Question about Sony 21" Trinitron P202 Flat Screen Monitor
Can i substitute STR-F6654 to STR-F6707, is it the same function in power supply?
STR F6654 is not workimg ,power led is bliking what is the cause?
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
If STR does not work, how do you get the power light ON at its front panel?
May 22, 2017 | Televison & Video
Onida CTV using str f6654 excess volt why?
Check all the related components at the power regulator circuit; after de-solder out the STR from circuit. If all are found OK, the STR is faulty. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in the phrase " My service table today " in the search box of the display window [at the top right]. You'll get related posts gathered for reference.
Jul 23, 2015 | Televison & Video
Hi! i have sanyo televesion, model ts21sf1k. the problem is no power. i replace the power ic regulator STR w6753. but still no power. no voltage out in power supply.
SMPS circuit is not functioning. Check and replace all the associated component to STR. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 24, 2015 | Sanyo Televison & Video
Is str f6707 the right power supply for daewoo tv model DTU-14d3
Schematics to power supply regulator section to many popular brand TVs are given. Search the site with the STR number to your TV.
Dec 31, 2014 | Daewoo Televison & Video
Str f6654 diagram
Check all the solder terminals to this Regulator IC, for any loose soldering. It will be best to resolder all the solder terminals to this IC, by applying a little more solder to each solder terminals, without making any solder bridge short in between adjacent solder terminals. Take extreme care when soldering procedure, as there will be dangerous voltages will be present, even after switch off the set. If you wish to get the schematic diagram for STR F6654, get it from the site linked here. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option. Surf the site with patience.
Jul 09, 2013 | Televison & Video
Light blinking problem in LG 775N ( White ) 17'' CRT monitor
any shortage in secondry side of monitor ..
plz check shoting.
Feb 25, 2009 | Computers & Internet
HDMI Input not recognized
With the power on, load a DVD and wait until it starts playing the movie. Press "Voutput" button - HDMI output (480, 720, 1080) will light upt and you should have video.
Dec 27, 2007 | Toshiba D-R5 DVD Recorder
Computers & Internet Logo
939 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
