Question about Lexmark Wheelwriter 3 Typewriter
Will not run. spacing indicator lights and shift lock light will not go off
  • Lexmark Master
  • 3,594 Answers
Dosen't sound good, look for forgien objects on or around the PC boards otherwise you'll need a tech.
DickyO
Posted on Jul 22, 2010
Where is module on brake peddle for shifting out of park on cadilac srx4 2007
There is no module on the brake pedal . There is a brake switch , do the brake lights work ? If the brake lights work switch is ok .
Automatic Transmission Shift Lock Control Description and Operation
The automatic transmission shift lock control system is a safety device that prevents an inadvertent shift out of PARK when the engine is running. The driver must press the brake pedal before moving the shift lever out of the PARK position. The system consists of the following components:
• The automatic transmission shift lock solenoid (serviced as the automatic transmission shift lock actuator), as well as the body control module (BCM) and the engine control module (ECM). The shift lock solenoid is located within the floor shift control assembly with vehicles equipped with floor shift.
• The body control module (BCM) controls the voltage supply circuit of the shift lock control solenoid. The following conditions must be before the BCM will supply voltage to the shift lock control solenoid.
The BCM controls the voltage to the shift lock control solenoid through the shift lock control solenoid controlled voltage circuit. The following conditions must be met before the BCM will supply voltage to the shift lock solenoid:
• The ignition is in the ON position.
• The engine control module (ECM) sends an input via GMLAN serial data to the BCM indicating the transmission is in the PARK position.
• The BCM determines the brake pedal is applied according the brake pedal position.
Since the shift lock control solenoid is permanently grounded, the BCM supplies voltage to the automatic transmission shift lock control solenoid, mechanically unlocking the shift lever allowing the driver to move the shift lever out of the PARK position as the solenoid energizes. When the brake pedal is not applied, the BCM turns the control voltage output of the shift lock control solenoid OFF, de-energizing the shift lock control solenoid. The de-energized solenoid mechanically locks the shift lever in the PARK position.
During remote start operation, the BCM will de-energize the shift lock control circuit, locking the shift lever in the PARK position.
Your best bet ,have it towed to a qualified repair shop !
Oct 15, 2016 | 2007 Cadillac SRX
When i switch on in the switch board the diff lock light indecation light is constantley on what can i do for it ?
mayb your diff lock switch was jam even there r free but it still giving signal to meter panel
Nov 26, 2014 | 1994 Toyota Land Cruiser
Honda element shift indicator light not working
Have a 2005 element; had the same problem. 15 amp fuze in fuze box under the hood. Fuze that controls horn, brake lights and gear shift lock out.
Sep 11, 2012 | 2007 Honda Element SC
Shift locked in park/2000 nissan xterra se
check battery volts should be 12.5 volts,if yes check see if you have rear brake lights.if no replace brake light fuse.if brake light fuse okay a faulty brake light switch or shift lock solenoid not working,when you apply brake the electrical circuit goes to shift lock solnoid so you can get transmission out of park.shift solenoid located centerconsole located near gear position indicator.
Sep 01, 2012 | Nissan Cars & Trucks
Shift indicator lights are all on
Might just be indicating a fault in TCM, have vehicle scanned.
Aug 08, 2017 | 2008 Volkswagen Jetta
2001 f-150 5.4 auto, overdrive light flashing
There will be a code in memory which will indicate the problem. From you saying it flashes at cruise it is most likely your torque converter is not locking up as it should.
Nov 16, 2017 | 1997 Ford F250 SuperCab
2000 Honda Odyssey. The passenger side headlamp burned out and I replaced it, no issues two days ago. Battery was cranking slowly and terminals were corroded so I cleaned them. Last night in 15 degree...
The driver's Multiplex Control System is a small computer that controls (among many other things) the dash lights brightness, ignition key interlock, shift interlock, and has a tie in to the brake light system and horn relay. It may be that this small computer malfunctioned and started the whole problem chain.
However, I note from the factory shop manual that if polarity is reversed on the shift interlock--it can be damaged. Reverse polarity will ruin the diode inside the shift interlock. This could have happened when you jumped the battery--a brief period of getting the cables and terminals mixed up could have done it.
Checking the shift lock solenoid can be done by removing the steering column upper cover. Disconnect the shift lock solenoid connector (2 terminals). Using long jumper wires, apply battery voltage to terminal 1 (yellow wire side) of the solenoid and ground terminal 2 (green wire side). Check that the shift lever can now be moved out of Park. NOTE: applying voltage in the opposite direction of that above will damage the diode in the solenoid and will probably ruin it. Remove your jumpers and shift back to park and check that the solenoid locks. If the solenoid does not work properly, it will need to be replaced. This involves removing the end of the transmission shift cable and is a complex job. Remember, no power to the solenoid equals a locked solenoid--it takes power to unlock it.
The Multiplex Control Unit has a self diagnostic feature which checks the computer itself and inputs to the computer. The computer check is called mode 1 and the input test is mode 2. The diagnostic trouble codes are outputted to the ignition key light and beeper.
To test, first confirm that all fuses are good, especially fuse 9 (10A) in the driver's under dash fuse box (left kick panel) and fuse 13 (7.5A) in the passenger's under dash fuse box (right kick panel). Then use a jumper wire (a wire with small alligator clips on each end works best) to jump the two leads of the multiplex test connector. (This is a light green 2 terminal connector dangling from the same wire bundle as the brake pedal switch connector.) Buckle the driver's seat belt (avoids nuisance beeps). Now turn the ignition switch to on. After about 5 seconds, the ignition key light should come on and the beeper should beep for 2 seconds then stop for .2 sec. then beep once for .2 seconds. This indicates that the system is in diagnostic mode 1.
If no diagnostic trouble codes (DTC's) are present, the key light and beeper will not blink/beep again. If there are codes: about one second after entering mode 1, the key light and beeper will indicate the DTC and repeat it every 3 seconds. If there are more than one, the system will indicate them in ascending order. The codes will be a light flash and beep so you will have to count the flashes/beeps to keep track. The codes range from 1 to 6. Code 3 (three flashes/beeps) indicates a problem with the multiplex control unit itself. Write back here for other codes or for questions about mode 2.
Jan 23, 2011 | 2000 Honda Odyssey
Grenn light in the center of the tach, looks like
Light is an automatic shift lock indicator.
Jan 14, 2010 | 2004 Volkswagen Jetta
VTM-4 indicator light comes on
VTM4 LIGHT ON after gear was changed, but car drives smoothly and CHECK NENGINE light does not come on. Have diagnosed and was told nothing wrong with transmission. Please help
Dec 02, 2009 | 2005 Honda Pilot
There is a light on the dashboard that I do not
I believe it's the washer fluid light
Here's a list of your dash lights and their meanings
Left
1. Door-ajar warning light
2. Oil pressure warning light
3. Check engine warning light
4. Tour or Sport for the ECS
5. Security indicator
Center Warning Lights
1st space down
Left: 4-wheel steering oil level warning light
Right: Brake warning light
2nd space down:
Left: Anti-lock brake warning light
Right: Active Exhaust Tour indicator
3rd space down
Left: cruise control indicator
Right: cruise control ON indicator
4th space down:
Left: charging system warning light
Right: High-beam indicator
Right Warning Lights
1st down: Not used
2nd down: Seatbelt warning light
3rd down: Washer fluid (2 storage containers)
4th down: Supplemental restraint system (SRS) warning light
Oct 07, 2009 | 1994 Dodge Stealth
Lexmark Wheelwriter 3 Typewriter Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
