posted by country cool on Apr 22, 2008
I'm having to clean the inside of my screen, my son dropped lamp oil and it's on the inside bottom right side of my screen and speakers. Is the model of my tv RCA model P52927 the same as P52926 52 in. as I read how to take off the screen on that model will mine be the same. I'm not turning on the tv until I get that oil off the inside of the screen....
forgot my unlock code
1 Other User Has The Same Problem
Comment by TOOTYPOPandw, posted on May 04, 2008
I HAVE SPIDER WEBS BEHIND THE SCREEN I NEED TO KNOW HOW TO REMOVE THE SCREEN TO GET BEHIND IT TO GET THEM OUT! HELP??????????
Solution #1
posted on May 14, 2008
Look, take out back cover and on the bottom left and right side you will see screw (2 or 4), take out it,Disconnect 2 plugs wire from chasis, pull out the box and you will have space for clean your screen.( You will take out all box with main chasis, convergence chasis )
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for RCA P52926 52 in. Rear Projection
Email this problem
Email this problem
Can you Help with these Projection Televisions problems?
RCA P52926 52 in. Rear Projection Television
squealing noise
squealing noise
When you turn the tv off and... Answer This...
TV wont turn on
TV wont turn on
I have a 52in RCA model... Answer This...
WEAK POWER LINE
WEAK POWER LINE
Are these expensive to replace? Answer This...
Power light comes on, then...
After about a year +, the power... Answer This...
2001 52" RCA Rear...
The television worked fine then... Answer This...
Repair Service
Find Projection TV Repairman Near You:
Find Parts
