Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
A
Anonymous Posted on Jul 17, 2010
Just got a router from my buddy and i want to hook it up.
Roy
Level 3:
  • Master 2,571 Answers
  • Posted on Jul 20, 2010
Roy
Master
Level 3:
Answers
2571
Questions
0
Helped
494100
Points
7959
Take a look here.
(if you need to reset the router to factory setings, push something into the reset hole on the back of the router)
http://www.pcwintech.com/wireless-setup-belkin-g-plus-mimo-f5d9230-4-v5-belkin-firmware
I have a wgt624 router i am trying to hook up wifi with. I had cox cable install their cisco modem with a hard line and i needed to add wifi so went and bought this router off a buddy. How do I hook this...
hook it up to a computer, in the back of the router put the cord with the yellow end/yellow phone wall clip,in to the yellow slot in the back of the router and the other end put it in any opening in the back of the power box/main power system. then put the plug in power cord to the router/ wall charger. and if you have a newer computer go on main screen and upper right corner ther should be a Bluetooth sign click on that and the routers name should be there?
I am connected to the internet. I can access all websites. I have two programs "First Class" an email server and Buddy for CLZ Barry a program that connects to my iphone to receive books i have...
You have to configure port forwarding in your router. Do you know what ports are used by "Buddy for CLZ Barry" and "First Class" (it probably uses port 21)? After you figure out the port numbers, follow the port forwarding steps documented in the router manual. Here's the link to the router manual:
http://help.cableone.net/HSD/Modem/PDF/SBG900_User_Guide.pdf#page=51
1helpful
Won't let sign into my buddy list
Try rebooting the router to make sure the connection is established.
Next check to make sure you have a connection to the router.
Lastly make sure your router is connected to the internet properly.
There's no place on modem to hook router
Look for Ethernet jacks. You want to hook both your computer and your daughter's laptop to the router to out ports i.e. usually on the front side. The back side of router would hook using probably another Ethernet jack to your modem.
2helpful
2answers
I have an original xbox console, and when I hook it up to a router to do system link, it doesn't connect. Have tried using my buddies console to troubleshoot, and his works fine with all the same...
This would be due to a bad ethernet card inside Hence you buddy is fine with your current rig I would have that looked at there are options out there to make these wireless going forward here you ethernet card is not working correctly.
Thanks and please do rate your solution today.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
1helpful
Cannot connect to a network that is using D'Link's DIR-615 as its wireless router
Log into your router and in the, I belive is the advanced tab make sure you have the PNP box unckecked, reboot and it shoud be able to connect.
Can't connect wireless. dell said to call to have router reset
hi buddy! you try to reset the router and i think you need to cofigure the router to your pc by typing the ip add. of router 192.168.1.1 and you choose the internet connection you belong ok.
D-Link DI-524
hey there , try this buddy remove all the cables connected except the power cable...do a hard reset upto 45 sec...wait for the power light to be solid green...connect all the cables back...still no go try swapping the ethernet cables...good luck buddy...tell me if it doesnt work.....
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
