Question about Lands Phones
Trac phone says service disabled - Lands Phones
  • LILMUZHIMU Oct 27, 2008
    my phone serviceman's and disabled and my phone dont show my nuber no more.
I have a trac phone as well. My son did "something " and then I was unable to make/recieve calls and where my units display it now says "service disabled". I contacted trac phone at 1-800-867-7183 and spoke with tech support. After entering a series of codes into my phone I was able to use my device again.
Posted on Jul 03, 2008
How do i reset my traction control
Is your trac light lit ? If so it has a problem an till it is fixed , you can't reset it. Need to have it checked for DTC'S - diagnostic trouble codes .
If the ABS control module detects a malfunction, it will disable TCS and will command the BCM to turn the TRAC LED Off. The driver can also disable TCS, if desired, by depressing the TRAC switch. When the driver depresses the TRAC switch, the ABS control module will disable TCS and will command the BCM to turn the TRAC LED Off.
DTC C0276 TCM Traction Control Not Allowed
DTC C0275 or C0276
The TCM sends a serial data message to the electronic brake control module (EBCM) indicating that torque reduction is temporarily not allowed.
DTC C0550
DTC C0896
The electronic brake control module (EBCM) is required to operate within a specified range of voltage to function properly. During antilock brake system (ABS) and traction control system (TCS) operation, there are current requirements that will cause the voltage to drop. Because of this, voltage is monitored out of ABS/TCS control to indicate a good charging system condition, and also during ABS/TCS control when voltage may drop significantly. The EBCM also monitors for high voltage conditions which could damage the EBCM.
Oct 16, 2015 | 2004 Saturn VUE
How bad is the warning: service advance trac
When the light is on the system is disabled. You would need to get the body computer checked for trouble codes to find the problem.
Feb 22, 2015 | 2013 Ford Explorer Limited
Lexus repair service
Check engine light needs to be repaired 1st. VSC is disabled in the meantime. Your local Checker or Auto zone can help with a code pull.
Jan 08, 2014 | Cars & Trucks
I have a Hauwai cell phone and I use trac phone service but cannot use the microphone nor can I access the internet with this even though I pay for it every month
u have to check ye network data setting and it's a setting of yr services provider setting so go to network services store they give u proper setting and trac phone services has various settings so u have to talk with model number and id to customer support
Nov 02, 2013 | Allsop 29575 Ahola Hawaii Mouse Pad
How to I disable the airbag on my 2004 Ford Explorer Sport Trac so I can change out the cruise control buttons?
Remove RCM fuse from dash panel fuse box. Fuse F2.10 10 amps. Turn key onfor 30 seconds and see that Air Bag light is lit. Now disconnect battery negative cable for 1 minute, leave disconnected while service is done. now the air bag is disabled. To repower the system turn key on, insert fuse. connect battery, now turn key off for 10 seconds, then turn key on and watch the air bag light. it should go on then after the air bag module is happy that everything is ok, it will turn off.
Dec 06, 2010 | 2004 Ford Explorer Sport Trac
My trac fone
When was the last time you bought an airtime card? Becuase I have a Tracfone too, and you have to buy an airtime card every 90 days...so if you haven't bought one in 90 days then that's probably what's going on. You can buy it online from Treacfone.com, in stores, or directly from your phone. Hope this helps! :)
Feb 15, 2010 | LG TracFone 600 Cell Phone - TF600GP4
The trac light comes on and cannot remove by pushing the button, and the car stalls or acts like it's missing terribly
the trac.control is disabled if the check engine light comes on repair the engine problem and the trac.control should work
Nov 06, 2009 | 2002 Pontiac Grand Am
I have an aftermarket Ford remote start on my 2005 Ford Sport Trac. I tried to start with my truck with the key in the ignition, I would hear clicks and then the alarm would go off. I have tried to reset...
First thing is to identify the alarm system, I.E.- who made it and what model it is? (like Viper, Automate, etc...)
Contact the aftermarket alarm manufacturer or the person that installed the alarm (if you had/know who installed the alarm system). Most major system have a phone number and a list of qualified installers for their systems. They will be able to direct you to a shop that can service the system. If your vehicle won't start, you may have to have it towed to the location to diagnose and correct the problem.
Apr 30, 2009 | 2005 Ford Explorer Sport Trac
My phone says No service
THE EASIEST SOLUTION IS TO GET OUT YOUR MANUAL THAT CAME WITH YOUR TRAC-FONE, AND CALL THE NUMBER THAT REFERS TO SERVICE. THEY WILL HELP YOU DETERMINE WEATHER IT'S THE PHONE OR THE SERVICE THAT IS THE PROBLEM. ANOTHER ALTERNATIVE IS TO GO TO, "TRAC-FONE.COM", AND GO TO THE SERVICE/HELP AREA..................... GOOD LUCK, JLR4
Jul 20, 2008 | Motorola Mobility TracFone® V170 Cellular...
Lands Phones Logo
724 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
