Question about Samsung Digimax S630 Digital Camera
My flash does not work
The infrared measures out like it is supposed to but the flash does not work. tried new batteries but nothing.
  • 121 Answers
In the menu on the camera there are several choices of flash you can make, such as fill in, red eye reduction, or off. Make sure your camera is set up as desired. Also, the infrared is used for distance measurement. ..you may need to scroll down past the shown choices.
Posted on Apr 22, 2008
I brought a Dora the Explorer tv with the built in DVD player for my three year old daughter. It came with the original remote controller but I cant seem to get it working. I have tried putting new...
If the remote control you got is its original one, there is no need to set it up with a code. It might have set to work with that DVD player. Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Mar 15, 2015 | Televison & Video
My ex470 goes up but don't works (es temp is alwais 0000)
Check the fuses and battery contacts. Fuses that old can open without any current going thru them. If the battery contacts are corroded then clean them before installing a new battery
Feb 20, 2014 | Extech EX470 True RMS Multimeter and...
Infrared indicator light will not come on all buttons flash multiple times
um..you wont see the infra red with the naked eye..you can only see it using nite vision style equipment..something that shows in monochrome which is that frequency..if it lights up it is supposed to be working..some need reset to the units in use when the batteries are replaced..use the search mode on it..
Feb 06, 2014 | Universal Urc R6 Avex Pre-Programmed...
Remote not working
I have rebooted several times during the reinstallation of the software. I also tried different USB, but no luck! Could it be something with the USB driver anyway? The system says the drivers are ok though.. Does anybody know the life expectancy of the batteries to this remote? I don't think it is the batteries though, because the red light on the remote is bright.
Nov 12, 2012 | Sony Nsgmr1 Remote Control
Tv doesn't pick up signal from remote
Hi Connie,
First of all, thank you for posting your question here at Fixya.
Please ensure that the battery is in good condition. Check the battery terminal for corrosion, Scratch it with fine sandpaper.
If the battery and its terminal is not the issue, please confirm if the remote control emits an infrared by pointing directly the sensor (infrared emitter) to your cellphone/digital camera. If it is working fine, you will be able to see the flash of the infrared through the screen of your camera. Watch the video below.
If you've confirmed that there's no infrared coming out from the remote control then this is an indication that the remote control itself is already faulty. Replace it with new one (part no. 0980-0305-3300 ).
If you can see the flash of the infrared, the IR board inside the TV is faulty. Please inquire at this link for replacement.
Hope I helped you.
Good luck and have a great day!
Jdvillanueva
Jan 11, 2012 | Vizio VL420M 42 in. HDTV
T.v. does not respond to remote control, but does work maually from side buttons
Turn tv on manually.Test the remote control all functions are dead or some functions work other don't?Tries take the remote control parts and clean the inner rubbers buttons between the rubbers insulater and the remote circuitries board and the battery connections + - connections with some rubbing alchahol.Then wait awhile like 20 mins and putting it back together again and putting in new battery in the remote,it might work again.If getting the same result than the remote CPU chip is probally dead,remote control devices are very depended on it CPU chip.Try website like Remotes.com to buy an original remote for the replacement.
Mar 24, 2011 | Vizio 42 in. LCD TV
My K550i got switched off while messaging, and every time when I try to turn it on, just infrared light flashes n nothing happens.. battery is full... when i try to connect it to comp, comp does not show...
maybe the infrared beam is not emited normally. checkout how to see the infrared from article posted at: http://www.unique-stuff.co.cc/fixing_remote_control_check_infrared.html
Jan 15, 2010 | Sony Ericsson K550i Cellular Phone
Our controllers won't work with new batteries.
Has the old batteries leaked and corroded the battery contacts?
If so the contacts will need tp be cleaned.
If the controllers use infrared LEDs you can test these controllers to see if the controller (infrared LED) works by pointing the controller at a digital camera. When you press the buttons on the controller you should see a light flash from the controller's LED in the LCD screen on the digital camera. If you don't see the LED flash then the controller is faulty.
If the controllers work then they probable need re-programming especially if they are universal types. I don't know how, you need to check your manual for the controller.
Nov 29, 2009 | Microsoft Scene It : Box Office Smash
Remote was not working well, called Toshiba. Recommend removing batteries & pressing all buttons. That worked for a while. Then nothing. Purchased new remote and it does not turn on TV. Is the infrared...
check out if the infrared is emited from your remote control, if it is NOT, then there could be problem with your infrared receiver embedded in the tv set.
to see this infrared beam, you need to read the article posted at http://www.unique-stuff.co.cc/fixing_remote_control_check_infrared.html
good luck
Nov 03, 2009 | Toshiba 36AFX62 36" TV
DVD Recorder TT 1620 The remote quit working. I changed battery sill nothing. Can I order a new remote or is this a contact problem with the battery?
Battery contact, broken wires, desoldered led emitter or other component on the circuit board, leads on the circuit board damaged by battery leakage, dirty contacts on keypad and/or on circuit board (only if just some of the buttons don't work).
Listed above are some possible reasons, could also be a fault in the infrared receiver section on the dvd unit, you can test if the remote is flashing by looking at the emitter (front end) through a cell phone camera while pressing the buttons on the remote - if it works you will see a led flashing inside the remote.
youtube showing such a test:
http://www.youtube.com/watch?v=DLx4zBKTSiM
regards
Triarcuate
Oct 02, 2009 | Televison & Video
Samsung Digimax S630 Digital Camera Logo
91 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
