Question about Samsung HCM653W 65" Rear Projection Television
I have a above Samsung TV (HCM653W). RGB color not right. Ghost the image. I replaced the AssyPCB,SUB,PCL54R,P54A but no solutions. Which pcb board I should try to fix the problem. There are audio and video on the tv, but not right not pleasure viewable pictures. Please advise me If you have any idea.
Thanks for your time.
Nicky Patel
  • DollarTech Jul 01, 2008
    I checked all fuses on power supply board ok. This time I am sending a image from the TV screen for you to get better idea.
    Thank you again.
  • Anonymous Oct 12, 2008
    it is the exact same but the red is off
  • 3,130 Answers
You will need to check the plus and the minus convergence voltages in the main power supply. There are a couple of circuit protector fuses that go bad. Do not replace these untill you replace the convergence IC's or you will cause more problems in the main power supply. Good Luck
Posted on Apr 23, 2008
Ghost-image on VPL PX31
There is dust in RGB Panel,that ghost image is actual dust.It need to clean.
Mar 16, 2010 | Sony VPL PX31 Multimedia Projector
Samsung HCM653W 65 in rear projection tv
its the convergence board/bulb problem for sure.check that and replace it.every thing will be fine.thanks.
Aug 22, 2008 | Samsung HCM653W 65" Rear Projection...
How to reset nokia mobiles life timer to ''0''
Nokia life timer is a counter that keeps track of the Total call time of your phone. It will show how much the phone has been used, and it?s the best thing to check if you?re planning to buy a used Nokia Mobile.
To see the Total Call Time or the life timer counter, On the standby screen type the following code *#92702689# (Easy way to remember this is ? *#war0anty#). And it will pop up a message that shows the life timer in hours and minutes.
Here is a detailed procedure to make this life timer zero.
The following files are required to reset the life timer:
  1. Nemesis service suite link: Download from Here
  2. file: Download Here
1. Download and Extract the file, and Download Nemesis Service Suite.
2. Install Nemesis Service Suite on your Computer, It won?t take much time.(select the first option)
3. Install Nokia Cable Drivers (No need to install, if you have Nokia PC Suite already installed)
4. Connect The Phone in ?PC Suite? Mode to the PC
5. Open Nemesis Service Software
6. Click on ?Scan for new Device? Button on Top right Corner
7. It Will take a few seconds to scan, and it will load up the software interface after communicating with the Phone.
8. Click the ?Phone Info? Button.
9. On the Bottom, Select and open the ?Permanent Memory? Tab, which is next to the Fbus info.
10. Click the ?Write? button on Below right, and open the Extracted file on your PC.
11. After the file is opened , it will immediately start writing it to the Phone?s EEPROM Area.
12. The Procedure will end when the progress bar reaches 20%. This is normal , and on the bottom right side, it will display its done.
13. Unplug the Phone, and Restart it.
14. After boot up, Check the life timer .
Note: This method has been tested on following devices: Nokia 6630, 6670, 6680, 5500 sport, 5700XM, 6110 Navigator, 6120 Classic, N70, N72, N73,N76, E50, E51, E61i, E65, N80, N91, N95, N95 8GB, 5800XM Mobile devices. If you want to try it on other S60v3 or S60v5 mobiles, do it at your own risk.
  • Power Failure During Writing will cause damage to the Phone, And there is a chance that it might brick the phone as well.
  • Loose, worn out Data Cables Might fail the Writing process, and there are chances of damage to the EEPROM area of the phone.
  • Do not attempt this with phones that are not included in the confirmed list.
By:- Mohammed Abdulhadi
on Jun 21, 2010 | Cell Phones
Color red is warping or ghosting
You need to have the convergence chips replaced.
It liiks like 3D?
Thanks for using FIXYA
Oct 26, 2009 | Televison & Video
HCM653W color convergence off
Ck low ohm resistors 3.9 omh and pico fuses they look like resistors but they are green or yellow 5amps, 6amps,sometimes after replacing STKs there is bad resistors or open pico fuses.
Dec 22, 2008 | Samsung HCM653W 65" Rear Projection...
Samsung HCM653W Convergence problem
CK low ohm resistors and pico fuses some are green,some are yellow .they will be around ics some may be under heat sinks that hold STKs.
Nov 29, 2008 | Samsung HCM653W 65" Rear Projection...
Convegence board
your model has the Ics and resistors on the sub delection PCB board. You can get a new replacement board at the following link with free tech support to help you install it as it the entire large circuit board on the right side of the set. You need the board called the P54A chassis Sub deflection board under their Samsung parts category.
Heres the link.
Aug 16, 2008 | Samsung HCM5525W 55" Rear Projection...
Samsung HC-P4752W 47 in. Rear Projection bigscreen TV
You dont have to remove the aluminum heat sink. The ICs are attached with screws and then just unsolder the ICs from the circuit board and then replace the new ics into the pin hole locations after applying heat sink compound onto the back then screww the new ICs to the heat sinks then solder the pins. Very easy repair.
Jun 19, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung HCM653W 65 in. Television
I do not know, what the problem you have in your tv M/N:HCM653W. I have the same Model samsung tv. I have image ghosting problems. As per tech I replaced the Pcb, part AA95-01846D, Which did not fix the problem. I still have it for sale. The power supply pcb is no longer availabe as per" I have no idea where you can find the power supply board. If you find it,please let me know.
Jun 18, 2008 | Samsung HCM653W 65" Rear Projection...
Samsung lcd tv le40r8
if the unit is under warranty call samsung for the nearest authorized repair place. the problem is a bad main board.
Feb 24, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Samsung HCM653W 65" Rear Projection Television Logo
108 people viewed this question
Jerry Greenberg
Jerry Greenberg
