Question about Dell Dimension 2400 PC Desktop
My dell dimension has all green lights but the d is orange
  • Dell Master
  • 5,660 Answers
Dell Support > Dimension 2400 desktop computer > Service Manual >
Advanced Troubleshooting.
I'm going to change up my usual method of providing a solution for a Dell
product, and finding information on their support website.
Navigation around Dell's Support website leaves a lot to be desired.
Start with,
A) Type - Dell Support in your browser search bar, and left-click on the
search icon
B) This is where it will take you,
http://support.dell.com/
C) Now left-click on - Start Here, in the green button, under the heading -
Support for Home Users
D) Under the - Support Options heading on the left side, go down the list,
and left-click on - Manuals
E) Give it a couple of seconds, and the - Get Manuals for Dell Products,
window will come up.
F) Under the middle heading - Choose a Model, left-click on - Select Model
in the green button
G) Now click on - Desktops
H) Click on - Dimension
I) Scroll the list down, click on 2400, then go down, and click on - Confirm
J) Click on - English
K) Under the blue HTML Documents heading, left-click on View, to the right of
Service Manual
You are now here,
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/index.htm
In the list left-click on Advanced Troubleshooting
Look at the chart under the heading - Diagnostic Lights
"Another failure has occurred"
Going down the chart you see the possible failures that can occur.
Indication is to "Ensure that the cables are properly connected to the
system board, (Motherboard), from the Harddrive, CD drive, and DVD drive."
Rrrright!
Are you aware of how to do this?
How to open your computer case, alleviate Static electricity from your body
BEFORE, you reach inside your UNPLUGGED from power computer, and
also know what cables they are referring to?
Go back to the main menu.
Left-click on Removing and Reinstalling Parts
Left-click on - Drives
Adding or Replacing a CD or DVD drive, shows you where the drive/s are
located.
Replacing a Harddrive, shows you where the Harddrive is located.
The Harddrive, and the optical drives, (CD/DVD) are IDE.
Also known as PATA.
They use this type of interface data cable,
http://en.wikipedia.org/wiki/Integrated_Drive_Electronics
Must be plugged in tightly, and in the correct orientation.
They use this type of power cable, (standard 4-pin Peripheral power cable)
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
This power cable must be plugged in tightly to those peripherals also.
(Harddrive's, and optical drives are Peripheral components)
Anti-Static Precautions:
Your body carries Static electricity.
Static can fry out (Short Circuit), the delicate hardware components inside
a computer.
Computer Unplugged from power, computer case open, working on a table,
TOUCH the metal frame of the open computer case, to relieve your body of
Static.
If you leave your computer in the middle of working on it, upon your return
Touch the metal frame again.
See if the cables above are connected tightly. If there is ANY doubt, it doesn't
hurt to unplug them, and reconnect them.
After you have done so, plug the computer back into power, WAIT 1 minute,
turn the computer on.
Suggestion is to leave the computer case open at this time, and Do Not reach
inside. You are testing. If there is a chance that children may access your
computer before you are done testing, then close the computer case.
My suggestion to leave the computer case open, is that you may have to go
back inside, if the above does not cure your problem.
Would like to know your findings. You can post back in a Comment.
JCV
Posted on Jul 21, 2010
No beeps but lights A B are orange
....and lights C, D are green, and your computer fails to boot up ? (you do not say) (on Dell PCs, which I don't have, the LEDs are usually described as yellow and green. There are four of them on rear of the PC ?).
First go to this webpage:
Product Support
if you are able run the Dell Diagnostics, or if not the ePSA.
Also read this manual - the only one available specifically for Dimension 4100 -
http://downloads.dell.com/Manuals/all-products/esuprt_desktop/esuprt_dimension_desktops/dimension-4100_Service%20Manual_en-us.pdf especially the section on safety. If you have to open the case remember to properly earth yourself.
To the answer to your question, if the 4600 model has the same codes as the 4100 see the service manual for the Dimension 4600 (or get the corresponding manual for the 4100 by contacting Dell support) look here
http://downloads.dell.com/Manuals/all-products/esuprt_desktop/esuprt_dimension_desktops/dimension-4600_service%20manual_en-us.pdf
in the Advanced troubleshooting section. It tells you the problem may be with your memory module(s) and it suggests what to try. I favour checking to see if you get correct errors with no memory inserted then with each module in each slot until all 4 combinations have been exhausted. This likely to tell you what is wrong. You may have to replace a memory module, or work with only one module or replace the motherboard.
23.June.2015
Apr 18, 2014 | Dell Dimension 4100 (-JM0TB01) PC Desktop
While my computer is running the light on the frount is flashing orange. I thought it was always green before. Is there a problem
i removed the connector at "J5J3 pswrd."
this is the blue thing between the battery and the card slot.
i tried everything else such as new M/B battery. remove/change ram. take out extra card, etc.
I just fixed my dell dimension 3100 by doing this.
Oct 05, 2012 | Gateway Computers & Internet
The power LED light is orange instead of green and it won't turn on
Hi! for most dell machines if the power led is orange its an indication of a issue with the ram, try to reseat the ram first.if that doesnt work normally for dimension 4600, there are diagnostic lights that are located at the back panel of the machine, they are four bicolor lights(amber and green) You can determine the exact problem by checking these lights and you can interpret them by going to this website: http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/adtshoot.htm#1112886 hope this helps...
Jun 12, 2010 | Dell Dimension 4600 PC Desktop
Have a dell dimension 4700 with orange steady light?
Turn the machine off and unplug the AC power then hold the power button in for about 30 seconds to drain any residual power. Plug it back in and turn it on, when you see the Blue DELL word press CRL+ALT+D and this should run a diagnostic on the hard drive. If it runs ok you will get a pass or fail on the hard drive. If you cannot get the diags to run you might have a bad power supply or motherboad/processor. I would find a known good power supply and try it before the motherboard.
Mar 09, 2010 | Dell Dimension 4700 PC Desktop
Dell Dimension 5150 automatically turns off
That flashing amber light is usually a sign the power supply is failed or is failing. I would suspect the power supply is the problem in yours. It is the better of the two problems connected with the flashing amber light..the other is motherboard is failing. Arrrr!
hope this helps (it takes a standard- oh say 350 watt 20-24 pin power supply unit.)
Hope an answer helps.
Please leave rating, thankyou
May 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 2400 won't turn off but goes off/on
The diagnostic code that you have specified is a memory related issue please try reseating the memory or swapping with a known good compatible memory stick in adverse case it can be the motherboard as you have specified that A & C take turn being yellow and green.
for more instructions please click here to got to a wizard which guides you through the step by step troubleshooting
Feb 19, 2009 | Dell Dimension 2400 PC Desktop
Dell dimension 8100 diagnostic lights
please refer to the below link...being dell support technician myself this link would give you the best possible help
http://support.dell.com/support/edocs/systems/dsleest/codemess.htm#diagnostic_codes
Oct 18, 2008 | Dell Dimension 3000® Pentium® 4...
Dell dimension 5100, power button has turned orange
If under warranty contact Dell? I had this same problem, a new motherboard and fan assembly fixed this problem. Bad capacitors on the motherbard.
Apr 12, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
No power to my dell dimension 4550
It might be a couple of things bad powersupply or power button incorrect ram module or hard drive settings ,if not then lastly have a bad motherboard which we all hate. you said you have a a green light on motherboard? Did you upgrade or install any new ram ,harddrives etc check make sure they are seated properly in their sockets and free from dust check connection on the ram module make sure it shinny brass color if not you can use an eraser to clean them. If you have upgraded check make sure the ram is compatible to your machine sometimes the wrong ram install can cause no power up problem. Do you have four green lights in the back of machine? Dell new desktop has 4 green light in back of the unit . if all four light are green then system is ok but one out of the four light are orange then you have a problem. You can go onto dell web sight for your machine to check out these lights codes. I hope this help you out some.
Feb 12, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 2400 PC Desktop Logo
117 people viewed this question
Alun Cox
