Question about White Sewing 1521
Toyota RS2000, problems with shuttle hook
I have a Toyota RS2000, I've been using it for basic sewing but tried to make curtains recently. (Quite thick fabric and I'm not sure if this is what started the problem)
The machine was working fine until I had to change the bobbin thread, on starting to sew again, I found it would not work.
The shuttle hook and the bobbin appear to be the problem. The needle does not pull the bottom thread up and keeps getting caught on its way round - is this a problem with the timing?
I've done all the usual things, changed the needle, re-threaded, oiled, had a good clean, checked the bobbin winder is off.
I can rotate the handwheel both forwards and backwards ok, and have watched the thread repeatedly getting caught.
Can any body help?
  • White Sewing Master
  • 7,365 Answers
My suggestion is to have it checked, sometimes sewing thick fabric on some machines can cause a problem.
Posted on Jul 31, 2010
How to use a twin needle on my SR2000 toyota sewing machine
First, verify that your machine can use a twin needle. Most machines take will use a twin needle will have separate thread guides and duel thread spool pins.
To thread it, thread one thread all the way through one of the needles and then thread the second thread through to the second needle. This will help keep the threads from twisting.
Toyota RS2000 Instruction Manual
Aug 25, 2016 | Toyota Sewing Machines
MY BOBBIN CASE HAS FALLEN APART AND I'M NOT SURE HOW TO PUT THE PIECES BACK TOGETHER.
Sounds like you are describing the hook. Perhaps the owner's manual would be assistance. We don't know the make/model of your machine so are really unable to help. There are some videos on YouTube that show how to install a shuttle and bobbin case, but machines differ.
Set up the shuttle race for RS2000 Series
Brother LS30 Inserting Bobbin Vertical Shuttle Hook
How to Clean and Maintain your Sewing Machine at Home Front Loading Bobbin
Mar 14, 2016 | Sewing Machines
How do i install a bobbin in a toyota rs2000 please
Your machine has a removable bobbin case and vertical rotary hook (front loading) so it is very alike to many other machines in that you insert the bobbin into the bobbin case in a clockwise direction, pull the thread into the tension spring on the case, then place the case into the front of the rotary hook while pulling out the little latch on the case, then release it to secure into the rotary hook. The latch usually goes into the "12" position on the rotary hook, there should be a little indentation for it.
If you go to this page https://sewing.aisin.com.au/upload/1255582851068_file_RS2000SD2D3D.pdf you can download Toyota RS2000 manual and full instructions and drawings are there about page 8.
If you go to www.sewing.about.com, http://sewing.about.com/od/sewingmachineindex/ss/windbobbin.htm there is lots of helpful sewing machine pages too, general threading up, trouble shooting and getting the right needle for the job. How you wind the bobbin is important and you need to put it into the bobbin case the right direction so the thread comes off the bobbin then reverses direction through the tension spring.
Great video on You tube too which should help you http://www.youtube.com/watch?v=KHl-j4pYx4I
visually its so much easier than trying to describe the steps. But once you've mastered a bobbin case and bobbin system, they are all very similar between makes and models.
Jul 25, 2011 | Sewing Machines
Upper thread winding around shuttle hook of sewing machine
rethread the needle as the thread has no tension
Aug 30, 2017 | Euro-Pro Sewing Machines
We need a manual for toyota rs2000 cb sewing machine
www.sewingonline.co.uk/instructions/toyotars2000/ -
cgi.ebay.co.uk/Toyota-Sewing-Machine-RS2000-CB-Series_W0QQitemZ300326924245QQcmdZViewItemQQimsxZ200
Jul 06, 2009 | Toyota Sewing Machines
White Sewing 1521 Logo
490 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
