Question about Radio Communications
Feedback through fm radio
I have feedback through the fm radio in my truck, the cb and fm radios use the same antennas, dual whips. Also resption of my output is scratchy at times. Any feedback. The cb is a texas ranger 296
    Problem Solver:
  • 5 Answers
Try using a seperate ant for ur radios
Posted on Jul 26, 2010
What antenna for the uniden pro 520xl to install on a F150
The longest one you can get, or make fit. 102" whip would be the best, just keep as much of the antenna away from the body of the vehicle as possible. When it comes to CB, the closer you can get to the 102" whip, the better it's going to work for you.
Jan 20, 2014 | Uniden Cb Radio Pro 520
SWR overload on sideband
Try a different antenna, my thinking on this is that the antenna has an issue where it can deal with the 4 watts of CW power and not the extra PEP on SSB mode.
May 11, 2013 | Galaxy Radios DX-949 CB Mob ssb Swr...
How do you adjust antenna
What is the make and model of the antenna? Most have a set screw on the whip above the spring. You loosen that and move the whip up and down
Mar 24, 2013 | Cobra 29 LTD CB Radio
I have spotty reception on a handheld CB and was wondering if there is a testing procedure I can use to check the antenna and radio. I have a multimeter. It's a radio shack handheld with weather bands...
The antenna is your problem not much gain. Height is everything tx and rx. Although it would not compare to a conventional cb size negates performance. Seeing is believing in this case hearing get adapter to connect to standard coax of antenna. (PL259) to BNC Coax Adapter Radio Shack sells them. And dont ask or buy any radios there. They are hardly the radioshack of choice anymore.
  • If you put 4 watts into a four-foot antenna, you will get the same power out of that antenna as if you were putting 2 watts into a 102-inch whip.
  • If you put 4 watts into a 3-foot antenna you will get the same power out as if you were putting about 1.5 watts into a 102-inch whip.
  • If you put 4 watts into a 7.5 inch antenna on a hand held CB, it would put out as much power as a third of a watt into a 102-whip.
  • If you put 4 watts into a 102-inch whip antenna, it is the same output as if you put 11 watts into a 3-foot whip.
  • If you put 4 watts into a 102-inch whip antenna,, it is the same as if you put 14 watts into a 28-inch antenna.
  • If you put 4 watts into a 102-inch whip antenna, it is the same as if you put 54 watts into a 7.5 antenna.
May 21, 2011 | Cobra HH 38 WX 40-Channels Handheld CB...
Extndedmods done not problem tansmiting in am radio go back to 10 meter or they do not here my voice clear or a load nois lake a long roger bit or does not trasmit ad all i have to reset again no...
make sure NO ONE clipped your modulation limiter!!!! the Magnums are way over modulated of a radio. any mods will cause trouble. you are probably getting a feedback making it sound like a roger beep.. also it will depend on your SWR's make sure they are good on the band that you are talking on. ie.. no antenna on the market can work 10-12meters except maybe the 108"whips $17.99 and the predator 10k.... so be sure to check the swr's on ever channel that you would operate on. like ch 19 and 28.xxx and be sure first. high swr's will cause feedback on any radio.
Feb 23, 2011 | Magnum OmegaForce S45 CB Radio
Static increases when i push on the gas
antenna needs a ground or a better ground. 102 whip needs a very good ground.You could try another antenna.
Apr 16, 2010 | Cobra 29 LTD CB Radio
I just installed a Stryker 490HP in my big truck, the most power I seem to be able too pull is around 30-35 watts from 125 before I get some serious feedback when I key up? Rookie
RF feedback into the radio most likely from bad SWR or poor ground counterpoise at the antenna. Change out antenna to something more capable of use with this radio. Maybe a 102 stainless steel whip or Wilson 1000 or K40 type.
Feb 02, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
I was wondering what was the range for the radioshack TRC-447 cb radio with a good cb antenna
Antenna :
-should be tuned, have good coax with no pinches, whip is centered over highest flat metal surface, no metal beside adjacent to whip, power is wired to battery direct, not to ignition or cigg lighter. whip is wiped clean of corrosion, whip is up, longer is better.
Praire City car-to-car: 15-20 km's
Praire Rural car-to-car: four-thirds over the horizon. Probably 60 km's.
Alot further over water.
Less within trees and mountains/valleys.
Google "Ham radio" & "ducting" "inversion" "skip" "sun-spots"
these refer to a condition where a radio signal getting stuck between the upper and lower atmospheres and travel intact for 1000's of km's (canada to mexico for example)
Sep 06, 2009 | Radio Shack TRC-447 CB Radio
With my CB I am getting feedback through the am fm radio speakers
Hello there:
the shielded coax rgu-45 series is probably the best one for this application also if you run the radio to a different fuse or u can also get a surpression filter that goes on the coax line I own a WL9000 KW. i had the same problem untill i got the filter installed at a loves truck stop in texas and no more problems since ok?
drive safe and best regards mike (warner transp.)
Mar 26, 2009 | Uniden Radio Communications
Antenna
OUCH! Cb antennas are cut to a specific frequency. FM antennas are also cut to a specific frequency. If you ground the antenna to a frame, you short out the antenna. BAD THING. If it is a 102" whip, you would have to cut off about 2/3's of the whip to work. If there is a cylinder at the base of the antenna You would only need about 7' of the whip sticking out for it to work right. Inside the cylinder there is a coil that would make up for the missing length of a 102" whip. I would suggest finding an old CB with FM built in like one of the old SEARS CB/FM receivers.
They had the electronics built in to compensate for the varience in the old sets.
Jul 30, 2008 | Cobra 29 LTD CB Radio
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
