Question about GE Profile PSS29NSTSS 28.5 Cu. Ft. Freestanding Side-by-Side Refrigerator with Electronic controls &...
The defrost cycle on my freezer seems to run too much/too often
The defrost cycle on my freezer seems to run too much. I cleaned the coils on the condenser, and the temperature gets down to -1 to -5, so I don't think the compressor/condenser/evaporator are having problems. The ice in the ice maker melts and refreezes in a solid mass. It seized up the motor in the ice dispenser too. It seems like the defrost cycle works, just too well. Is this a mother board problem, and is there a diagnostic that can be run on the defrost cycle?
Thanks - Doug
SOURCE: Ice cubes melting then refreezing in clumps
check the flap door to see if it is slightly open letting warm air in
Posted on Aug 10, 2008
  • 1122 Answers
SOURCE: ice dispenser freezes
check your ice dispenser door flap,is it coming all the way down?there is a solinard that opens and closes it,it might be going bad,if you can get in to it it might just need alittle lube,what make?let me know what you find-mike
Posted on Oct 17, 2008
lojacksdad
  • 121 Answers
SOURCE: bottom freezer, ice cubes melting and refreezing.
defrost timer saying off to long
Posted on Apr 17, 2009
Sea Breeze
  • 4655 Answers
SOURCE: evaporator coil freezing, replaced main control
It is possible you have a defective fan motor in the condenser area or evaporator area. Sometimes when they become defective they will run for a while and just warm up and stop while the compressor continues to run. I learned that one on four costly returns to the home. The cost was to me not the customer. Thanks, Sea Breeze
Posted on Aug 05, 2009
  • 143 Answers
SOURCE: my daughter left the freezer door open overnight.
YES.
Posted on Aug 13, 2009
Freezer fan runs not freezing . seems to be locked in defrost mode
read the manual book of the freezer ,,,and see if ice is not blocking the way......
Nov 20, 2015 | Amana Refrigerators
Frigidaire freezer runs a lot. Located in garage. In summer runs almost non-stop. Currently outside temps are below 0 deg F and freezer still cyles frequently. Have replace the freezer tstat. Defrost...
Yup, these timers have a tiny clock motor that can get lint on them, causing motor failure, should be simple replacement. Refrigerators in cold garages run more to regulate their temperature below 45 degrees.
Jan 29, 2014 | Freezers
Refrigerator has frost in freezer
replace the defrost thermostat on the coils in the freezer and you will be good to go. Here is the part to order.
Feb 10, 2013 | Amana DRB1901C Bottom Freezer Refrigerator
Whirlpool Refrigerator model ET18GKXHW0 0 I seem to have a problem with my defrost cycle. The fridge has warmed up over the last few days and there is frost buildup on the back of the freezer...
The defrost cycle is relative to the cooling coils and not the interior temprature. Frost showing up means air is leaking into the fridge... To resolve, you need to observe the cooling coils are free from buildup. it it the coils, usually under panels, that should be attracting the moisture, and the defrost cycle clears that buildup, and not any buildup in the main (user accessable) areas of the fridge....
Defrost timers are not too expensive, consider blindly changing that...but totally defrost the unit around the coils or you will never get past the issue.
Mar 02, 2011 | Microwave Ovens
Fridge is not cold ice is forming on the bottom of freezer I cleaned the coils and vacumed the back what could it be thanks
good that you cleaned the coils this will help the unit run better but your problem is the defrost cycle has failed . in the back of the freezer is the cold coil and it has frosted over preventing air flow . i would replace the defrost thermo and the ADC aditive defrost control . mm hope this helps feed back please ..
Dec 11, 2010 | Maytag MSD2656G Side by Side Refrigerator
I HAVE ABR18 BOTTOM FREEZER. THE COILS WERE VERY DIRTY AND STOPPED FREEZING. I HAVE CLEANED IT AND IT RUNS BUT DOESN'T SEEM TO GO BELOW 40.
While it's good that you cleaned the coils and that needs to happen periodically to maintain efficiency in the operation of your fridge, it appears not to have fixed your problem. It could be that you have developed a leak in the sealed system, and have lost refrigerant causing it not to cool. Or you may have a problem with the defrost system. All frost-free refrigerator-freezers have a thing in the system called a Defrost Timer. The thing is a little clock of sorts that tracks accumulated running time. Every 8 hours of run time the thing cycles through a defrost cycle. The defrost cycle is necessitated by the humidity that forms ice crystals on the freezing coils, if the frost is not eradicated it can build up to the point where no air flows over the coils to chill the inside of the box. (it may keep the freezer cold but no air goes to the fridge part. If completely solid neither cools) Most timers are located on the front of the machine, behind that removable grille under the door. The timer has a round hollow shaft through it, and can be turned with a screwdriver. If the compressor is running, give the shaft a slow twist until a click is heard. The compressor will stop. Give the fridge an hour to defrost the coils, and check it to see if it took off running. If an hour has passed and the fridge hasn't restarted, advance the timer again to start. Sometimes the nudge will make the timer run for a while. If this is the case, the unit will chill, and buy you some time to get it fixed. If the timer does not run, you can repeat the process daily until you get a replacement timer. If we're on the mark here, the pan underneath may not hold all the water, and a small flood will result. If the coils are frozen over and it's not the timer, there may be a failure of the thermodisk or the heater coils in the evaporator.That repair is more involved.
Jul 11, 2009 | Amana ABB1927DE Bottom Freezer...
Drain in freezer plugs up
sometimes can be solved by loosely coiling a piece of solid copper wire around the defrost heating element and down into the drain a little. the radiant heat on the wire during defrost cycle may help keep the drain open
Mar 13, 2009 | GE Refrigerators
Coil is freezing on freezer
Yes, the seal will let outside air into the unit causing the coil to ice up. When it ices up the air cannot blow through the fins in the coil, thus no cold air goes to the refrigerator section.
Dec 20, 2008 | Whirlpool GB2SHKRLS Stainless Steel Bottom...
My older kenmore refridgerator/freezer isnt cooling well
Likely defrost mode, which on older models runs for a fixed amount of time whether needed or not.
The motor that times the cycle may be stuck or running slowly. It often is located at the bottom front of the frig behind a cover that runs between the front legs. Unscrew it and you will see a small motor running, that, through gears, turns a wheel 1 rotation every 24 hours.
The wheel can also be turned by a screwdriver - turn it until you hear a click that indicates defrost cycle is off. Should solve the problem short-term.
Long term, replace the faulty motor or clean it off to run smoothly. Alternately, unplug the motor so that defrost never kicks in automatically and defrost it manually.
Oct 03, 2017 | Kenmore Refrigerators
Auot defrost problem?
cleaning the condensor is nothing to do with evaporator freezing up. keep an eye on it - you may have a problem with the defrost cycle. problem can also happen if freezer door has been left open
Jul 21, 2008 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
215 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
