you!
Setting the destination Description
Switches the operations and screens of the machine according to the destination.
Purpose
To be executed after replacing the backup RAM on the main PCB or initializing the backup RAM by running
maintenance item U020, in order to return the setting to the value before replacement or initialization.
Enter Maintenance Mode
Enter "10871087" from keypad, You should now be in maintenance mode.
Enter "252"press "Start / Print" key.
Select your destination from list on the display.
Press "Start / Print" key.
Enter 001 "Start / Print" key to exit to normal display.
Method
Press the start key. The screen for selecting an item is displayed.
Setting
1. Select the destination using the cursor up/down keys. The selected item is displayed in reverse.
Display Description
JAPAN METRIC Metric (Japan) specifications
INCH Inch (North America) specifications
EUROPE METRIC Metric (Europe) specifications
ASIA PACIFIC Metric (Asia Pacific) specifications
2. Press the start key. The setting is set, and the machine automatically returns to the same status as when
the power is turned on.
Completion
To exit this maintenance item without changing the current count, press the stop/clear key. The screen for
selecting a maintenance item No. is displayed.
Feb 09, 2011 | Kyocera Mita RADF-11 REVERSING...
How to do a print test on canon mp460 printer after replacing cartridge?
Print the nozzle check pattern to determine whether the ink is being ejected properly from the FINE Cartridge Nozzles. Use this function when the printed results are blurred or the color is incorrect. sikaku.gif Performing Maintenance 1 Press [ON/OFF] to turn ON the machine.
2 Press [Menu].
3 Display the Maintenance screen.
(1) Use [l_mark_s17.jpg] or [r_mark_s18.jpg] to select <Maintenance/settings>, then press [OK].
The Maintenance/settings screen is displayed.
(2) Use [l_mark_s20.jpg] or [r_mark_s21.jpg] to select <Maintenance>, then press [OK].
The Maintenance screen is displayed.
(3) Use [t_mark_s23.jpg] or [d_mark_s24.jpg] to select the setting item, then press [OK].
The setting screen for the selected item is displayed.
sikaku.gif Printing The Nozzle Check Pattern 1 With the machine ON, load a sheet of A4- or Letter-sized plain paper in the Auto Sheet Feeder.
2 Print the Nozzle Check Pattern.
(1) Display the Maintenance screen.
(2) Use [t_mark_sas25.jpg] or [d_mark_s26.jpg] to select <Nozzle check>, then press [OK].
The pattern print confirmation screen is displayed.
(3) Use [t_mark_s28.jpg] or [d_mark_s29.jpg] to select <Yes>, then press [OK].
The nozzle check pattern is printed.
Mar 31, 2010 | Canon PIXMA MP460 All-In-One InkJet...
My pixma ip8500 is printing with some colour missing, all cartridges have ink in them?
When Printing Becomes Faint or Colors are Incorrect.
When printing becomes faint or colors are incorrect even if the ink remains in the ink tanks, the print head nozzles are probably clogged. Print the nozzle check pattern to confirm the condition of the nozzles and then perform the Print Head Cleaning.
Note : Before performing maintenace
*Open the Scanning Unit (Printer Cover) and make sure that all lamps for the ink tanks are lit red.
-If any one of the lamps is flashing slowly, the associated ink tank is running low. You can continue printing for a while, but we recommend you to have replacement ink tank available.
-If any one of the lamps is flashing fast, the associated ink tank is emty. Replace the ink tank.
If an ink tank is flashing fast even though ink remains in that ink tank, it is inserted into the wrong position. Make sure that the ink tank of the correct coloris inserted in each position matching the label.
-If the ink lamp is not lit, the tank is not set properly. Press the <PUSH> mark on the ink tank until the tank clicks into place. Make sure that all the packaging material is peeled off the ink tank.
*Increase the print quality setting in the printer settings.
Step 1 : Printing the Nozzle Check Printer.
1) Make sure that the machine is turned on, open the Front Feed and extend the Output Paper support.
2)Load a sheet of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Front Feeder.
Set the Paper Thickness Lever to the left.
3) Press the Paper Feed Switch to select the paper source where you have loaded paper.
4)Print the nozzle check pattern.
a) Press the Menu button.
b) Use the right and left arrow buttons to select the Maintenance/settings, then press the OK button.
The maintenance /setting screen is displayed.
3) Use the right and left arrow buttons to select Maintenance, then press the OK button.
4) Use the Up and Down arrow buttons to select the Nozzle check and then press the OK button.
The pattern confirmation screen is displayed.
5) Use the Up and Down arrow buttons to select Yes and the press the OK button.
The nozzle check print is printed, and the pattern confirmation screens are displayed alternately.
Examine the pattern and take the appropriate action.
Step 2: Print Head Cleaning
Clean the Print Head if lines are missing or if white streaks appear in the printed nozzle check pattern. Cleaning unclogs the nozzles and restores the print head condition. Note that cleaning the Print Head causes used inl to be absorbed in the ink absorber. Cleaning the Print Head consumes ink, so perform Print Head Cleaning only when necessary.
1) Make sure that the machine is on, open the Fron Feeder, and extend the Output Paper Support.
2) Load a sheet of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Front Feeder/
4) Start Print Head Cleaning.
b) Use the right and left arrow button to select Maintenance/settings, then press the OK button.
c) Use the right and left arrow buttons to select Maintenance, then press the OK button.
d) Use the Up and Down arrow buttons to select Cleaning and then press the OK button.
The confirmation screen is displayed.
e) Use the Up and Down arrow buttons to select Yes and the press the OK button.
Print Head Cleaning starts.
Do not perform any other operations until Print Head cleaning finishes. This takes about 50 seconds.
f) Use the Up and Down arrow buttons to select Yes and the press the OK button.
Note : If the problem is not resolved after performing steps 4 and 5 twice, try Print Head Deep Cleaning.
If print quality does not improve by standard Print head Cleaning, try the Print Head Deep Cleaning, which is more powerful process. Note that cleaning the Print Head causes used ink to be absorbed in the ink absorber. Print Head deep Cleaning consumer more ink than the standard Print Head Cleaning, so perform this procedure only when neccessary.
d) Use the Up and Down arrow buttons to select Deep Cleaning and then press the OK button.
Print Head Deep Cleaning starts.
Do not perform any other operations until Print Head Deep cleaning finishes. This takes about 100 seconds.
5) Check the condition of the Print Head.
a) Print the nozzle check pattern to check the print head condition.
If a particular color is not printed properly, replace the ink tank of that color.
b) If the print head nozzles are still not cleaned, turn off the machine and perform another Print Head Deep Cleaning after 24 hours.
c) If this does not solve the problem, the Print Head may be damaged. Contact your Canon service representative.
Hope this helps.
Please rate my response.
Thanks.
Have a good day.
Dec 01, 2009 | Canon PIXMA iP8500 InkJet Photo Printer
Auto head alignment
#1 of 2
Carryout a Manual Print Head Alignment If Possible.
If the results of Automatic Print Head Alignment are not satisfactory, follow the procedure below to perform Manual Print
Head Alignment.
1 Make sure that the machine is turned on, and then load three sheets of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Cassette.
Important. You cannot print the print head alignment pattern if paper of size other than A4 or Letter is loaded. Be sure to use A4 or Letter-sized plain paper.
2 Open the Paper Output Tray, and then open the Output Tray Extension.
(1) Put your finger in the rounded indent of the Paper Output Tray and open it gently.
(2) Open the Output Tray Extension.
3 Press the Paper Feed Switch to select the paper source where you have loaded paper.
4 Select Settings on the HOME screen.
5 Select Maintenance, then press the OK button.
6 Select Manual head align, then press the OK button.
Note. If you select Head alignment print, the machine exits the process after printing the current head position adjustment values.
7 Select Yes, then press the OK button.
8 When the Print Head alignment pattern is printed, select Yes, then press the OK button.
9 Look at the printout. From the patterns, select the most even, least irregular patterns for each column and input their numbers. Press the OK button.
(1) Select a column to input the pattern number.
(2) Use the or button to input the number of the pattern.
(3) Repeat the steps (1) and (2) until you finish inputting all pattern numbers, press the OK button.
Oct 08, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Drum light stays on after replacing
C- Auto- C -Auto . 24 Print, 07 Print , then press CCC three times.
Pls? try so that)
Dood luck!
Sep 15, 2009 | Sharp AL-1642CS Copier
Pentax Optio s50 The LCD display has lost some pixels and now has a circle of black spots on the screen. Is there anyway to fix this or is it time for a new camera? I can't just look through the view...
If pictures taken in Auto mode look the same on a computer (or when printed) as on the LCD display a Sensor fault is indicated. If the Computer image is OK the LCD display on the camera is faulty.
Assuming your camera is out of guarantee you could request a quote for repair but beware the "Minimum Charge" some suppliers impose just to tell you how much it will cost.
Apr 27, 2008 | Cameras
Print Qualityfor DC12
I am not 100 percent what you are asking but I will answer the best I can with your question.
  1. Press the [Administration] button located above the numeric keypad on the Control Panel. The Administration button has a wrench symbol located above it. The Access screen will be displayed.
  2. Select [Tools] on the Touch Screen. The Tools Access Number screen will be displayed.
  3. Enter your numeric password using the keypad.
    If the administrator encounters a problem with changing or forgetting the machine password, a service call must be placed:
  4. Select [Enter] on the Touch Screen. The Tools screen will be displayed.
  5. Select [System Image Quality]. The System Image Quality screen will be displayed.
  6. Select [Image Recognition]. The Image Recognition screen will be displayed.
  7. Select 'Screening Adjustment' by selecting the [Up] or [Down] arrow buttons.
  8. Select [Change Settings]. The Screening Adjustment screen will be displayed.
  9. Select [Apply to Copies Only] then select [Save]. The Screening Adjustment screen will be displayed.
  10. Select [Close]. The System Image Quality screen will be displayed.
  11. Select [Auto Screening Adjust]. The Auto Screening Adjust screen will be displayed.
  12. Select [Halftone Screen]. The Halftone Screen will be displayed.
  13. Select either [Halftone 200 line screen] or [Photograph 200 dpi].
    NOTE: Do not select 'Printer use' as this will effect print calibration; which will be handled directly by the color server set up to print to the copier / printer.
  14. Select [Save]. The Auto Screening Adjust screen will be displayed.
  15. Insert at least 2 sheets of white, 216 mm x 279 mm (Letter, 8.5 x 11 inch) paper in Paper Tray 5 (Bypass Tray).
  16. Select [Print Test Original] to print a sample of the settings. The message 'Please wait…Printing test original' will be displayed and the test original will print.
    NOTE: If selecting [Print Test Original] displays the message ‘System Disabled' then Screening Adjustment is disabled. Select [Close] and repeat steps 5 to 16.
  17. Open the Document Glass Cover.
  18. Place the test original face-down on the Document Glass with the two magenta squares against the left edge of the glass.
  19. Place 5 sheets of blank white paper directly on top of the test original.
  20. Close the Document Glass Cover.
  21. Select [Start Adjustment] from the Touch Screen. The message 'Please wait….Adjustment in progress' will be displayed, then the Auto Screening Adjust screen will be displayed.
  22. Select [Adjustment Complete]. The message 'Please wait…Printing current settings' will be displayed and the adjusted original will be printed.
  23. Examine the adjusted original to make sure the image quality is satisfactory and continue to the next step. If the image quality is not satisfactory repeat steps 12 through 22.
  24. Select [Close]. The System Image Quality screen will be displayed.
  25. Select [Close]. The Tools screen will be displayed.
  26. Select [Close]. The default copy screen will be displayed
Dec 27, 2007 | Xerox DocuColor 12 Printer
Canon FAX-JX200 Logo
131 people viewed this question
old marine
old marine
