Question about JVC XV-501 DVD Player
Jvc xv-501 dvd player. says reading and then eject the dvd
SOURCE: DVD (JVC XV-S502) Does not eject dvd. Word "lock" appears in screen
hey, this happened to me too. what you have to do is put it in standby mode, then press and hold the eject and stop button on the actual dvd player, the remote wont work doing this. this is how you can unlock and lock the dvds into the dvd player. why this is a feature jvc thought this needed im not exactly sure, but thats how you fix it.
Posted on Aug 12, 2007
SOURCE: jvc xv-s332 dvd player won't play
on the back is a seitch labelled ntsc/pal. flick it the other way might fix it
Posted on Mar 09, 2008
  • 916 Answers
SOURCE: error message when reading DVD
Try changing the region setting to region free.
1. Make sure there is no Disc in the tray.
2. Shut off the unit and unplug it from the AC outlet.
3. Press and Hold the "Play" and "Open/Close" keys,
simultaneously on the player and not the remote control.
4. While holding these keys, plug the AC cord back into the outlet. (TEST and CPU ver# will appear on the display)
5. Release the "Play" and "Open/Close" keys.
6. Press DVD Menu twice on the remote.
7. When the display reads s000 5858 use the up and down buttons to change the 000 to 02E.
8. Using the Left and Right arrow buttons, change the last four digits until they read 0000 for Region Free, 0101 for Region 1, 0202 for Region 2 or 0404 for Region 4.
9. Press Enter on the player.
10. Press Standby and wait 5 seconds.
11. Press Standby again. Your player is now set to the region you requested. If you find some titles do not play on the region 0 setting, you may have to hard select the appropriate region.
Good Luck. Let me know if it works
Posted on Jan 02, 2009
SOURCE: Unlock code for jvc XV-N652
Below is the only known process to unlock that model of DVD player. Does not work on 100% of dvd players.
1. Turn on dvd player
2. Open the tray
3. Press 0000 in the Remote Controller
4. Change to any region you want (0 for region free)
5. Press Pause to confirm your change
6. Turn off
7. Turn on again and enjoy
Hope this works for yours, please post back if it does. Thank you for trying Fixya!
Posted on Mar 24, 2009
SOURCE: JVC XV-N322 DVD player
Dear friend,
It is a software problem.Reflash ur dvd player.
Posted on Mar 29, 2009
I can't eject a dvd from a JVC player because movie I was watching kept freezing.
Unplug player from wall receptical, and detach any other leads that plugged into it, press and hold power for at least 2 minutes in an attempt to clear the microprocessor controller ic, if this fails! you may have to take the top off to manually eject the DVD.
May 04, 2012 | JVC XV-N310B DVD Player
Flashed my XV-NP1 with wrong firmware. now player wants original firmware CD. I need original firmware ISO!!!
  • Check the DVD player to ensure that you do not have a DVD disc inserted into the device. Press the "Eject" button and lift out any DVD present in the device.
  • Turn off your JVC DVD player.
  • Unplug the device from the power source.
  • Examine the front or rear of your DVD player and note the model number.
  • Reset your particular device using the "DVD Reset Procedures" documentation provided by JVC (see Resources). Cross-reference your particular device's model number with the instructions provided within the reset procedure documentation
  • Read more: How to Reset a JVC DVD Player ' eHow.com http://www.ehow.com/how_6940950_reset-jvc-dvd-player.html#ixzz16g5rec91
    Nov 29, 2010 | JVC XV-NP1SL DVD Player
    ''Bad disc'' error when any disc loaded in JVC XV-N670B DVD Player
    There may be a connection to the problem, but it sounds like the laser assembly may need to be replaced as well as/or the mpeg printed circuit board(the printed circuit board) attatched to the laser assy. Good Luck.
    Sep 26, 2009 | JVC XV-N320 DVD Player
    I have a JVC model XV-THS3
    try to press the "stop" button and then eject it.
    Mar 01, 2009 | Panasonic DVD-A110 DVD Player
    I HAVE A JVC XV-THP3 DVD PLAYER. MY LITTLE GIRL WAS PRESSING THE BUTTONS ON THE FRONT AND HAS LOCKED THE DVD TRAY. CAN YOU HELP ME PLEASE?
    Hi there, I just had the same problem with my daughter, looked in the manual and it says to hold down the stop button and press the eject button on the unit. That should unlock it, its the same procedure to lock it, in case you want to prevent you daughter from attempting to play biscuits!!
    Regards, darren
    Jan 08, 2009 | Panasonic DVD-A110 DVD Player
    Lock problem with my DVD player
    Dear friend,
    press and hold stop+play button on the front panel of the dvd player more than 15 sec the player will be unlock
    Dec 08, 2008 | JVC XV-S30 DVD Player
    LOCK displayed on the dvd player
    Though it may be different for different models, the JVC XV-N40 DVD Player LOCK can be disengaged (and engaged) by pressing the [EJECT] button while holding-down the [STOP] button. Yes, it's that simple but I had to search online to find it too. The XV-N212 did not appear on JVC's website when I looked for it there.
    Here's a link to the material that coves with the player in the box:
    http://resources.jvc.com/Resources/00/00/96/GNT0027-001A.pdf
    Happy viewing to all!
    Jul 19, 2008 | JVC XV-N212 DVD Player
    Jvc xv m-567 won' t read cd or dvd
    The problem, ended up being the DVD drive motor. Unfortunately, it wasn't worth finding a replacement motor.
    Jul 10, 2008 | JVC XV-M567 DVD Player
    Dear friend,
    May 16, 2008 | JVC XV-N320 DVD Player
    JVC XV-501 DVD Player Logo
    59 people viewed this question
    Top JVC Televison & Video Experts
    Jaime Hernandez
    Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
