Question about GE 24 in. GLD5560LSS Stainless Steel Built-in Dishwasher
Dishes seem to have a powery residue on them after they're clean
After the dishwasher has run a full wash cycle, the dishes seem to have a powdery residue on them when I'm unloading the dishwasher. My appliance is only a year old. What can I do to rectify the problem?
  • 901 Answers
Check inlet water quality for hardness. If salt chamber is provided, fill the chamber with salt meant for washing machine.
Use the recommended wash soap.
Check rinse aid and fill if required.
Posted on Jul 21, 2010
Dishes not cleaning after full cycle running
Your screens are plugged with food residue in the bottom of the unit. clean it out. You can use 1 gallon of white vinegar for your wash after you clean the screens. Start your washer to fill with water but after the water starts, open your door and pore all of the gallon in the unit. Let it now run for 4 minutes and stop it by opening the door. Leave the door slightly open for 1 hour. close the door and let the cycle continue for 4 more minutes. open the door and repeat it a couple of more times. Let it sit all night with the vinegar in it and in the morning - close the door and let the cycle continue to the end. This should help soften and clean out the food particles in the unit. You can repeat the process and get a better cleaning then too. All the scale should be off your dishes now.
Jan 08, 2014 | Frigidaire Professional Series 24 in....
Dishwasher is going on 3.5 yrs old, it worked well for the 1st year but for the last year & half it has been leaving gritty residue on all the dishes. To the point, dishes are being hand washed to...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101//
Mar 22, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
Soap residue on glasses, dishes & flatware...what can I do..I use Cascade & JetDry
Instructions Things You'll Need:
  • Vinegar or lemon juice
  • Gel dishwasher detergent
  1. dishwashers have a rinse aid dispenser. If your dishwasher has this dispenser, fill it up periodically and it will release the appropriate amount of rinse aid automatically at the right time during the wash cycle. This will help your dishes rinse more cleanly.
  2. Rinse aid in solid form
    Some older dishwashers or basic models do not have an automatic rinse aid dispenser. In this case, you can buy rinse aid in solid form that attaches to your dishwasher rack. Solid rinse aid can be hard to find in stores because it is not commonly used, but it can be purchased online.
  3. Vinegar or lemon juice
    Appliance repairmen will tell you that one of the common problems they see with dishwashers is the buildup of excess detergent. If there is too much detergent in your dishwasher, your dishes will not rinse cleanly, no matter how good the dishwasher is or how much rinse aid you use. To clean the excess detergent that has built up inside your dishwasher, put 3 tablespoons of vinegar or lemon juice (concentrate is fine) in the empty dishwasher and run the dishwasher through a complete cycle with no dishes. Do this twice, for two complete cycles of the empty dishwasher with only vinegar or lemon juice added. The acid in the vinegar or lemon juice will break up the detergent that has built up in your dishwasher's interior.
    After you have cleaned the detergent buildup from the inside of your dishwasher, follow the steps below to keep the buildup from happening again and to help your dishes rinse cleanly and prevent residue from accumulating on the dishes.
  4. Gel dishwasher detergent
    Switch to a liquid or gel dishwasher detergent. Any brand will do.
  5. Fill one compartment half full Dishwashers will effectively clean dishes with much less detergent than manufacturers often recommend. The bleach in the detergent, combined with the extremely hot water used in the dishwasher wash cycle, will clean and sanitize your dishes completely, even in small amounts, and using less detergent helps prevent buildup and residue from accumulating on your clean dishes.
    Fill only one detergent compartment(the one that snaps closed) half full with gel detergent. Snap the opening closed and run your dishwasher as you normally would. Your dishes will come out sparkling clean with no buildup or residue, plus you'll save money by using less detergent!
Feb 02, 2011 | Dishwashers
White powdery film is on dishes at end of cycle.
Too much detergent. the amount of detergent should vary with the amound of soil left on the dishes. Most users will pre wash their dishes in the sink, but still use the full recommended amount of detergent. There is no soil for the detergent to bind with, so it builds up in the pipework of your dishwasher. when the water evaporates during the drying cycle, the detergent residue is left behind on your dishes. Run a cycle or two with your dishwasher empty. add a cup of white vinegar to each cycle, but dont add any more detergent. After that, cut your detergent amount by half, and see if your issues go away. if not, please post the model and manufacturer of your dishwasher.
Nov 18, 2010 | Dishwashers
The center tower is not able to go all the way down after a cycle
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Dishwasher Residue and Film on Dishes
heatman101
l;
Jul 17, 2010 | GE Nautilus 24" Built-in Dishwasher
I have powdery residue on my dishes and i ran it twice. I ran the rinse cycle after that and they are still yucky. What should i do?
heatman101
Jun 25, 2010 | Maytag 24 in. MDBH940AW Built-in...
Dishes have a powdery residue
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
NOTE(((excessive calcium build up inside the dishwasher can cause this as well. I recommend cleaning the inside of the unit with a dishwasher cleaner called Dishwasher Magic. its good stuff and it will get rid of that calcium build up)))
Jul 30, 2009 | Jenn-Air JDB1105AWS Stainless Steel...
After running a full cycle dishes are covered in detergent residu
www.dishwasherfilter.com has a great product specifically for this problem. it filters the water going into your dishwasher removing the hard minerals that cause this problem. after the first load my dishes looked amazing. it is very affordable and fits right under your sink.
Apr 01, 2009 | Asko D3251HDSS Stainless Steel Built-in...
Putting my fdw60 aquarius dishwasher back together
check that the place where u put the salt in is screwed in tightley, then, i find giving the dishes a hand wash and they come up clean , ti will work fine, because if you notic, take a glass with white powdery residue out of the dishwasher and rinse it under water, and the residue is still there, so they need a good scrub and after that , they can be washed as normal!
Jul 03, 2008 | Hotpoint 24 in. FDW60 Free-standing...
GE 24 in. GLD5560LSS Stainless Steel Built-in Dishwasher Logo
178 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
