Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Water inside refrigerator
There is a build of water (condensation) in the main box. The pan underneath is dry. How do I clear/clean the line to get it to drain properly. I know where the line comes out the back, but I am not sure how it is removed from the back of the unit.
  • 4,793 Answers
Use a meat/gravy syringe or similar to blow clorine bleach down the drain pipe,it will clear any "growths"inside the pipe in no time....
Posted on Jul 21, 2010
Water is dripping from the freezer compartment into the fridge compartment.
WATER LEAKING FROM REFRIGERATOR OR INSIDE THE FREEZER OR FRESH FOOD SECTION
You have a blockage in your condensate defrost line or the pipe that fill the tray below the refrigerator is missing the condensate collector pan that uses the heat from the fan to evaporate the condensate back into the air inside your home. Or this sounds like you have a blockage in the drain tube, remove panel back of freezer...you may see ice build-up, melt ice with hair dryer, you will see a pan below evaporator, melt ice in pan, dry water up in pan with towel, now you should see drain hole in pan that leads to drain tube, pour some hot water in pan, wait a couple minutes, wipe up water and repeat this step 2-3 times, once you have done this use a wet and dry vacuum cleaner to vacuum out the gunk or blockage in the drain line. Now it is cleaned out! Put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. Good luck! PS Please don't forget to rate my solution Thanks! Sea Breeze One moment I will send you to a ink and scroll down the page and read and watch movie Click Here=> Sea Breeze Tip's
Mar 13, 2010 | Whirlpool Refrigerators
Bottom of freezer in the side by side builds up with ice, then water leaks on to the floor
We have a defrosst drain problem we will need to work on, WATER LEAKING FROM REFRIGERATOR OR INSIDE THE FREEZER OR FRESH FOOD SECTION
Feb 06, 2010 | Maytag Ice2O 24.9 Cu. Ft. Side-by-Side...
Have a GE side by side, when it goes through the defrost cycle puddles of water form outside the unit. Drain hole in bottom of freezer seems to be clear.
You have a blockage in your condensate defrost line or the pipe that fill the tray below thr refrigerator is missing the condensate collector pan that uses the heat from the fan to evaporate the condensate bak into the air inside your home. Or this sounds like you have a blockage in the drain tube, remove panel back of freezer...you may see ice build-up, melt ice with hair dryer, you will see a pan below evaporator, melt ice in pan, dry water up in pan with towel, now you should see drain hole in pan that leads to drain tube, pour some hot water in pan, wait a couple minutes, wipe up water and repeat this step 2-3 times, once you have done this use a wet and dry vacuum cleaner to **** out the gunk or blockage in the drain line. Now it is cleaned out! Put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. Good luck! PS Please don't forget to rate my solution Thanks! Sea Breeze
Aug 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refridgerator side not cooling. No air movement.
vent clear but vent opening arround vent frozen or coil is frozen eithor way you probably need a thermostat and a timer
Jul 29, 2009 | KitchenAid KSCS25FKSS Side by Side...
Water accumulating under the vegetable boxes in the refrigerators
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Jul 06, 2009 | Refrigerators
I have a whirlpool refrigerator and it seem to be leaking from
The bottom front of the refrigerator or freezer door Self-defrosting refrigerators usually dispose of the water generated during the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
In some refrigerators, the defrost water is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain--usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction.
Another cause may be the following. The refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says “energy saver” or something similar, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the condensation disappears the problem is solved.
The back of the refrigerator Water coming from the back of the refrigerator usually comes from either the ice maker water valve or line (if there is an ice maker), or from the defrost drain pan.
Here's what to do:
  • If the water is coming from the ice maker water valve, check to make sure the water tubes are attached properly and are fastened tightly.
  • If the water seems to be coming from any part of the valve itself, replace the valve.
  • If the water appears to be coming from the defrost drain pan, inspect for holes or cracks, and replace the pan if necessary.
The inside ceiling of the refrigerator Water accumulating on the ceiling of the refrigerator is usually caused by a clogged drain in the freezer section beneath the evaporator. The clogged drain will cause water from the self defrost cycle to leak into the divider between the freezer and refrigerator. This water may then freeze and cause condensation build-up on the refrigerator ceiling. The solution to this problem begins with unclogging the drain. It may also be necessary to remove the entire freezer/refrigerator divider to thoroughly dry the insulation in the divider. Occasionally the insulation needs to be replaced to prevent a recurrence of the problem. This can be a big job – you may want to hire a qualified appliance repair technician.
The inside back wall of the refrigerator In some refrigerators, the water from the defrost cycle is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain - usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction.
Underneath the front of the refrigerator If the refrigerator is equipped with a water dispenser on the freezer door, check if the water line to the dispenser is leaking. Also, check the drip pan to be sure it isn’t out of place, broken or cracked.
Mar 24, 2009 | Refrigerators
Condensation dripping from top of refrigerator
The problem is the defrost drain trough is plugged with ice. You will have to turn off the refrigerator, remove the freezer back panel and use a baby aspirator to help you apply and remove hot water to melt the ice. Then insert the aspirator in the drain hole to blow out any thing that may have gotten lodged inside. You will hear the water draining now to the pain underneath the refrigerator. Hope that helps you, good luck!!
http://tclaundryrepair.com/
Feb 25, 2009 | Whirlpool Refrigerators
My whirlpool refrigerator is leaking water inside the refrigerator. i have no water or icemaker on mine. its just a regular old fridge about 9 years old. i keep it clean and vaccum out the bottom every...
Water can leak from these areas:
Here's what to do:
Jan 06, 2009 | Refrigerators
Leak
It leaks Water can leak from these areas:
Here's what to do:
Dec 02, 2008 | Kenmore 53642 / 53644 Side by Side...
Samsung side by side
This is an issue brought about by the defrost cycle. Usually, the condensate goes into a small pan under the unit where it evaporates. You will likely find that the tubes coming down from the unit to the pan underneath the box are clogged with dust. While you're there, clean the condenser coils.
Dec 30, 2007 | Samsung RS2534 Side by Side Refrigerator
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
71 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
