Question about Brother MFC-8440 All-In-One Laser Printer
I am trying to figure out how to use my Brother MFC-8440 scanner. I would like to use it to scan documents to email out. When I go to Brother.com and look at the direction book, it doesn't have directions to scan. What's up with this? Can someone tell me how to scan to email with this printer/scanner? Thanks, Dianne
  • Brother Master
  • 5,529 Answers
It is part of the Network User's Guide (section 10) and the Software User's Guide (section 3 for a PC using Windows, Section 8 for network scanning), not the User's Guide. The directions below are for XP and Win2K primarily. Slight changes may exist with other OS versions. (Full software is not available for Win7 so the buttons on the unit will not work. You will need to launch scans from the computer only. You can use Windows Paint or Fax and Scan without needing third party software. Then attach the file to an email either in the email software or by right clicking on the file and choosing Send to Mail Recipient.)
For either use, put the document face down on the glass or face up in the ADF.
If you use a directly connected computer, you need to set the destination for the Scan to E-mail in the Control Center (section 4-4 in the Software User's Guide). Open this program and make sure the correct machine is in the drop-down menu. This program needs to be running to hear the buttons being pressed. Click on E-mail to set which program will get the scanned document as an attachment for your e-mail. You can also set the resolution and type of attachment. If you do not want to use available file formats, you will need to scan in PaperPort (or other software) and then use that to attach the file to the e-mail. Then click Scan to launch the scan from the unit. Hit Set when ready to send.
If you have the unit set up on the network, then you can enter the LAN setup in the Front Panel (or a browser). Hit Menu 6 (and then the appropriate number for the next feature), such as TCP/IP, DHCP or Static IP (these are under 1), SMTP, POP3, Mail Address (Menu 6 2). Setup the Scan to email with Menu 6 7 1 for color and Menu 6 7 2 for black and white.
This automatically sends the item to the email server or PDF as either a PDF or JPEG. Then you need register the PC that will get the file to the unit, if you use scan to email (PC). (Your version of Windows will matter for exactly where the information is: Control Panel > Scanners and Cameras or Control Panel > Printers and Other Hardware > Scanners and Cameras.) Right click on the icon for the unit and select Properties to see the Network Properties box. Go through all of this set up including the Scan To Button. Then the Control Center will launch the e-mail program when it "hears" you press Scan, select Scan to Email, press Set, then choose PC and press Set again. (or select the destination PC which has e-mail access and press Set again). Scanning will start.
If you have set the POP3 and SMTP servers and the unit can directly access them, then you can scan to e-mail and enter the recipient address. Press Scan, select Scan to Email, press Set, choose Email Server and Press Set again. Adjust the scan quality as desired pressing Set at each step. Once you go through all of the layers, the LCD screen will prompt you for the recipient's email address. Then press Start.
I hope this helps.
Posted on Jul 20, 2010
Can I scan a document to PDF?
any scanner, indeed any document, picture format can be saved as pdf. i would suggest first scanning the document as text (for example to words, or openoffice or indeed whatever you use as your document management program) and then port it (sort of print operation) to any free available "translator" program which allow you to save file as pdf. alternatively you can scan your document as jpeg and then save it as pdf, but this tend to produce very messy outlook and results are usually horrible.
Jul 27, 2010 | Brother MFC 8440 All-In-One Laser Printer
I am a first time user of the scan function. Brother MFC 8440.
Hi there
I myself would just scan the one first and send it to your PC and then scan the other part and send it to your pc and then just copy the first 1 in to the Microsoft word program and then copy the second one and past it into first under it so it becomes as 1 then upload it to your email and send, this is what I do.
Or of cause you can upload 1 first to your email then upload the other one to your email and send.
All The Best Pineworks
Feb 18, 2010 | Brother MFC 8440 All-In-One Laser Printer
I have a brother MFC 8440 and the document feeder has never worked properly. It pulls the documents in slightly off line and causes the paper to jam before it gets to the scanner. It is out of warranty...
you might have some type of foreign debris covering the paper path, you might want to try heavier paper (almost like a thin cardboard) and try to manual drive it into the paper path, do not force it too much if it wont budge.
also try cleaning your pickup roller, lint free cloth with iso-propel alcohol.
Dec 02, 2009 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC 8440 Automatic Document Feeder doesent feed
Could be a sensor in the ADF, or the hinge on the left rear of the scanner cover is broken.
Jul 21, 2009 | Brother MFC-8440 All-In-One Laser Printer
Unable to scan to email with gmail on a Brother MFC-6490CW
Use SMTP relaying. Set up a computer with SMTP relaying. Go into the Remote Setup Program for your Brother MFC and select Setup Server. Use the IP address of that PC in the Server Settings and set Auth for SMTP to None. Worked great for me. This document can help you set it up on the relaying computer/server. http://www.lesolsoncompany.com/InstantKB20/Attachment17.aspx
Apr 01, 2009 | Brother MFC 6490CW InkJet Printer
Brother MF-8440 scanner driver and document manager for Mac OS X
Open preview and go to file and then scroll down to "import from scanner" MFC should show up as a choice and then when the window appears, go ahead and pick your preferences and scan
Mar 01, 2009 | Brother MFC 8440 All-In-One Laser Printer
Scan from brother MFC 8440 to pc
you need to make sure that the brother printer is et as the default printer
Dec 19, 2008 | Brother MFC-8440 All-In-One Laser Printer
Mfc 8440 scanner installation onto my computer
After I installed the print/fax/scanner drivers on my computer, Paint automatically configured itself to recognize the scanner. Other image programs I had to manually configure the TWAIN source before I could import from the scanner.
Apr 14, 2008 | Brother MFC-8440 All-In-One Laser Printer
MFC 8440
the automatic paper feed is not working
Jan 31, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC-8440 All-In-One Laser Printer Logo
633 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
