I have a powerline adaptor and it is connected in both areas the one that is connected to the router is not showing signal and the light on the back of the router where it is pluged in is not lite up. Any suggestions?
    President:
  • 2,571 Answers
The powerline adaptor is faulty or the router is dead.
Has a fuse blown somewhere, are all the plugs in right?
Posted on Jul 20, 2010
I have a d-link 2750u wifi router with dual atntena..but connect in my badroom its near by wifi router i fonna show you in video with distan
Hi
Thanks for the video. I appears that you have concrete floors in your home. A couple of things that drasticly reduce wifi distance or signal strength is electrical fields caused by wiring in the walls and concrete walls or floors. Concrete is very dense and also has a lot of metal rebar in it for structural strength. This combination is very tough to penetrate with radio signals. The best thing you could do is either mount the router higher in the first room you showed so that it is at a level about even with the floor of the second level or add a repeater somewhere on the second floor. Mounting the router higher allows the radio waves to bounce around both levels without having to go through the concrete and rebar between them.
Jun 13, 2014 | Computers & Internet
I have a Belkin powerline adapter with three ethernet ports. The adapter that connects to my modem suddenly went dead. The connection to the modem is good and the outlet is working. The red light that is...
Hi i do understand ur issue ....for this you need to update the firmware so follow these steps to update the firmware
Step 1)Go to the link www.belkin.com/support
Step 2) Click on the adaptor picture
Step 3)Enter the model number of the adaptor which you can check on the adaptor itself-starts with "F5d"
Step 4)Enter that number and click on play icon
Step 5)You will get an DOWNLOAD icon and clivk on that and save on the computer
Step 6)Save that in the desktop
Step 7)Connect modem>>router>>computer
Step 8)Open the browser page and type http://192.168.2.1
Step 9)On the router page towards the left under utilities click on firmware update and update the firmware which is on the desktop
NOTE: THE ABOVE STEPS ARE APPLICABLE IF YOU ARE USING ONLY A BELKIN ROUTER
If still you have any issues contact 24/7 belkin technical support
1-800-2235546
Thank you,with regards
Priya
Aug 22, 2010 | Belkin Powerline F5D4050 Network Adapter
Seemlessly joining two networks
try changing the subnet on N1 to 255.255.254.0 or 255.255.248.0
Apr 24, 2010 | Computers & Internet
I have two Belkin powerline adaptors 200mbps type
Your hard disk is failing and should be replaced. Have you tried to press F1 when you get the message? If this doesn't help try to enter the bios and disable S.M.A.R.T.
Your first goal is to save the data so please do that before it's too late.
Mar 09, 2010 | Belkin Powerline F5D4050 Network Adapter
Hi, I'm an idiot! PLEASE HELP
you may be suffering from mixed Cat 5 and Cat 6 cabling.
The wiring is slightly different and they don't work well when mixed in routers and modems etc. One or the other will work , but when they're mixed it'll do what you have going on here...
I would recommend wiring everything with cat 6 ethernet cabling. Look on your cable and you will find the labeling on the outer casing.
Sep 20, 2009 | Computers & Internet
Trouble installing XE102 Powerline
there wasn't actually any problem with the device. For these bridges to work, you need to be on the same phase of the wiring. If the devices are on different phases then they can't communicate. But I still couldn't get the encryption to work. Netgear support doesn't seemed to be bothered with that...they told me to ignore it.
Dec 16, 2008 | NetGear XE102 Powerline Ethernet Adapter...
Netgear xe102 isnot picking up an ip address
-- Xe102 is a plug n play powerline device
-- there is no specific configuration required for that .
-- try hard resetting from the reset hole on the back of the device
-- then get the powerline checked
-- check the light status of the powerline device.
And if the problem still persists , upgrade the powerline device ..
Follow the link below ::
http://kb.netgear.com/app/answers/detail/a_id/901
Nov 15, 2008 | NetGear XE102 Powerline Ethernet Adapter...
Out of range
When I bring up the wireless network manager, it shows a strong signal to connec to the access point (linksys wireless router). But when I try to connect, it indicates that it's either out of range, or can't find a signal. I've checked that the wireless adapter is enabled, (it is), I've updated to the latest driver, my other computer connects just fine to the acess point, I don't know what else to do at this point. Any help much appreciated....
Dec 07, 2007 | Intel PRO/Wireless 2100 MiniPCI 802.11b
Can my neighbors or power company intercept my data over my powerline network?
Our Powerline devices have security that will prevent anyone from seeing your Powerline network. Using the utility provided with the device, you can encrypt all data transfers over powerline to 56 bit DES. In addition, the range of the powerline signal is limited, in order to help prevent others from accessing the data stream.
Feb 19, 2006 | Efficient Networks Siemens SpeedStream...
Computers & Internet Logo
Alun Cox
David Payne
David Payne
