Question about Philips Televison & Video
I have a phillps rear protection after about 20 to
I have a phillps model number 60pp9401 rear protection after about 20 to 30 min of use the pic starts dancing around
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please post a comment with the model no# of your Projection TV and also elaborate the question as to what exactly is happening, are you able to see a 3d image etc.
Thanks
Rylee
Posted on Jul 20, 2010
  • ryan handschuh Jul 21, 2010
    it is a a60pp9401 it has a 3d imagne but it bouncing a round a lot but if the tv sits for a while it will work great some times then it will start to bounce 3d in a matter of time the longer it sits off the better the picture
  • Rylee Smith
    Rylee Smith Jul 21, 2010
    Thanks for your reply. The issue is with the failed convergence (STK) ICs which needs to be replaced. It’s not a difficult job if you want to do this yourself, you should require some basic knowledge about soldering-resoldering components. To start with you’ll have to open the back of the unit and then replace the ICs (STK ICs) which are located behind the black heat sink and also check the resistors as if they are short the ICs might blow again after sometime. There are repair kits available which includes repair instructions with the parts, if you want to do it yourself, you can buy and repair it yourself. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
Phillps tv model number 50pl9126d/37 what is the red light mean
It depends on whether you are able to see a clear image or not. check the lamp first if its more than 2 yrs old you may need a new one, last one we checked with the problem you describe had a fan running slow. The fan nearest the lamp needs to run correctly or the tv will shut down. Good luck !
Nov 11, 2011 | Philips 50PL9126D/37B 50" DLP TV
Translating japanese to english on fuse box
is located under the dashboard on the driver's side. The fuse label is attached under the steering column. If something electrical in your vehicle stops working, check for a blown fuse first. Below table outlines detail fuse number, its ampere and circuits protected. honda-crv-interior-fuse-diagram-thumb.png
No.
Amps
Circuits Protected
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
7.5 15 10 7.5 (15) (20) _ 10 7.5 7.5 10 10 10 7.5 7.5 10 10 20 15 7.5 20 _ _ (20) 20 20 (20) 15 15 20 (15) 20 20 7.5 7.5 10 7.5 30
Power Window Relay Fuel Pump ACG ABS/VSA Heated Seats* Front Fog Lights* Not used Rear Wiper ODS (Occupant Detection System) Meter SRS Right Headlight High Beam Left Headlight High Beam Small Light (Interior) Small Light (Exterior) Right Headlight Low Beam Left Headlight Low Beam Main Headlight High Beam Small Lights MAIN TPMS Headlight Low Beam Not used Not used Moonroof* Door Lock Front Left Power Window HAC Option Rear Accessory Socket Accessory Front Right Power Window Accessory Power Socket on the Center Table* Rear Right Power Window Rear Left power window ACC Radio ACC Key lock HAC Daytime Running Lights Front Wiper
Dec 13, 2010 | 1997 Honda CR-V
Projection TV Phillps 60PP9202/17F, bought 2004. Was watching and suddenly the picture went out. All connections are good and components work. Can you help?
Hi.
If there is no power at all, then it is either the power cord or power board inside the TV.
If after the fault the TV went in standby and does not wake up, then the TV is in protect mode.
In protect mode higher voltages from PSU gets shut down and TV remains in standby.(see also Why my TV does not start up and remains in...)
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Then connect powr
If that does not work, and you keep having the TV in protect mode, it means that there is a fault.
In that case call the support number listed on Philips user manual to arrange repair.
If you are a technician I can try locating parts, service manual and giving more directions. Common faults that affect a Philips rear projections are convergence, PSU board, lamp and ballast assembly.
Regards.
May 28, 2010 | Philips 60PP9202 60" Rear Projection...
1. After being on for 1-2 hours the pic goes out and turns to "the green screen of death". Pic will not come back on unless TV cools for 30+ min. 2. When I switch from DVD source to cable TV source the pic...
You got an issue with overheating.  TV is designed to shut off to protect electronic components if TV overheats.  Take it to the shop and have them open this thing up to identify the faulty circuit.  Also, check to make sure your not blocking the heat vents.
Nov 11, 2009 | Hitachi 70VS810 70" Rear Projection HDTV
When taking pic in sunlight - lcd screen is whited out!!
I think that's normal. I also have experienced the same always when the screen is exposed to sunlight. Try adjusting its brightness or use an anti-glare protection.
May 26, 2009 | Olympus FE-20 Digital Camera
All
adjust the vertical hight with service mode. or adjust the liniarity V or replace the vertical filter or chk the+B volt ,solder the dry soldering point in vertical section ok i am Basheer my e male is ,,,,,basheerecb@yahoo.com ok by by
Sep 23, 2008 | Philips 27PT5445 27" TV
Televison & Video Logo
18 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
