Question about Philips DVD726AT DVD Player
I have sound, but no picture
I put a DVD in and was watching it. I hit Stop on the DVD remote twice and all of a sudden I don't have a picture, but I still have sound. We've tried all kinds of scenarios with the TV, to no avail. We've tried the Video and Audio cables and nothing changes. Any suggestions?
  • 121 Answers
Most of the newer electronics are computer controlled. It is also best to unplug them for a couple of minutes (for a reset), and then try ALL of the TV input choices, as these have a tendency to change and not tell you
Posted on Apr 22, 2008
Whar channel should be on to play a DVD?
It depends on which input you have the DVD plugged into. The pictures below show the different inputs. One of those should match what you see on the back of your DVD. If you don't know which, you can turn on your DVD player and hit the INPUTS button shown on the picture of the remote control shown below. Or, if it's connected to one of the inputs pointed to by the DIRECT SELECT arrow on the picture of the remote control, you can go there directly from watching the TV. phillip_d971_1.jpgphillip_d971_2.jpg
Apr 12, 2011 | Zenith Z50P3 50 in. Plasma TV
I need to unlock my dual xdvd8181 i need password
Put a dvd into the player, when you hear sound hit the STOP button twice on your remote. Enter the code 26604 and hit enter. That will do it. Make sure your parking brake wire is grounded.
Feb 12, 2010 | Dual XDVD8181 Car Video Player
I have a 2006 cadilliac cts that came with a factory dvd player. i can watch movies until i put it in drive. when i put it in drive the scree goes blank and i can only hear the movie. Is there a way that i...
You can try the procedure for the VM9311TS model (the one I have) - I don't know if it'll work but it's worth trying. Put in a DVD, and let it start playing. Then hit STOP on the remote twice, and enter the code 1264. If you were able to see the actual movie at this point, you'd see a menu pop up. Push down twice, then ENTER. At this point the blue screen should clear and you should see the movie itself. You'll have other options on that menu, like a macrovision option to allow you to see burned DVDs. Set what you like, then on the remote, hit SYS SETUP twice to lock in your choices.
Nov 14, 2009 | Jensen VM9510 Car DVD Player
Problems with Sansui VRDVD4005 DVD Player / VCR Combo.
the only problem i have is the remote reciever works only part time. I bought aa new remote control but didn't help.what do you think the problem is.
Mar 02, 2009 | Sansui VRDVD4005 DVD Player/VCR
Curtis DVD Player
Hi Kathy, The DVD player has accidently set to the wrong video ouput or P.Scan mode. Remove the disc from the DVD tray and press the P.Scan button on the DVD remote control untill the pictures comes back. You should receive the picture within three clicks on the P.Scan button. Thanks, Mike
Nov 02, 2008 | Audio Players & Recorders
Wont play dvd jensen vm9311
You can bypass all that. Here's how:
This will work without having to do anything to the pink wire - just tape it and leave it alone. But the next time you unhook your battery cable you will have to put the code in again.
Put in DVD
When the blue screen comes up, hit STOP twice on the remote
punch in 1,2,6, and 4
hit DOWN 1 time
hit PLAY/ENTER (although you can't see it, this turns off the parking brake bypass security feature)
**at this point the display became visible and you will now see the menu which makes it much easier.
hit DOWN one more time to change macrovision
hit PLAY/ENTER
hit SYS SETUP twice to save and exit menu
From now on, you can just put in a movie and it'll start - no more grounding or toggle switch procedure, and you don't have to use the e-brake.
Oct 22, 2008 | Jensen VM9510 Car DVD Player
Dual problems
Ground the parking brake wire to any bare metal area on the van this should allow you to watch well in motion.
then do the following.
** Insert Audio CD
** Press Play
** Hit Stop Twice
** Use remote to enter 26604
** Hit OK
** Take out Audio CD and Insert a DVD
Aug 26, 2008 | Dual XDVD8181 Car Video Player
Burnt DVDs
Try this (this is the procedure for the 9311TS model, which I have, and it should be the same for yours too) - put in a regular movie, and do what you need to do in order to be able to watch the movie (cycle the e-brake handle, toggle a switch - however you have it set up). When the movie comes on, using the remote, hit STOP twice, then type in 1264, and a hidden menu will appear. This menu has the macrovision toggle - turn that on. While you're in there, you can also disable the parking brake bypass (turn the bypass on - no more e-brake handle or toggle switch!). Then hit the SYS SETUP button on the remote twice to save the choices you made, and you should be able to watch the burned movie then. You'll also find that it's nice to be able to just stick a DVD in and have it start playing.
Jun 10, 2008 | Jensen's VM9312 Car DVD Player
JENSON VM9512 CODES FOR BRAKE BYPASS
turn on the player, start the radio option, go into the setup menu, tap the language tab, ON THE REMOTE press "stop, stop, 5,4,3,2,1" This will bring up the secret menu, you do not need to connect the pink wire
Mar 10, 2008 | Audiovox VM9512 Car DVD Player
How do you take progressive scan off
eject the tray and press the stop button for 5 - 10 seconds...if not stop then try pause button
Nov 17, 2007 | TruTech TT320
Philips DVD726AT DVD Player Logo
62 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
