Question about Boating
What was the year that the Slickcraft SS140 was built and what is the beam width?
  • Rog Matthews
    Rog Matthews Jul 20, 2010
    I know that it was built in the early 1980's - not in the 1990's
    Top Expert:
  • 79,024 Answers
This model was built in 1965 here is a link to the PDF artile about the history of the comapny if u are interested in reading it.
http://www.hope.edu/jointarchives/quarter/winter05.pdf
Not much info exists but the beam is stated in one article as 8'0"
Posted on Jul 20, 2010
  • yadayada
    yadayada Jul 30, 2010
    we just wnet on what was avail onm the internet, and what i show is the 60's, I tried why the poor rating?,
  • 360 Answers
It was built in 1996 and beam width should be around 102
I am looking for a wiring diagram for 1990 Skeeter ss140 bass boat.
Sorry it is just to old and no free diagrams are on the web.
Feb 17, 2018 | Boating
Headlight low beam on my envoy 2006 not working
The headlamp driver module (HDM) is an electronic module that provides electrical power to the vehicle low beam headlamps. The HDM is controlled by a pulse width modulated (PWM) ground signal from the body control module (BCM). The BCM determines the desired lamp intensity using the ambient light sensor, multifunction switch and the park brake switch as inputs. In general, the HDM will operate in 1 of 3 modes:
Reduced Intensity Mode: This mode is used by features that do not require or allow maximum low beam headlamp intensity such as daytime running lights (DRL) (nominal: 85% duty cycle).
Full Intensity Mode: This mode is used by features that require full low beam headlamp intensity such as low beam headlamp operation in manual or auto modes (nominal: 100% duty cycle).
Off Mode: This is the default mode of the system that will occur when none of the features described above are active. The BCM will deactivate its PWM output (0% duty cycle) during this mode.
The normal battery voltage input to the HDM must be between 6 and 16 volts DC to operate. Any deviation to these values could cause improper operation.
Major components of this system are the BCM, HDM, ambient light sensor, multifunction switch, park brake switch and low beam headlamps.
DTC B2575 Headlamp Control Circuit
When the body control module (BCM) senses a request for headlamp or daytime running lamp (DRL) illumination, the BCM sends a pulse width modulated (PWM) ground signal to the low beam headlamp driver module through the low beam headlamp driver module control circuit. The low beam headlamp driver module will illuminate the headlamps, adjusting the intensity based on the PWM signal received
You best bet is to take your vehicle to a ASE certified repair shop or the dealer >
Jan 15, 2016 | GMC Envoy Cars & Trucks
Do you know the BTUs for the five burners on this cooktop?
WEIGHTS & DIMENSIONS Approximate Shipping Weight 38 lb Cabinet Width 36 in Cutout Dimensions (Width x Depth) (In.) 33-7/8 x 19-1/16 Net Weight 33 lb Overall Depth 21 in Overall Height 3 1/16 in Overall Width 36 in Space Required Below Cooktop 0 7/16 in
  • POWER / RATINGS POWER / RATINGS Burner BTU Ratings (000's/BTU) - LP Gas (1) 9.4; (2) 7.0; (2) 4.0 Burner BTU Ratings (000's/BTU) - Natural Gas (1) 12.0; (2) 9.5; (2) 5.0 Volts/Hertz/Amps 120V; 60Hz; 5A
  • ACCESSORIES ACCESSORIES LP Conversion Kit Included
  • WARRANTY WARRANTY Parts Warranty Limited 1-year entire appliance Labor Warranty Limited 1-year entire appliance
  • GE 36 Built In Gas Cooktop JGP636WEDWW GE Appliances
    Oct 27, 2015 | GE Profile JGP636 Gas Cooktop
    How do I narrow the scan beam on the n410
    The scan beam is fixed and can not be adjusted. However moving the n410 closer to the bar code will reduce the width of the beam itself. The narrow beam is designed to accommodate static stands as well as manual use.
    Simply hold the n410 a few inches away from the bar code and the beam will be able to read the code underneath. No adjustment except the distance between the n410 and the barcode is required.
    Nov 24, 2014 | Computers & Internet
    Height of high beam
    Take your car and park it 10 ft from a wall or a building, now take a tape measure and measure 36 inch's from the ground up and draw a line so its the same width as your car front end , turn on your head light and see if center of your lights our hitting the line you just drew , if not adjust them until they do. The right side should be just to the right a bite and the left one straight a head .
    Aug 05, 2014 | 2002 Cadillac Deville
    Mc9190 laser beam width is too wide. I need to change the width of the beam. How can I do this?
    Hello
    Contact Motorola Solutions Get Support or Zebra Technologies
    Support Downloads. They aren't helping on FixYa yet so it is best to reach out directly.
    Mark
    Motorola Mobility Support
    Apr 12, 2013 | Motorola MC9190-GST
    Good Evening, My mum purchased a kupperbusch built in oven over 15 years ago. The grill is no longer working and fan has gone. I will like to purchase a new one the same size. H 89cm W 556.5 would this...
    Most ovens are based on a modular 600mm width cupboard dimension. Heights can vary but that not so much of a problem so you should be ok with most new ovens.
    Check on suppliers websites for details.
    Dec 09, 2010 | Kuppersbusch Ovens
    I need an owners Manual for a 1976 AMF Slickcraft 24 foot boat
    good luck AMF american molded fiberglass went out of business several years ago.
    Mar 17, 2010 | Boating
    How do i change the bulb
    Unscrew the bottom portion, where the batteries go. Then unsrew the top where you can adjust the beam width until it comes off. Very carefully pull the bulb out and replace the old bulb with the new. The Reassemble is the reverse of the procedure.
    Jun 23, 2009 | MagLite RX3019 Rechargeable Flashlight...
    Boating Logo
    115 people viewed this question
    Top Boating Experts
    Steve
    Steve
    ray gallant
    Fabrice Wolters
    Are you a Boating Expert? Answer questions, earn points and help others
