Question about IBM ThinkPad T43 Notebook
T43P LCD keeps going dark
LCD goes dark intermittently making the machine practiacally useless. In Linux I can go to another screen and coming back to X I get the lcd working for a while, then it goes away again and I have to do the ctl+alt+F# dance all over again. In Windows when it goes away I have to reboot!
.githogori.
  • Anonymous Sep 26, 2008
    T43 LCD keeps going dark problem
    Scholar:
  • 144 Answers
I think you are having problem with backlight. The concept of laptop is that if there is problem with backlight then it will try to shut it down(shut the light down).If you restart your laptop ,that mean you turn the light on again...after that if its blink or something wrong then again your system will try to shut it down to prevent other part get spoil.
What you have to do is..
1.problem from backlight replace backlight
2.problem from inverter replace inverter
3.problem from motherchip...repair motherboard.
Byebye,takecare
Posted on Apr 23, 2008
I have a problem with my IBM T43. It starts up with a dark screen and I can still see windows boot up. I have try clicking ctrl+alt+F# and ctrl+alt+F7 but it doesn't work.
Please can anyone help me slove my problem.
Regards
Rexford
Posted on Jun 08, 2008
I have a t43 too and i face the same problem ..but in order to quicky solve this problem ...i press FN key and then F7 that will try to switch to external display and now since you dont have any external display press FN and f7 again to come bak to your laptop screen ....
this is what i figured out instead of restarting the computer again
--- Naveed Muhammad Iqbal
Posted on Jun 05, 2008
There is issue I have run into on alot of IBM t40 series with the screens going dim, I don't know what its called but the board that has all the LED's on the screen is easily replaced and usually fixes the problem, take out the 3 screws on the front of the screen, and one of the small ones on the right side, you should be able to left the bezel (carefully its stuck to the screen) and you will see the board with the LED's take out the screw for it and unplug the white 2 pronged cable and the the small ribbon cable attached to back, get another one (I suggest off a broken screen) and replace.
Posted on May 12, 2008
After booting my screen goes dark
Goes dark or just stays dark ? if stays dark then it is the GPU causing problems as it has got too hot at some point, possibly due to lack of ventilation underneath. What sometimes works for me is to turn the machine on and flip it over and rest it on say a tea towel, but have the screen overhang the edge of table so it doesnt damaged it. Then, you need to cover vents and let the machine heat up for say around 10 mins. After this time, turn machine off and back on again, and you will find the screen will come back on. You should then be able to use machine as normal, but keep all vents clear. Some folk might think this is barmy, but trust me it works on most, HP, Compaq, Dells etc.
Apr 07, 2010 | HP Computers & Internet
My screen keeps going dark like it is going to sleep
Right click on any free space of desktop and go to properties and go to Screensavers tab and click on Power Tab and select Never in Turnoff monitor option and click apply OK.. now it will not go dark..
Soluzia.net
Jan 07, 2010 | HP f2105 21" LCD Monitor
Dark and useless
LED went out on your phone and you need to replace the LCD on the phone
Sep 18, 2009 | Sony Ericsson G900 Smartphone
My Element 15" TV comes on for about 30 sceconds then goes "dark. It is useless now.
The back light is probably bad, It can be sill used if you put a bright lamp behind it.
or get the inverter replaced.
Check each lamp to make sure it is not black on the both ends. That's a sign that it's bad. and a sign that the inverter is still good.
Aug 14, 2009 | Element Electronics FLX3210 32 in. LCD TV
Screen goes dark after few minutes
check your LCD inverter maybe there is loss connection or some parts damage from inverter.
May 05, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Screen goes dark, sound goes quiet...
I have a sony KDF-E60A20 projection tv. The picture would go out for about 30 seconds and come back on. It would continue to cycle this way. The green power light would stay on and not flash. The sound would go off when the picture went out and come back on when the picture came back on. I tried taking the bottom cover off the back exposing the fan and blowed it out with a vacuum cleaner, also taking out the bulb and blowing it out. That didn't help. So I ordered a new bulb from Advancedlamps.com and that's what it was. I have now had it on and off for two days and no problems. Cost of lamp was $107.00 including shipping. Good Luck!
May 01, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Screen keeps going dark
thats a lcd failure contact dell tech support 1800629896
Jan 12, 2009 | Dell Inspiron E1505 Notebook
Monitor keeps going dark
It sounds like a LCD backlight problem. Bring it to an authorized repair shop.
Dec 02, 2008 | Dell Latitude D600 Notebook
The monitor turns off and on repeatedly.
Linux and UNIX wget command help --dns-cache=off, Turn off caching of DNS lookups. Normally, Wget remembers the addresses it looked up from DNS so it doesn't have to repeatedly.
Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | Philips Magnavox 15MF400T 15 in. LCD...
IBM ThinkPad T43 Notebook Logo
1,010 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
