Question about Ultra Products 1000 VA 600 WATTS Backup UPS w/ AVR (ULT31502) UPS System
1000 VA 600W-S/N:20436760610. Unit failed after
Ultra 1000 VA 600W-S/N:20436760610. Unit failed after less than 2 years use. Wattage well below allowable parameters. Unit will not even pass through voltage to usable components. Attempts to turn on results in short "beep", and fast blink of purple pilot then, nothing. Any suggestions?
    President:
  • 2,571 Answers
I have gone through a few UPS, Im lucky to get 3 to 4 minutes if my power is cut.
I think most people plug too much into the UPS sockets.
The Battery backup protected sockets cant take the drain from everything over a prolonged period of time.
The nature of rechargable batteries means that when plugged permanently into a power supply they get damaged (li-on batterys especially).
Im afraid i cant help with this UPS, looks like you need a new 1.
I now only have my PC/Monitor/modem and router plugged into the UPS protected sockets.
Speakers / printer and other stuff are plugged into the unprotected sockets.
Posted on Jul 20, 2010
Heater only blows on high...what do I do?
sounds like the blower fan resistor unit. its located in the case below the pass side dash
Jan 20, 2011 | 2000 Chrysler Sebring
I have a 600w transformer - 300w per side- I ran two lengths of 12 gauge cable. 1st run is 100' with 8 20w lamps. 2nd run is 200' with 7 20w lamps. The 1st run is bright but the 2nd run is dim. I'm not...
Instead of 2 seperate wires run 1 long continuous wire & splice each light into it as you go along.There will be less resistance & the last light will be almost as bright as the first with very little difference in between.
Jan 17, 2011 | Malibu Hardware & Accessories
I have a Verbatim ac320gb USB Hard Drive. i try to format it in windows and had it say exceeded the hub power and how i have 0 bits on it. i try to reformat it and say 289 gb but windows can not format it....
Each USB port passes a limited amount of wattage.
The "formatting" is a "high-wattage" operation.
Try connecting to a different desktop computer, hopefully with more wattage per USB port.
Note that 289 * 1024 * 1024 * 1024 is equal to 320 * 1000 * 1000 * 1000
So, '289' (base-2) is equal to '320' (base-10).
Dec 31, 2010 | Verbatim VER95327 USB Hard Drive
What is check engine code c107?
do you mean P0107?iagnostic Trouble Code (DTC) P0107 - BARO Sensor Low Voltage Detecte 08.12.2010 · Posted in Automotive Diagnostic Trouble Code (DTC): P0107 - BARO Sensor Low Voltage Detected Description: Sensor operating voltage is less than 5.0 volts (VREF), as a result it failed below the minimum allowable calibrated parameter. Possible Causes: Open in the circuit, or short to ground VREF
Dec 23, 2010 | 2004 GMC Sierra
Light switch feels hot
If the switch is rated at 600 watts and you have six 100 watt lamps connected to the switch, you are at the capacity of the switch and heating would be expected. It's general practice to not place loads on a device that will exceed 80% of the device's ratings, in this case 480 watts.
Some heating in a dimmer switch is not unusual, but if it's hot, it should be replaced with a device with a higher rating or the loads should be divided. You could also lower the wattage of the lamps (to around 75 watt each) unless you would lose too much light.
If the sockets in the fixtures can be lowered closer to the surface of the fixture, you can probably reduce the wattage since more light will exit the fixture. You will also save a few bucks with less wattage. Lastly, check the fixtures themselves and see if they are rated for the wattage of the lamps you have in them.
Apr 14, 2009 | Lutron 1000-Watt Incandescent Dimmer...
NEW 600W L.V.TRANSFORMER DOES NOT PRODUCE ENOUGH POWER
This is more than likely what has happened . I am going to guess that your original low voltage trasformer was a 120 volt .6KW. Or 600watt transformer that has one lead from it to the lights . The newer less expensive transformer is also 600 watts , but the new one may have 2 sets of wire terminals on the back( 4 screws ). If this is the case , you have a transformer that is 600 watts output but it has 2 seperate 300 watt outputs that won't run 600 watts from 1 set of output screws . You will have to seperate the lighting load and may have to run an additional low voltage wire to half of your lights . In other words . Put 300 watts of light on 1 set of 12volt output screws and 300 watts on the other se of output screws .that will solve your issue . Good luck and enjoy your lights again . John
Nov 03, 2008 | Garden
Have Foxconn 975X7AB motherboard. Am building a new setup and looking at 8800 PCI-e series graphics cards and Core 2 Duo CPU. Would like advice on PSU wattage required. Think a 750w unit will be...
your manuals should tell you what the min req wattage for your motherboard and video card are the motherboard is more important of the two since it will provide power to the video so 600 would be quite enough I would think consider the electric bill on the 750 watt is pretty steep
May 06, 2008 | Computers & Internet
Hitron 600w 12' subs in a bandpass box
i think u mean ohms,amp wattage?wat r u trying to do>?
Oct 31, 2007 | Hitron 2 12in Subwoofers loaded in...
Ultra Products 1000 VA 600 WATTS Backup UPS w/ AVR (ULT31502) UPS System Logo
229 people viewed this question
Top Ultra Products Computers & Internet Experts
Laxman Bisht
Laxman Bisht
John Hong
John Hong
David Payne
David Payne
Are you an Ultra Products Computer and Internet Expert? Answer questions, earn points and help others
