Question about Ricoh Office Equipment & Supplies
Ricoh FT4822 error code E-5.. What does that mean and what is the fix?
3 Suggested Answers
SOURCE: I have error code sc329 on my Aficio/ricoh copier.
In some models this code means that the laser has aged and must be replaced.
But he would be interesting to know that model is for being safe of this.
Posted on Sep 17, 2009
  • 165 Answers
SOURCE: Erra code E4 how do I fix machine is FT4822
one of the doors open or something u pulled out but didnt put back properly/all the way.
Posted on Mar 30, 2010
How to clear ricoh MP 2001 sc 552 errors code
http://terraofficesolutions.com/forum/index.php?topic=7.0
Quoting from the link shown:
Ricoh Error Code 552, SC552 Fix - Printer, Copier, Fax Machine « on: September 20, 2012, 10:37:12 pm »
This error is a fusing thermistor error, it can mean:
The fusing lamp is not connected. Reconnecting it may solve the problem.
Thermistor is bent or gone bad. You may need to replace it.
Or, the thermistor position is incorrect.
To try and reset the code press:
Clear Mode, 107, Clear/Stop and hold for 5 seconds.
May 08, 2017 | Ricoh Office Equipment & Supplies
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
ERROR CODE E-5 HELP RICOH 4522
If you press the "." key you will get the last 2 digits to complete the error message. For example: "E542".
Whatever the result, 'E5xx' is always related to a fuser error; That means, you have a blown fuse, lamp, or thermistor, and the problem, and the service code can only be reset by a technician in service mode after the fault is fixed.
Nov 25, 2011 | Ricoh Aficio 450 Copier
I have a Ricoh C811DN printer and getting the error message "SC303 - Functional Problem" I downloaded the Ricoh error codes and the description for this code is: Charge Corona Output Error 3,...
Many times, replacing the PCU can fix this problem. For sc303, yellow is the color in question, so try replacing the yellow PCU. If that doesn't fix the problem, you may need to have your printer's high voltage power supply replaced.
Nov 02, 2010 | Ricoh Aficio SP C811DN Laser Printer
Ricoh 3310l fax shows error code 0390H in display. Anyone know what this means?
I've never seen a message like that with the 0390H code. There is no mention of that code in either the user manual or service manual. The closest thing is the sc390 code, which means either the toner density sensor or the developer has gone bad, and typically replacing the PCU can fix that problem.
If the new PCU doesn't fix the problem, you might want to try calling Ricoh for support, since their documentation doesn't mention that code.
Jun 11, 2010 | Ricoh 3310LE Plain Paper Laser Fax
Mar 10, 2010 | Ricoh Office Equipment & Supplies
My richo ft4822 copier is now printing blank copies. Before this, image density was faint even if you set to maximum density.
Clean the optics and change the transfer/separartor corona wire.Verify the drum ground plate connection.
Nov 11, 2009 | Ricoh Office Equipment & Supplies
When i on the machine e-5 error appear and machie not working
What model? AND you need to press the "." key to get the complete code?
However... "E 5xx' " is a fuser code and will not go away until it is fixed and reset in service mode.
"E 1xx" is a scanner code, which means it is either a lamp, fuse , home position sensor...etc.
Mar 19, 2009 | Ricoh Office Equipment & Supplies
188 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
