Question about MTX Thunder 8000 T8154A Car Subwoofer
My subwoofer doesnt work
My wires and everything are hooked up correctly and its not the amp or the head unit..
they cut off and come back on randomly
please help me!!!!!!!!!
  • nikm Apr 22, 2008
    yes it cuts off and comes back on randomly
    the amp gain is on half and the boost is on half
    the sub volume on the head unit is low
  • 975 Answers
You mean that the SUBWOOFERS connected to the amp cuts off and come back on randomly?? did you bring the SUBS level to a high volume ? i suggest to check first the value of the speaker (ex. 4 , 8 , 16 ohms ) matches the same value with the amp . second , hows the subs connected , in series ? or parallel . you will need a multimeter for this task .
Posted on Apr 22, 2008
Hooked everything up in my car right but still no
hook your personal music player to sub amp turn on see if it works if so check settings in head unit or rca wires
Sep 07, 2014 | Car Audio & Video
My 12inch speakers work in my house but when I hook them back up to my truck they dont work . My amp used to have a red light on it but now it doesnt work i bought a new amp and speakers and still nothing...
Could be a number of things. Check all the fuses (the power wire, the amp). Make sure your ground wire hasn't worked loose. Make sure your remote wire hasn't worked loose either (sometimes vibration causes loose crimped wires to come out behind the head unit). Happy Hunting
Aug 20, 2011 | Car Audio & Video
How do you connect the amp with the stereo
  • Choose where to put your new amp. If you are installing subwoofers it's usually best to put the amplifier in the trunk next to or attached to your subwoofer enclosure. If you are going to power your main car speakers with the amplifier then it may be better to put the amp under the passenger's seat.
  • 2
    Purchase the following wiring for the amp: A thick power cable (the thickness required depends on the total wattage of your amp, ask a sales rep or consult your amplifier's manual for the proper gauge) that will have to reach from your battery to the amp (the power cable should also have an inline fuse to protect the amplifier); 3 feet of ground cable of equal thickness as the power cable; an RCA signal cable to carry the left and right signals from your head unit to the amp; a "remote on" wire which can be any thin wire (20 to 24 gauge) that will also run from the head unit to the amp; speaker wire (if you are powering subwoofers you should only need about 3 feet of 12-gauge wire per sub, if you're going to power your main speakers you will need enough 16-gauge wire to reach each speaker from the amp, 12 feet per speaker is usually safe).
  • 3
    Gather the following tools: Screwdrivers, wire cutters, wire strippers, pliers, a utility knife, sandpaper, masking tape with a pen for labeling, 2 crimp-on o-ring ends for the power and ground cables. If you're hooking the amp to your speakers, you'll also need 2 crimp-on female spade connectors for each speaker.
  • 4
    Find a manual with instructions on taking off the dash of your car (not the whole dash--just the head unit, in order to hook wires to the back), and also to get at your car's speakers if you are hooking the amp to them.
    The Installation
  • 1
    Disconnect the ground (negative) cable from your battery. Never work on the electrical system of your car with this connected.
  • 2
    Attach the side with the fuse of the thick positive (+/red) power cable to the connector on the positive terminal of your battery; the o-ring can be sandwiched in the bolt on the connector that connects your car to the battery. Now put the fuse in the fuse holder.
  • 3
    Run the power cable through the firewall of your car (there is usually an opening on the driver's side) and to your amplifier. If your amp is in the back it is usually best to run this wire under the plastic molding that goes along the bottom edge of your car. Be careful where you run the wire because the power cables should never be near the signal or speaker wires.
  • 4
    Find a metal bolt or screw on the metal of your car near the amp to connect the ground cable to. This should be as close to the amp as possible, never more than 3 feet. Unscrew it and clean the metal surface with sandpaper. Attach the ground to it with the o-ring and screw it back down firmly.
  • 5
    Remove your head unit and run the signal and remote on wires from behind the head unit to your amp. Connect the RCA connectors and the remote on wire to the back of your head unit.
  • 6
    (If you are installing subwoofers and not running your normal speakers off the amplifier skip to step 7.) Run the 16-gauge wire from each one of your speakers to the amplifier. On the amp side use the masking tape to label each wire so you know which speaker it is. On the speaker end-strip a 1/4 inch off the ends of the wires and crimp on the female spade connectors with your pliers. Connect the spade connectors to your speakers making sure to match the positive (+/red or white) with the positive terminal and the negative (-/black) with the negative one.
  • 7
    Connect everything to your amplifier. Only strip off as much as you need off the end of each wire to make a solid connection, you don't want any exposed wire hanging out. If you have subs, attach them to the amp with the 12-gauge speaker wire.
  • 8
    Secure your amp to something. If it is in the back you can screw it directly to your subwoofer enclosure. If it is under a seat you may just want to get some straps that hold it down.
  • 9
    Reconnect your car's negative cable to the battery. Test your system and make sure everything works, going around to see that every speaker is on before you put everything back together
  • Feb 17, 2011 | Car Audio & Video
    No sounds coming out of subwoofers
    CHECK INSIDE UR SUBWOOFER BOX ...
    Apr 11, 2009 | Pyle PLAM2300 Car Amp
    Sub cutting out
    Check the 12v wire running from the battery to the amplifier. Also the sony explode is a garbage subwoofer compared to the Alpine.. sony (they say 1200w max but its more like 100w to power the thing) Amp could be going. Is the amplifier hot when running. If there is a burnt smell comming from the amp, its the amplifier
    Mar 27, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
    Have one wire for audio sub out, but two input ports to amp
    This one Wire should be for the +. Try connecting the + to the Head Unit and - to a Common Ground. At the Worst, You will Blow the Amp Fuse if not Correct. The Lead from the Head Unit is Only an Off and On from the Ignition. Please Rate My Response! Thanks!
    Jan 31, 2009 | Power Acoustik PTID-8960 Car Video Player
    Subwoofer doesn't play through ipod, only radio and cd's
    Hook up the remote wire from the head unit (grey w/ orange stripe) to the power antenna wire (blue) on the wiring harness adapter.
    Jan 15, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
    Visonik 350watt Amp Doesnt Come On....
    With your multimeter set to DC volts, the black meter probe on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red probe alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
    Let me know if you have any other questions.
    Oct 06, 2008 | Visonik V117SX Car Audio Amplifier
    Subwoofer Output Not Working...
    first check that the subwoofer function on the actual head unit is turned up,second check that the gain on the amp is at bout half way then check that it is on a lp (low pass setting)
    then check that the boost on the amp is turned up.
    please leave feedback.
    cheers
    Jul 02, 2008 | Eclipse CD5405
    MTX Thunder 8000 T8154A Car Subwoofer Logo
    276 people viewed this question
    Top MTX Car Audio & Video Experts
    Professor_V
    Professor_V
    Matthew Spark
    Matthew Spark
    Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
