Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
How do i fix my flash drive sandisk - SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
  • 4 Answers
Don't bother to fix it, buy a new one as your old one will not be reliable.
Posted on Jul 20, 2010
Read-only files and how to them?
Possibility
Firmware flash drive corrupted (the disk is write protected).
Solution
To repair damage to the firmware, the solution can be found on google seach engines. Example; Fix transcend flash drive, Fix sandisk flash drive, Fix PQI flash drive, etc.
Dec 15, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Not open the memory card the computerslove probleam
If the flash drive is detected but error, there has been damage to the partition table or firmware. But, if the flash drive is not detected, there has been a hardware damage.
Solutions, flash drive detected but error
To fix the SanDisk flash drive, use the U3 LaunchPad software. This software can be used to saved data, repair the firmware and update the firmware.
For Win Xp, download from here SanDisk Support
To Win 7, download from here SanDisk Support
Solutions, flash drive not detected
Chances are, there has been cracked solder. To fix this, open the flash drive casing, use a soldering iron to heat the solder component flash drive.
Hope it helps
Sep 10, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Never used a sandisk before,wanting to find HOW TO USE.
Just fix it to the computer and use it as a normal flash drive! Of course it will install it's software first.
Sep 07, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
My 4gp pen drive is suddenly showing o bytes. what i do
To fix the SanDisk flash drive, use the U3 LaunchPad software. This software can be used to save data, repair the firmware and update the firmware.
Hope it helps
Sep 03, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk 4gb cruzer micro showing 0 bytes and not accessible, i have valuable data in it
Files on a flash drive canbe corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon andthen click on the flash drive you want to remove and then remove the flashdrive when the computer message says it is Safe to remove.
To restore the flash drive you need to format the flash drive, but you willlose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm www.CardRecovery.com
Feb 04, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Format 8gb sandisk micro sd problem
Often times, these jump drives have a tiny, nearly invisible read-only switch on them. Check to see that it isn't set to read only, which will inhibit formatting, among other things.
Jun 14, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
SanDisk Titanium 8GB flash drive with files will not open
Microsoft has a fix for USB and other external peripherals.
http://support.microsoft.com/kb/925196#fixit4me
Hope this solves your issue. Good luck and all the best!
Greg
May 17, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Sandisk flash drive
Vista has not been out long enough for any company to state that there product is compatible. I would check there website to see if they have updated drivers that will make the sandisk usb drive compatible. This may fix the problem!
Nov 24, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Dropped my sandisk cruzer micro 512MB flash drive, computer cant read it now
I have had the same issue. Sometimes static builds up and discharges into the drive. Most USB drives are made to tolerate such problems, if it's fairly new and not obviously damaged outside, send it to sandisk for a replacement under the "poor workmanship" clause.
Nov 05, 2007 | SanDisk Cruzer Micro MP3 Player
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
146 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
k24674
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
