Question about Zebra LP 2844 Thermal Printer
Printing is fuzzy. Not clear
When printing a label, some of the address comes out fuzzy and is hard to read. Is there any ink in these printers or how do you get it to be clear again. Do I have to replace the board?
jigeo
  • 57 Answers
SOURCE: Zebra 2844 Not printing at all
Antztech,
if the red light is coming on and staying on, it might be a sensor problem. Try pushing on the lid and see if the light goes to green. If it does, it' s the gap sensor. This is how the printer "reads" the labels gaps-the little spaces between the labels. We've solve this in the short term by covering the sensor and manually setting the gap through the programming command prompt,
Posted on Apr 19, 2008
SOURCE: ZEBRA 105SL : PRINTING PROBLEM
Thanks your the solution. This helped me a lot.
Greetings
Thomas
Posted on May 05, 2008
SOURCE: printing blank labels
I am having the same problem! Printing blank labels. Don't know what's wrong now. It was working fine yesterday.
Posted on Jul 23, 2008
SOURCE: HP Deskjet F2180 Margins incorrect for label printing
I eventually managed to print my labels one sheet at a time by forcing the label top edge down the page. You can insert one or two lines above the label template and adjust the font size to get the right distance. It took a bit of trial & error but got there in the end. Hope it helps you
Posted on Dec 11, 2008
  • 62 Answers
SOURCE: how do I clear the memory on a zebra gk420d?
Download the Seagull scientific GK420 ZPL driver. Version 7.16.
Open the driver file, (Double click on printer icon in printer & faxes folder)
Click Printer, properties, tools, action, reset printer.
Play around with the Seagull driver, it is very useful, you can format memory, read files stored in printer memory, see forms, fonts, images etc.
The forms stored in the G series printers are not cleared by the normal methods which one would use on it's predecessor the 2844 models. The G series will maintain the forms stored in its memory even if you download new firmware, or reset it. This is actually a good thing, as it prevents you from accidentally erasing forms stored in the printer.
Posted on Apr 18, 2009
Barcode prints fuzzy
Have you tried to "clean" the printerheads. You know like you would do with a normal printer. Sometimes the printheads go stucked with old ink(wich you cannot see on screen ofcorse)
Apr 16, 2014 | Zebra GK420D Direct Thermal Label Printer
HP6500 won't print on foil
Most inkjet printers need a paper that has an absorbtion rate of +.ooo5 but unless the foil is a coated stock I dont think the ink will adhear to it..Try a differnt stock . Maybe a bad batch of labels..and did you use HP printer ink or are your cartrages refills??
Dec 20, 2013 | Office Equipment & Supplies
Printing not clear & disabling alignment
h o this is because of the catridge problem. check the outlet of the ink....and clean the area with proper clean cloth and check t. may be the catridge got over . so check the level and try printing.
Jul 05, 2010 | Office Equipment & Supplies
Smart LabelPrinter Seiko 440
The code between the labels indicates either you are using labels designed for another model or that it is thinking it has a shippinhg label opr some lareger type installed. IT is more likely to be the first option, you are usinjg the wrong coded labels
Please rate my help++++Thanks for using FIXYA
Dec 06, 2009 | Seiko Smart Label Printer Pro Thermal
Brother mfc 5840 won't print clearly
you need to check the maintainence kit and see if it's full. Also if it isn't, use some iso-proponal alcohol and some q-tips to clean the print section of the cartridge and the cartridge tray.
Aug 21, 2009 | Brother MFC-5840CN All-In-One InkJet...
My printer prints fuzzy
Have you tried to do an alignment? It's usually part of maintanance.
May 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
My dymo starting printing only the bottom half of my labels, do i just need a new ink cartridge or is this a different problem? the bottom half seems just fine...
Take out tape cartridge, make sure tape is going THROUGH both top and bottom tape guides. Clear all.
This should work. You also may have set up for second line printing. Go through all settings and clear.
May 06, 2009 | Dymo LetraTAG Thermal Label Printer
Oki 320 Turbo -- Unclear characters in output
If it is not the ribbon, you may have to replace the print head.
Genuine Okidata Print Head
Mfr Part #:
50063802
Hope that helps...
Jun 21, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Zebra TLP2844 does not print the barcode label
Can you print the barcode using the software that come with the printer. Zebra TLP2844 come with basic Designer software. Test whether it's printing the barcode or not.
IF it prints the barcode via its software, then you might be having barcode font problem between your application/os and the printer.
May 21, 2008 | Zebra Eltron TLP 2844 Thermal Label...
Zebra LP 2844 Thermal Printer Logo
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
