Question about Acer AL1916W 19" LCD Monitor
Acer AL1916W monitor went black permanently. Replaced it with a different monitor, and all is OK. Connected the Acer to a different PC, and is still black. How do I test the backlights and inverter?
SOURCE: Acer AL1916W 19" LCD Monitor '' no power''
There was a busted fusible coil in series with the main line supply. Changed it with an ordinary fuse. There are available voltages for 5V and 12 volts but still there is no power indication on the panel and never turns on. I checked the backlight but no output power. the system control has power supply of 3.26 volts. What really the problem of this unit?
Posted on Apr 04, 2008
kookabugga
SOURCE: SCHEMATIC LCD MONITOR AL1916W FROM ACER
Schematics are in the Service manual here → https://www.mk-electronic.de/hersteller/PDFDokumente/Acer/Display%20Product(DP)/19/AL1916Wc.pdf
Posted on Jan 13, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: THE ACER MONITOR AL1711 BLINKING
This is not a monitor problem, it's normal behavior. The monitor does this when it's turned on but no signal is coming from the computer. The solution is to turn off the monitor when you shut down the computer, and turn it back on next time you start it back up. The simplest way to handle this is to get a switched surge-protector strip and plug all your computer system into it (computer, monitor, printer, etc.). Then after the computer shuts down you flip one switch and everything is off. It's also protected from power line problems, and that's always a good idea.
Posted on Feb 07, 2009
bunnydawg
  • 5158 Answers
SOURCE: Acer AL2017 Monitor
you will need 3 or 4 ( forget now) 220 uf 25 volt and two 1000 uf 25 volt .... just finished putting this one back together and it's great.
Posted on Apr 08, 2009
  • 36 Answers
SOURCE: No backlight. I'm looking for a schematic for the
<p>How about the whole <A href = "http://www.go-gddq.com/upload/2009_06/09060313346662.pdf">Service Manual</a> ?</p?
Posted on Jun 17, 2009
I'm using the AL1916w 19" as a secondary monitor for my laptop. I went to turn it on the other morning whilst it was connected and it didn't turn on. I've tried it with other computers and it seems to...
Look for bad caps just like other failed monitors as shown in my album first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 03, 2010 | Acer AL1916W 19" LCD Monitor
I have owned an Acer X241W for 2 1/2 years. I have tried every solution listed above (except main board replacement), and more. None are long term fixes. I have sent the monitor back to Acer for repairs...
mazricool, Will monitor do same strange things when connected to a different "known-good" computer other than YOUR'S ??? What is it that your unit does that you don't like about it? What is the pc operating system that you are using it with. Try installing monitor on different pc first. 12fixlouie
Apr 29, 2010 | Acer AL1916W 19" LCD Monitor
Acer AL1916W about 2 years old. Turned on this
Bad caps in the power supply, common problems with 2-year old monitors, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 25, 2010 | Acer AL1916W 19" LCD Monitor
My acer al1916w displays the image for 3 seconds then goes black
Sounds like your video card. Check to make sure it's connected properly. If so, check to make sure it's properly seated to *********** board. The possible issue could be the card is connected enough to display the picture, but not enough to communicate with the monitor to stay on because it has an active feed. Best of luck fixing it
Oct 14, 2009 | Acer AL1916W 19" LCD Monitor
Black screen after a year of use
Sine a flashlight on the screen and check for a dim image. If you see a dim image the back light needs to be replaced. After doing that you will want to try using another monitor cable and see if that helps. If it doesn't with the computer on and the monitor on disconnect the cable from the computer. If the monitor shows a no signal error the graphics card needs to be replaced.
Sep 07, 2009 | Acer AL1916W 19" LCD Monitor
Monitor colors are not displaying correctly
Hi, At the worst it is a blown monitor, but have hope. 1st try a new or known good lead, between monitor and PC. 2nd put monitor with own lead on good PC. if 1st works = result. if 2nd and monitor is same, suspect monitor, however, if 2nd works ok on other PC, then look at ur vid card. Either way, this test sequence should save you some $. Be lucky.
Aug 15, 2009 | Acer AL1916W 19" LCD Monitor
After loading windows Vista screen says no signal
steve, i dont think there is any problem with monitor. restart ur pc in safe mode, change resolution to 1440X900.
Mar 02, 2009 | Acer AL1916W 19" LCD Monitor
Acer al1916w wont turn on
My living room monitor faced the same issue before.
I called up Acer, and they fixed the power LCD board in the monitor.
Do not buy a new one yet, unless the warranty is over.
Jan 01, 2009 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Blacking out
This is not a setting or driver issue! The best way to determine this is to connect the monitor up to another device to see if the same thing occurs! If it does then your backlight is in bad shape and it is starting to go bad. It will generate enough power to display some images, but when it continues to be on for a certain peirod of time it goes black. This is common when the backlight is starting to go bad!
Oct 04, 2007 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
49 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
