I HAVE A POULAN PRO PB250E WEEDEATER, i CAN GET IT TO START FOR ABOUT 5 SECONDS ON CHOKE AND THEN THE ENGINE JUST DIES. WILL NOT RUN UNLESS CHOKE IS ON FOR THOSE 5 SECONDS.
I have the same problem but after it dies I noticed the primer bulb was emptyI have the same problem but after it dies I noticed the primer bulb was empty
You can't post conmments that contain an email address.
Try changing the fuel filter and if that dont do it there is a small screen inside the carb that usually plugs up carefully disassemble it and clean it out with a good brand of carb cleaner
I have same problem but I noticed after it dies the primer bulb is empty can anyone tell me whyI have same problem but I noticed after it dies the primer bulb is empty can anyone tell me why
If you do indeed have (good)fuel and spark to cylinder, I suggest you remove muffler and clean the internal screen/mesh and carefully scrape off carbon around exhaust port. Do not let debris fall inside engine when cleaning. Repairing my STIHL FS 38 Clogged Muffler Fix
Press primer bulb 6 times
Move throttle lever to start position
Move choke lever to full choke position
Pull starter rope sharply until engine attempts to start, but no more than 5 pulls.
Move choke lever to half choke position. Pull starter rope sharply engine runs. If engine hasn't started after 5 pulls, repeat all steps above.
After warming up for 10 seconds, move choke lever to run position.
Manuallib.com has a manual for this model available for free download
Needs a carb adjustment, cleaning, or possible rebuilt. Try adding a little seafoam and running at half choke for about 5 mins or longer this may clean it up nicely. also check the spark plug.
Full choke until it tries to start, half choke until it does, and once it's running, open the choke fully and wait a few seconds for it to warm up before using it, as well as 15-20 seconds to let it cool down before shutting it off so as not to warp any metal parts of the engine
needs to have carb cleaned out. most likely the main jet in the carb is plugged. symptoms include only running on choke and dies when choke is turned to run. or if you only have a primer bulb, it will only run for only a few seconds every time it is primed. if you are qualified to work on the carb, dont forget to start with fresh gas and possibly new fuel line and filter. R
After you start it and are in the second stage of the choke (half choke ) let it run for awhile until it warms a bit then try openning choke and going to full throttle.
