Question about GE GSS25JFM Side by Side Refrigerator
Run for a few days and stops getting cold - GE GSS25JFM Side by Side Refrigerator
  • GE Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Dec 28, 2010
Hello, my frig gets real cold but one day compressor stopped frozen stuff started melting. unplug plugged in few hours later it works for a week off again cycle continues for a few weeks. I replaced the...
0ba250e7-c31b-40ec-b003-ff0da31d62e4.jpgThis could be caused by a couple of things. If the condenser fan is defective and stopping while you don't see the fan stop it will cause the compressor to overheat and stop. The other possibility is a defective=> 12784415 Main Control Board or JAZZ Board A defective relay on this board will cause the same symptoms, Sea Breeze
I am here if you have questions...JT
Sep 21, 2013 | Maytag Refrigerators
I get a warning message, "HIGH ENGINE TEMPERATURE-STOP ENGINE" from our 2002 S60 Volvo upon starting. The check engine light also comes on. The electric fan come on and runs for approx. 2-3 minutes....
Mine is doing the same thing. I have taken it to the shop and the mechanic can't find anything wrong with it. When he resets the diagnostic, the car runs fine for a few days then it happens again. I'm thinking it is something due to the cold temps here in NW Iowa. It is obviously not a cold weather car!
Feb 16, 2010 | 2002 Volvo S60
Frig does not get cold
Usually when this happens it is because of a problem with the fan that moves cold air from the freezer section of your unit to the refrigerator section. Either the fan has gone bad or the unit has frosted up to the point of stopping the fan. Try defrosting (unplugging) the unit over night and then check it to see if the fan runs. If not then replace the fan. If it runs and then stops after awhile like days or even a few weeks, then you may need a defrost timer.
The other thing that can cause this is the heating element going bad, but this is not usually the problem. The element can be checked with an OHM meter. If the coil does not have any resistance then it is bad.
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
You can find parts for your unit by doing a search for “appliance parts”.
Once you get the results of the search, pick a site and when it comes up it will usually ask for the model number of your unit.
Enter your model number and you will then get a page with exploded views and a parts menu.
Find the part you need and then order it.
Check a few different sites to be sure that you are getting the best pricing.
Most sites can have the part to you in a couple of days.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 23, 2009 | Maytag MFD2560HES Bottom Freezer French...
Car won't start HELP PLEASE
Hello...
I would start, since it is cold outside by checking to make sure the battery is in good shape. If it is not, it will run but when the cold comes it will eventually not turn over. Note: Turning on the lights to see if they are bright is not a good check for the batteries abilty to crank the car. If you have a Checker or Autozone or other auto parts store see if they can test your battery for you.
With the sudden stop starting I would also suspect possibly the fuel pump or the pump relay.
Good Luck...
Mike
Dec 13, 2009 | 1992 Toyota Celica
Freezer works, fridge doesn't cool
Probably excessive ice in the condensor. Likely defrost thermostat or defrost heater problem.
What happens is excessive ice keeps airflow from the refrigerator part of the unit.
Jul 08, 2009 | Refrigerators
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Jul 08, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
The side by side fridge either cools too much (at times freezing the vegetables in the bins) or stops cooling (when it starts getting opened a bit morethan few times a day)
This sounds like an intermittent bad cold control. If you catch it off and hear nothing running and it is warming up, use the handle of a butter knife and rap the knob of the cold control. If it pops on, you must replace the control. Good luck, AJ
May 22, 2009 | Refrigerators
Refrigerator operates properly for a few days then stops working
When you said it stopped working, do you mean it is not working at all? or is it not cold enough? If not working at all, that will be thermostat, when you change the thermostat, did you adjust the small switches to match you unit and make sure wires are connected properly, If not, it would work properly. If not cold enough, check and make sure the condenser fan motor and compressor are running, if both are running but not cooling then you have sealed system problem.
Mar 28, 2009 | Marvel 6BAR-BD Beverage Cooler
GETS COLD IN 4 HRS
sure could be what is your email i will send you the manual
Jul 07, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
1995 ford taurus wagon a/c issues
Id say you have to go into it and see. Sounds like the compressor is not running. The small copper pipe should be warm and the big copper pipe cold and wet. Could be anything low pressure switch ,wire off, cap gone???????
Jun 23, 2008 | 1992 Ford Explorer
GE GSS25JFM Side by Side Refrigerator Logo
37 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
